Desmond's Dungeon: Kill level or bug?
19 replies to this topic
#1 therealbountybob OFFLINE
therealbountybob
  • 6,537 posts
  • Still time to join in HSC Season 13
Posted Tue Feb 28, 2012 5:46 PM
In the HSC we're playing Creative Sparks' Desmond's Dungeon ... the game gets to level 11 and is missing a ladder (see this post) making it impossible to complete.
Anyone know if this is a kill level due to lack of RAM etc or a bug? Either way perhaps someone could fix it and at least make it loop around perhaps if there are no more levels coded ?
#2 Pengwin OFFLINE
Pengwin
    Dragonstomper
  • 836 posts
  • So many projects, so little time...
Posted Tue Feb 28, 2012 5:54 PM
I'll be lucky if I get to level 6!
#3 therealbountybob OFFLINE
therealbountybob
  • 6,537 posts
Posted Tue Feb 28, 2012 6:02 PM
But you'll be good at Pengo or Winter Wally (shudder) ;) though I thought you'd be ok with the darkness... guess it's difficult for you to pick up the gold and then there's the ladders :grin:
#4 Shawn Jefferson OFFLINE
Shawn Jefferson
  • 1,959 posts
Posted Wed Feb 29, 2012 1:00 AM
You can just change the characters on the screen to add a ladder... just tried it in level 1 and it works.
#5 therealbountybob OFFLINE
therealbountybob
  • 6,537 posts
Posted Thu Mar 1, 2012 5:56 PM
Please can you share how to do this?
Looks like it's bottom left of level 11 (see screenshots on HSC link above) but here's what's strange I then started up on level 11 from the menu and the level was possible. I wonder if there is a random screen design element at play?
Perhaps someone could make the starting level selectable from the off (rather than being the highest you have reached) - that way we could try out the higher levels?
Thanks ;)
#6 therealbountybob OFFLINE
therealbountybob
  • 6,537 posts
Posted Thu Mar 8, 2012 4:00 AM
BUMP!
can anyone help with this?
Or point me in the right direction to make the edits?
Some more info looks like the Alternative s/w re-release had starting level selectable up to level 8 details here:
http://www.atariage....ost__p__2479208
Thanks
#7 www.atarimania.com OFFLINE
www.atarimania.com
  • 1,623 posts
Posted Thu Mar 8, 2012 5:49 AM
The game plays just fine from the original tape. Using save states, I got to level 14.
Also, all releases are 100% the same (Creative Sparks, Sparklers, Alternative Software). I believe there's also a Dutch version by Aackosoft but it probably isn't any different.
Atari Frog
http://www.atarimania.com
#8 rdemming OFFLINE
rdemming
  • 1,099 posts
Posted Thu Mar 8, 2012 6:50 AM
Attached the Aackosoft tape release (which AtariMania should already have ;) ). I don't have the tape versions of the other releases (AtariMania only has a .xex file), but this version uses 256 byte tape blocks instead of the standard 128 byte tape blocks. Strangely the AtariMania .xex is 19 KB while the game itself only needs 16KB. The .cas file is only 11KB including loading screen. So the .xex version has about 8KB of redundant data. I don't know which version you are using for the HSC, but maybe this .xex has introduced the bug.
Robert
#9 rdemming OFFLINE
rdemming
  • 1,099 posts
Posted Thu Mar 8, 2012 7:01 AM
I just saw that the Alternative Software version was posted in the other thread. It is at least different from the Aackosoft release in that the Aacksoft version has a loading screen and uses 256 byte blocks while the Alternative Software version is a normal boot tape without loading screen. I didn't compare the loaded data yet.
Robert
Edit:
In both the Aackosoft and Alternative version, you can initially select the starting level from 1 to 8 while the .xex version does not initially allow to change the starting level with the select key.
Edited by rdemming, Thu Mar 8, 2012 7:16 AM.
#10 Mclaneinc OFFLINE
Mclaneinc
  • 3,503 posts
Posted Thu Mar 8, 2012 7:28 AM
I presume Shawn was talking about editing the map in memory as I see no way adjust anything nor a screen maker?
