What can I use to write out an ST image to disk?
disk image to physical media
8 replies to this topic
#1 blakespot OFFLINE
blakespot
    Star Raider
  • 94 posts
Posted Thu Mar 15, 2012 1:33 PM
I need to write an ST disk image out to floppy to work on my 520ST.
I do not have a Windows or DOS PC with a 3.5-inch floppy drive.
Machines that do have 3.5-inch floppies in this room:
  • Several Amigas (networked)
  • NeXTstation Turbo (networked)
  • Mac Plus (networked)
  • Apple Lisa 2
  • Apple IIgs (networked)
  • Apple IIe
Is there any way I can write out a SS or DS ST floppy with these units?
I will order a KryoFlux one day, it could handle this. Yea, I may add an HxC2001 to the ST one day -- my Amiga 2000 has one.
Thanks.
bp
#2 mimo OFFLINE
mimo
    Preppie!
  • 6,796 posts
  • It's easy living in a bubble
Posted Thu Mar 15, 2012 1:58 PM
do you have an external drive for the ST?
If you do you could set up the HxC as drive 2 on the ST and copy from SD card.
#3 blakespot OFFLINE
blakespot
    Star Raider
  • 94 posts
Posted Thu Mar 15, 2012 3:24 PM
I do, but the HxC is basically physically attached to my Amiga in a way that I am not about to alter.
Tnx
bp
#4 ParanoidLittleMan OFFLINE
ParanoidLittleMan
    Dragonstomper
  • 810 posts
Posted Thu Mar 22, 2012 7:31 AM
There should be some SW for MAC what can do it.
Most important is to be aware that ST format is same as some others, like DSK . In fact, it is just content of all sectors in order. No any header.
So, you may need just to rename ST to some other extension, and may be that SW can deal with it.
There are sites where can gain more info about all this - formats, SW for platforms. Google in hands ! :)
#5 amiman99 OFFLINE
amiman99
    Dragonstomper
  • 890 posts
Posted Thu Mar 22, 2012 5:02 PM
If you have Kickstart v2 and higher in your Amiga 2000 then you can format DD 720K disks and copy files that way.
The WB ver 2 and higher have CrossDos sw which lets you use DD disks from PC.
Another idea, that I did not try, is to use PC emulator on Amiga and yous a PC DOS program to write the floppies. (I need to try this one day)
#6 Mark Wolfe OFFLINE
Mark Wolfe
  • 2,358 posts
  • The Central Scrutinizer
Posted Fri Mar 23, 2012 11:50 AM
I've been reading up about the kryoflux and ipf format. does anyone know where to get disc images for the ST in IPF format?? seems like it will be a while before we get there and meanwhile i do not theink the kryoflux will write from the STX disc image format, which sucks
#7 amiman99 OFFLINE
amiman99
    Dragonstomper
  • 890 posts
Posted Fri Mar 23, 2012 11:14 PM
OK, I was doing some tests and I have some nice results so far.
Looks like you can use an Amiga with Workbench 2.1 and higher and PCTask emulator to write Atari ST floppies.
I'm using A1200 with WB3.1 and 64MB RAM (it should not matter to have that much, but you do need some fast ram), PCTask v4 and DOS program STDISK.EXE
You need a DOS boot disk on 720KB floppy and a PC hardfile with DOS on it. There is a software on Amiga that lets you write files from Amiga side to the Hardfile, this is the way I was able to put the Atari ST disk images onto virtual C drive.
As a test I wrote a 720k ST image and I was able to read it on Atari ST.
#8 amiman99 OFFLINE
amiman99
    Dragonstomper
  • 890 posts
Posted Sun Mar 25, 2012 11:42 AM
I was able to make some experiments and it looks like we can only write 80 track disk images with 9, 10, 11 sectors on Amiga. Anything above 80 tracks would fail formatting.
#9 Tickled_Pink OFFLINE
Tickled_Pink
  • 5,976 posts
Posted Tue Mar 27, 2012 10:06 PM
Personally, I use FloppyImg. Unfortunately it is a Windows program. TBH if you're going to use a non-ST system for creating ST disks on a regular basis then you would be far better off biting the bullet and spending 10 minutes fitting a drive into a windows PC. Then just get FloppyImg and away you go.
