Lynx I vs Lynx II
8 replies to this topic
#1 vince OFFLINE
vince
    Star Raider
  • 79 posts
Posted Mon Mar 26, 2012 9:52 AM
I'm searching a way to recognize in a program if it is executed on a Lynx I or Lynx II system.
It could be a difference between register initialisation, or something like that... (this test would probably the first thing in the program)
Any idea ?
#2 sage OFFLINE
sage
    Dragonstomper
  • 985 posts
Posted Mon Mar 26, 2012 2:12 PM
Write Stereo register, re-read register. if =0 => lynx 1
#3 vince OFFLINE
vince
    Star Raider
  • 79 posts
Posted Tue Mar 27, 2012 11:55 AM
Thanks a lot !
I'll try it.
#4 vince OFFLINE
vince
    Star Raider
  • 79 posts
Posted Fri May 4, 2012 4:38 PM
I made a test with a write then a read into 0xFD50 adress (MSTEREO) and I confirm : it allows you to make distinction between Lynx I and Lynx II
#5 vince OFFLINE
vince
    Star Raider
  • 79 posts
Posted Wed May 9, 2012 3:32 PM
Here is my test sample :
#include <lynx.h>
#include <lynxlib.h>
char SCREEN[8160] at (MEMTOP-16320);
char RENDER[8160] at (MEMTOP-8160);
char MSTEREO at 0xFD50;
char pal[]={
0x00,0x0F,0x00,0x0F,0x0F,0x00,0x0C,0x08,0x08,0x0F,0x08,0x08,0x08,0x08,0x04,0x0F,
0x00,0xFF,0x0F,0x0F,0x00,0xF0,0xCC,0x8C,0x88,0x8F,0xFF,0x4F,0x48,0xF0,0x08,0xFF
void Vsync()
#asm
vretrace:
lda $fd0a
bne vretrace
#endasm
main() {
unsigned char val;
InitIRQ();
CLI;
SetBuffers(SCREEN,RENDER,0);
SetRGB(pal);
MSTEREO=0x10;
DrawFBox(0,0,160,102,0);
val=MSTEREO;
if (val==0x10) {
DrawFBox(20,20,20,62,0x0F);
DrawFBox(60,20,20,62,0x0F);
} else {
SwapBuffers();
Vsync();
for( ; ; ){
source : http://devlynx.ti-fr.../?pag=9&cat=111 (with comments, in french)
Edited by vince, Wed May 9, 2012 3:33 PM.
#6 Shawn Jefferson OFFLINE
Shawn Jefferson
  • 1,987 posts
Posted Fri May 11, 2012 12:48 AM
Link isn't working.
What programming environment are you using? I've never seen "char MSTEREO at 0xFD50;" in C before (that I can remember).
#7 vince OFFLINE
vince
    Star Raider
  • 79 posts
Posted Fri May 11, 2012 2:47 AM
Concerning the link, it was an error of DNS this morning. It must be updated now.
I use the NEWCC65 environment. It does not includes reference to 0xFD50, wich is the adress of the MSTEREO register (http://devlynx.ti-fr...=dtl&adr=0xFD50) so I added it in my code defining MSTEREO variable.
It would probably be better if I specify "unsigned char" instead of "char"...
#8 Shawn Jefferson OFFLINE
Shawn Jefferson
  • 1,987 posts
Posted Fri May 11, 2012 7:53 PM
Ah, that's why. Is that K&R syntax?
#9 vince OFFLINE
vince
    Star Raider
  • 79 posts
Posted Sat May 12, 2012 1:59 AM
Yes it is ;)
