Some A8,TI, and Colecovision protos and some questions...
30 replies to this topic
#1 labrat OFFLINE
labrat
    Moonsweeper
  • 334 posts
Posted Wed Mar 14, 2012 9:38 PM
I got a nice lot of A8 carts recently that had a few prototype carts. Some worked others did not. I wanted to share pics and ask advice on the nonworking ones...
I'm not entirely sure that all are prototype cartridges, since I know that there are pirate EPROMS, but here's some pics (The black tape was added by me to cover open EPROMS):
Donkey Kong Jr.
K-razy Antiks
Both of these were in cases and worked fine. There were also two that were on bare boards that I could not get to work, labelled as Galaxian and Quest... The latter of which is obviously the most interesting (since I don't know what game it is).
As I said, these did not work. The first one I tried was Galaxian, and I accidentally plugged it in turned around. Could this have fried it? It only gives a black screen.
For Quest... I only ever inserted it in the correct orientation, but still only get a black screen. Some of the pins on the back of the chip socket were bent, breaking the solder cones. I plan to take it to work to tidy up the soldering, but it looks like there is still a connection at all points. The soldering on Galaxian looks fine.
Its weird that all of the complete carts (there were a bunch in the lot) worked, but the bare ones did not. Are these more susceptible to static or other damage? I was hoping someone would have a suggestion as to what I should do with the ones that aren't working.
Edited by labrat, Wed Mar 14, 2012 9:42 PM.
#2 labrat OFFLINE
labrat
    Moonsweeper
  • 334 posts
Posted Wed Mar 14, 2012 9:45 PM
There was also some TI-99/4A possible protos from Atarisoft that I have not yet gotten a chance to try...
#3 Bryan ONLINE
Bryan
  • 9,895 posts
  • Cruise Elroy = 4DB7
Posted Thu Mar 15, 2012 5:22 AM
Yeah, you might have fried Galaxian. The best bet at this time is to try to dump the ROM contents directly. If you want, I can turn all the ROMs into files for you and we can figure out what's there.
#4 labrat OFFLINE
labrat
    Moonsweeper
  • 334 posts
Posted Thu Mar 15, 2012 7:20 PM
Thanks for the offer. I was planning on finding a way to get the files for the working ones out there...
#5 Bryan ONLINE
Bryan
  • 9,895 posts
Posted Sat Apr 7, 2012 4:19 PM
After taking a look at the carts for labrat, I've determined that only DK jr. and K-razy Antiks are for the A8. Galaxian and BC's Quest are Coleco. Here's the images for the A8 games if someone wants to compare them to release carts.
#6 deathtrappomegranate OFFLINE
  • 4,389 posts
  • Lipstick on my cigarette
Posted Sat Apr 7, 2012 5:24 PM
Antiks is the same as the released version, but there are multiple differences in DK Jr.
#7 Bryan ONLINE
Bryan
  • 9,895 posts
Posted Sat Apr 7, 2012 8:07 PM
Interesting. I wonder what changed.
#8 labrat OFFLINE
labrat
    Moonsweeper
  • 334 posts
Posted Sun Apr 8, 2012 5:06 PM
Thanks for getting these dumped, Bryan. I'm glad you figured out that those 2 were CV; its not a system I collect for so I would not have recognized them.
Nice. Hopefully something interesting...
#9 Kr0tki OFFLINE
Kr0tki
    Dragonstomper
  • 964 posts
Posted Mon Apr 9, 2012 5:54 PM
I've disassembled the images. There are only two differences:
1. Some values in lookup tables are changed. The result is, Junior is able to climb the ropes in the Chain scene a few pixels higher in the released version.
2. The prototype contains additional 10 bytes of code at $85d3. IMO it's a bit of test code that was later removed, as it affects size of Junior's hitbox in a somewhat detrimental way - for example, when Junior climbs all the way to the top on the Chain scene, incoming Birds are able to pass through his bottom without killing him - a feat not possible on the released version.
EDIT: I've also found that the well-known "BOOGA" cheat is somewhat broken (in both versions) - the routine is not initialised properly and the first time after startup it's actually enough to press Shift+A to enable the cheat mode. There are also another two cheat keys in addition to the known S (skip stage) and K (invinciblity) - there's also I - disable invinciblity, and O - disable cheat mode as a whole.
Edited by Kr0tki, Mon Apr 9, 2012 6:41 PM.
#10 Defender II OFFLINE
Defender II
  • 1,042 posts
Posted Mon Apr 9, 2012 9:53 PM
So someone put the Quest Coleco chips in the Atari 8-bit PCB.
Did you dump the Quest chips?
