DLIST
Atarigmr
Hi
I have started to play with some ataru 8 bit coding and I have ran into a problem, I am trying to have a widescreen with 240 lines (30 lines of which are mode 2 and the others mode 4), but it flickers, it only works with 232 lines, my dlist is:
dlist dta $42,a(vram),2,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,$41,a(dlist)
What am I doing wrong?
thx
  • 1 month later...
40 x 30 is normally the max - but you can get problems if the 240th scanline is in hires. There's a fix for it, involves using a DLI to play about with DMACTL at the right times.
You can create shortened characters using DLIs and VSCROL register changes.
So, e.g. if you have 6 pixel high chrs instead of 8 that means possibly 40x40.
My interlaced demo raises the usable resolution to 480 pixels instead of 240. 8 pixel high chrs could be done at 40 x 60 although they're half normal height and might be a bit hard to read.
Easist fix for you would be just use VSCROL tricks. You could get away without needing custom character sets by doing 7 pixel high characters.
240 / 7 gives 34 character rows with a few scanlines left over.
Thank you for clarifying things Rybags.
Shorter chars are not an option but I have come with an idea but I don't know if it will look ok - the extra lines were to be top and bottom game stats but I can have the game area a bit smaller(horizontally) and then have some columns on the sides free where I would have the score and other stats displayed vertically but this might be impractical as it might be hard to read also if I want to have some displaylist interrupts to get more color this will affect the stats too... hmmm
