Loading Data in BASIC
Hi all,
is there a quick way of loading a block of 1024bytes in Atari BASIC?
So far I'm using:
1000 CHSET=152*256:POKE 106,152:GRAPHICS 0
1010 OPEN #1,4,0,"D:MYFONT.FNT"
1020 FOR I=0 TO 1023
1030 GET #1,J:POKE CHSET+I,J
1040 NEXT I
1050 POKE 756,152
Which takes an age.... I'm guessing I should be GETing 1024 bytes at a time and not 1 byte 1024 times?
Thanks...
I want to do something similar with USR routines and I haven't found a solution yet.
I want to store the length of the USR routine in the first two bytes of the file, followed by the actual USR code.
I wanted to GET the first two bytes and then just READ the rest but I haven't found anything that lets me do that in standard Atari BASIC.
Turbo BASIC lists BPUT and BGET but Turbo BASIC only works on XL/XE machines.
http://www.atariarch.../12/02/0007.php
<edit>
OSS's BASIC XL and BASIC XE also support BGET and BPUT.
http://www.atariarch.../05/10/0018.php
I have BASIC XL so I will probably just write two versions. One SLOW version for Atari BASIC and another for BASIC XL, BASIC XE, and Turbo BASIC
You should also look at RGET and RPUT.
Edited by JamesD
Hmm,
I am no programmer, but afaik somewhere in my collection I have some tools that can convert fonts into DATA lines and then Data lines into a string. And I guess a string can be read in much faster than Data-lines or an external font... But as said before, I am no programmer... -Andreas Koch.
Hi all,
So far I'm using:
1040 NEXT I
1050 POKE 756,152
Thanks...
Using BGET (at least I think this would be it, I haven't tested any code using BGET yet):
1020 BGET #1,CHSET,1024
1030 CLOSE #1
1040 POKE 756,152
Yes, for certain values of "in Atari BASIC". There's a well-known machine language subroutine which translates to ATASCII as "hhh*LVd" (where the * and d are inverse video). Try replacing lines 1020-1040 in your program with these:
1020 POKE 852,0:POKE 853,152:REM Put low and high address bytes in IOCB #1
1030 POKE 856,0:POKE 857,4:REM Ditto for low and high length bytes
1040 POKE 850,7:I=USR(ADR("hhh*LVd"),16):REM * and d are inverse video, 7 is the "get" command, 16 is IOCB #1
Please let me know if this works, it's completely untested :)
  • Haha 1
Wow. :)
Pure BASIC, under emulation on Altirra took 804 Jiffies. (so 804/50=16.08 seconds).
This method? FOUR (=0.08 seconds).
Not sure how well it'll work with real hardware but it's gotta be good. :thumbsup:
Thanks to eveyone who replied... Mr Fish, I have a lot of code to play around with here ;-)
BASIC Turbocharger includes fast machine language load routines for character sets and micropainter files.
The disks also include source files which could be used to create more general purpose routines.
I've included a text file, which has a partial listing of the contents of the disks.
BASIC Turbocharger.zip
Wow. :)
If you have fast I/O enabled it might not be so fast on real hardware, but then the looped version will be even worse.
Well worth the code change I'd say.
What I can't understand is why they wouldn't build in another mode when that's already in the ROM.
But I guess maybe they were out of ROM space.
Wow. :)
Well, it'll take longer on a real machine, but only because it takes time to find and read a file from disk.
Since this is the programming forum I thought I'd translate the string:
PLA
PLA
PLA
TAX
JMP $E456 ; CIOV
The PLAs gets rid of the argument count and the high-order byte of the argument, leaving the low-order byte (16 in the above example, representing IOCB #1) in the accumulator. TAX transfers that value to the X register where it needs to be, and finally JMP $E456 jumps to CIO and lets the OS do the heavy lifting using the values POKEd into IOCB #1 earlier.
So elegant. If there's only one thing that makes the Atari OS stand out from other OSes of its time, it's CIO.
Edited by Eyvind Bernhardsen
BPUT and BGET are not available in Atari BASIC. Of course with mentioned tricks it's doable.
When using Sparta-Dos one can use the XIO#40 / XIO#41 commands to load/save blocks of data.
I guess I wasn't obvious about BPUT and BGET not being in ATARI BASIC.
This may help out. I have a BASIC utility called CONVERT.BAS that will take any file, for example a font file, binary file, or screen file, and convert it into string assignments or DATA statements in a .LST file which can then be merged with your BASIC program. The thread is linked here:
http://www.atariage...._1#entry1813361
The real advantage is if you convert your font file into string assignments. It will automatically store the font into a string called S$ (which is 1024 bytes long) and provide the code that loads the string into RAM, below RAMTOP. This is done by messing around with the string offset and making the String point to RAMTOP. Any operations on the string immediately reflect RAMTOP, so the entire font file is loaded into RAM almost instantaneously. Allowances are also made in the code for CHR$(34) and CHR$(155) in the string assignments as well.
When you run the program, you will want to select String assignments, and reply "N" when it asks you if the file is a binary file. If you reply "Y" the first six bytes of the file are automatically stripped.
Hope this helps!
Edited by Synthpopalooza
2nd attempt.
It took a little while but I finally found a page documenting some of this.
http://www.atariarchives.org/alp/chapter_9.php
Edited by JamesD
  • 9 years later...
Here is Atari BASIC demo with loading character set instantly (bold characters):
10 REM ******************************
20 REM LOAD CHARACTER SET FROM FILE
30 REM ******************************
40 CHRAM=PEEK(106)-4
50 POKE 106,CHRAM
60 GRAPHICS 0
70 FOR I=0 TO 255
80 IF I>32 AND I<125 THEN ? CHR$(I);
90 NEXT I
100 REM LOAD FONT SET FROM FILE
110 OPEN #1,4,0,"H1:BOLD.FNT"
120 REM PREPARE CIO FOR FASTER FILE LOAD
130 X=16:DIM ML$(7)
140 ML$="hhh*LV*":ML$(4,4)=CHR$(170):ML$(7,7)=CHR$(228)
150 ICCOM=834:ICBADR=836:ICBLEN=840
160 REM High and low address for IOCB #1
170 POKE ICBADR+X+1,CHRAM:POKE ICBADR+X,0
180 POKE ICBLEN+X+1,4:POKE ICBLEN+X,0
190 REM CALL CIO (7 = "get" command, 16 = IOCB #1)
200 POKE ICCOM+X,7:A=USR(ADR(ML$),X)
210 CLOSE #1
220 REM MODIFY CHARACTER SET POINTER
230 POKE 756,CHRAM
The listing is prepared for display on any text editor, that's the reason the machine language code in ML$ string is modified a little to eliminate the need for inverse characters.
FONTLOAD.BAS BOLD.FNT
  • Like 4
you reminded me of another version that they use in the pirate's treasure stage copier.
PLA
LDX #$30
JMP $E456
always caught my attention as a child, today thanks to all the information the mystery is solved. ?