#11 deathtrappomegranate OFFLINE
  • 4,389 posts
Posted Tue Apr 10, 2012 6:23 AM
Excellent work, Kr0tki.
#12 Tempest ONLINE
Tempest
    Your Imperious Leader
  • 24,925 posts
Posted Tue Apr 10, 2012 7:15 AM
Awesome! Thank you for doing this. I'll have to add this one to my site (actually I need to get going on my site again for a whole bunch of protos).
If you're into disassembling 8-bit protos, I have a several Atari 5200 protos that tested differently but I couldn't see anything when I played them. I could post them all if you're interested.
#13 Bryan ONLINE
Bryan
  • 9,895 posts
Posted Tue Apr 10, 2012 7:37 AM
That's actually a CV PCB, it just looks like an A8 one. Labrat and I were discussing posting the other protos in a different forum (like, maybe the Protos forum?). :)
#14 Tempest ONLINE
Tempest
  • 24,925 posts
Posted Tue Apr 10, 2012 8:36 AM
Actually let me move this thread there. It belongs in the protos forum anyway.
#15 labrat OFFLINE
labrat
    Moonsweeper
  • 334 posts
Posted Tue Apr 10, 2012 8:56 AM
Yes, Bryan was kind enough to dump all of the chips. I will post the CV and TI tonight...
Thanks for getting this to the right place, Tempest
#16 Kr0tki OFFLINE
Kr0tki
    Dragonstomper
  • 964 posts
Posted Tue Apr 10, 2012 9:30 AM
Sure, post them, I'll look into them when I have more time.
#17 Tempest ONLINE
Tempest
  • 24,925 posts
Posted Tue Apr 10, 2012 9:35 AM
Ok I'll try to get them up by Friday. I've been meaning to release them anyway like I did with my 2600 protos, but at the time there really didn't seem to be any interest. Of course as with my 2600 protos there are one or two that I can't release due to promises I made to the original owner.
#18 labrat OFFLINE
labrat
    Moonsweeper
  • 334 posts
Posted Tue Apr 10, 2012 6:00 PM
It looks like I can't update the first post, but here's a recap since the thread was moved...
Bryan dumped these ROMs and posted the A8 ones above. There are also 2 CV and 3 TI carts.
Colecovision (I initially thought these were A8):
Galaxian
B.C.s Quest for tires
TI-99/4A:
Jungle Hunt
Ms Pac Man
Moon patrol
#19 Bryan ONLINE
Bryan
  • 9,895 posts
Posted Tue Apr 10, 2012 6:48 PM
Also, here's some text I found while poking around:
Galaxian contains this text:
GRAPHICS AND PROGRAM BY JAMES D. EISENSTEIN 08/11/83 DEDICATED TO THE ONE I LOVE
and this snippet (from the assembler?):
IN SECTOR 84/SYSTEM CRASH/20451
Quest contains:
SIERRA ON-LINE PRESENTS B.C.'S QUEST BY T SYDNEY DEVELOPMENT CORP 1983 SIERRA ON-LINE INDICATES TRADEMARK
R BANKS ML O'ROURKE
#20 Tempest ONLINE
Tempest
  • 24,925 posts
Posted Wed Apr 11, 2012 6:22 PM
Ok here are those protos I promised:
http://www.atariprot.../8bitprotos.zip
http://www.atariprot.../5200protos.zip
#21 Mitch OFFLINE
Mitch
  • 6,343 posts
  • 7800 Guy
Posted Thu Apr 12, 2012 12:09 AM
Thank you.
Mitch
#22 Bryan ONLINE
Bryan
  • 9,895 posts
Posted Thu Apr 12, 2012 6:37 AM
Would it be possible to change the name of the topic to include TI and Colecovision just so everyone knows what's in here?
#23 Tempest ONLINE
Tempest
  • 24,925 posts
Posted Thu Apr 12, 2012 7:19 AM
Ok the 8-bit link is back minus the no-no game. Sorry about that.
#24 www.atarimania.com ONLINE
www.atarimania.com
  • 1,618 posts
Posted Fri Apr 13, 2012 10:24 AM
Matt,
Are we allowed to make the 8-bit programs available on a site such as ours or are there restrictions? Maybe screenshots only?
BTW, what was the "no-no game"?
Thanks!
Atari Frog
http://www.atarimania.com
#25 Tempest ONLINE
Tempest
  • 24,925 posts
Posted Fri Apr 13, 2012 11:21 AM
Matt,
Thanks!
Atari Frog
I believe I took out the one game that wasn't allowed to be posted, so yes it's all good to use.
The 'no-no' game was Xenophobe. I was given a copy of the rom to review for the site, but was told not to distribute it. I forgot it was in my folder when I posted it.