#11 therealbountybob OFFLINE
therealbountybob
  • 6,537 posts
Posted Thu Mar 8, 2012 7:46 AM
Great response to the bump guys :thumbsup:
Perhaps someone can create an xex/atr of those .cas versions?
I remember the problem from an original tape years ago but thought it was a higher level (perhaps 13?)
atarionline.pl have a release(?) by English Software Co v4.xex which also allows start level 1-8. I'll check this out tonight.
Would still like the info on editing the levels and if somone could adjust the v4 above to allow start on any level (or 1-20) that would be much appreciated :thumbsup:
#12 www.atarimania.com OFFLINE
www.atarimania.com
  • 1,623 posts
Posted Thu Mar 8, 2012 11:19 AM
Thanks Robert, I'll check out the Aackosoft image when I get home!
I'll verify what's up with our version on the site as well and probably replace it, unless it's some kind of preliminary release (?).
Atari Frog
#13 rdemming OFFLINE
rdemming
  • 1,099 posts
Posted Thu Mar 8, 2012 11:40 AM
Not an .xex but I've created a "Multi Boot" disk out of the AackoSoft tape version of Desmond's Dungeon. But the loading screen was removed.
The disk also contains the Aackosoft tape versions of "Tank Commander" and "Submarine Commander" and the Aackosoft tape release of Hijack.
I will post the .cas files of those in later messages.
Robert
#14 rdemming OFFLINE
rdemming
  • 1,099 posts
Posted Thu Mar 8, 2012 11:44 AM
You're welcome. Attached the Aackosoft tape version of Tank Commander for you to check out. I wasted many hours on this game :-)
#15 rdemming OFFLINE
rdemming
  • 1,099 posts
Posted Thu Mar 8, 2012 11:47 AM
And Tank Commander...
#16 rdemming OFFLINE
rdemming
  • 1,099 posts
Posted Thu Mar 8, 2012 11:49 AM
And Hijack is also missing at AtariMania...
#17 therealbountybob OFFLINE
therealbountybob
  • 6,537 posts
Posted Thu Mar 8, 2012 7:33 PM
OK looks like the (v4) XEX or Desmond's Dungeone from atarionline.pl is good (well level 11 completes) not played much further yet. Not sure if gameplay is the same. I have extended the HSC round for a couple extra days so we'll see how far people can get!
Details here. Interestingly text shows "English Software" and not "English Software Company" ?
(still would like to know how to edit the levels ;) (when someone has time)
Me too! Tank commander is a really good game (it's an arcade game folks not a war/strategy game!)
#18 www.atarimania.com OFFLINE
www.atarimania.com
  • 1,623 posts
Posted Sat Mar 10, 2012 5:48 AM
Many thanks to Robert for the additional material and kudos to people who have dumped their tapes!
Had never seen this edition of Desmond's Dungeon by English Software! I believe it's a leaked version. Chances are the author submitted the program and English Software either had no interest or didn't offer as much money as Thorn EMI!
Atari Frog
#19 www.atarimania.com OFFLINE
www.atarimania.com
  • 1,623 posts
Posted Sat Mar 10, 2012 6:04 AM
That unidentified version which won't let you choose your starting level is pretty odd. Wondering whether it's an early run or another leaked edition... Well, I was completely wrong about there only being one version...
Would anybody be able to dump both the Creative Sparks and Sparklers cassettes so we could have some sort of "final comparison chart"?
Does anyone have the English Software file unpacked?
Thanks,
Atari Frog
#20 Shawn Jefferson OFFLINE
Shawn Jefferson
  • 1,959 posts
Posted Sat Mar 10, 2012 2:14 PM
I just used Atari800Win+, used DLIST to find the where the screen was in memory, did some trial and error adding character codes based on what I saw there. It appears that the levels are compressed or encoded somehow though, so I wasn't able to modify the original level (not easily in the time I took to look at it.)
