conversions and other stuff
11 replies to this topic
#1 dr. kwack OFFLINE
dr. kwack
    Moonsweeper
  • 344 posts
Posted Sun Apr 22, 2012 4:36 PM
I lately rediscovered in my collection of classic computer stuff two books: Marvel Book of Computer Fun volumes one and two. It's a bunch of simple BASIC programs written around Marvel Comics Characters.
I'd like to do them on my Atari 8 bit, but it has no listing! What other popular computers of the time are closest to Atari Basic? I'm guessing C64. How hard would a conversion be?
Also, this will be my first summer off for a few years (I'm a teacher). One item on my to do list is to write a text adventure using AdventureWriter. I'm thinking of doing a Questprobe game featuring... Howard the Duck. Seriously. Never used the program before, any suggestions or advice?
#2 kenjennings OFFLINE
kenjennings
    Chopper Commander
  • 220 posts
  • Me + sio2pc-usb + 70 old floppies
Posted Sun Apr 22, 2012 4:48 PM
"hard" is relative.
If the game includes graphics for a different computer, then "hard" could be hard.
If not, then BASIC is BASIC (mostly).  Strings are the biggest difference for Atari BASIC.  Most other things are easier to adapt. If you can identify the platform used for the BASIC listing, then you should be able to google for a reference guide to explain how the commands work.
#3 Defender II OFFLINE
Defender II
    Dragonstomper
  • 913 posts
Posted Sun Apr 22, 2012 10:20 PM
You shouldn't have too much trouble with the text adventure.  No graphics problems like mentioned above.
Have you done any BASIC programming?
#4 sack-c0s ONLINE
sack-c0s
  • 1,064 posts
Posted Mon Apr 23, 2012 3:59 AM
the problem with c64 basic is that it's crap. PEEK, POKE and SYS are about the only decent commands it has so consequently and half-decent 'BASIC' typein will end up just being a loop to poke a machine code program into memory and call that instead.
so if a C64 program uses 'purely BASIC' then it'll be trivial to port to the Atari, but a bit rubbish. If it uses assembly then at best it's going to be a heavy rewrite of the 6502 it dumps into memory, at worst a total rewrite.
BBC basic is also a problem because it's probably the best BASIC, or to look at it another way the best damn macro assembler you'll ever use - you can put 6502 between square brackets and use the BASIC to control assembly to create macros, fill out lookup tables, etc. So a lot of it could end up being 6502 and not BASIC. On the plus side though it's a pretty barebones 'framebuffer strapped to a CPU' type machine and you do have the 6502 source to look at.
The ZX Spectrum basic is a bit of a pig to code in (it's like keyboard twister - left finger SYMBOL SHIFT, right thumb J, etc.) but maybe reading the code it should be fairly generic and one of the less painful machine to port from. Being a very popular machine in the UK there should be a lot of listings around for it too.
But whichever machine you go for it's going to be an effort
#5 deathtrappomegranate OFFLINE
  • 4,389 posts
  • Lipstick on my cigarette
Posted Mon Apr 23, 2012 7:05 AM
Is this one of the books?
If so, it's not very complicated stuff. The strings would probably be the trickiest part to convert, but there's nothing too daunting otherwise.
#6 miker OFFLINE
miker
  • 1,501 posts
  • Stay Atari!
Posted Mon Apr 23, 2012 1:17 PM
Ok, guys. Here's my trial.
I've retyped Bombs Away from the link given by deathtrappomegranate,
Steering by hitting L R U D (respectively).
Have fun! :)
#7 dr. kwack OFFLINE
dr. kwack
    Moonsweeper
  • 344 posts
Posted Mon Apr 23, 2012 4:17 PM
That's the book! Very cool miker. This will be a perfect time killer for the summer.
#8 devwebcl OFFLINE
devwebcl
    Dragonstomper
  • 815 posts
Posted Mon Apr 23, 2012 5:17 PM
Have fun! :)
nice work, however I didn't understand the game... (I love conversions :) )
#9 miker OFFLINE
miker
  • 1,501 posts
  • Stay Atari!
Posted Mon Apr 23, 2012 10:25 PM
Well, the plot is fairly simple. There are bombs appearing around our "superhero" and you have to press the right direction (Left, Right, Up or Down) to hit the bomb and make it go "away". That's all. :)
#10 Stephen OFFLINE
Stephen
  • 4,018 posts
  • A8 Gear Head
Posted Tue Apr 24, 2012 10:41 AM
Sounds like the 1st "stage" in Cosmic Ark, one of my fave 2600 games.
#11 miker OFFLINE
miker
  • 1,501 posts
  • Stay Atari!
Posted Tue Apr 24, 2012 10:48 PM
Ok, next one. Program looks trivial, but originally usues string instructions, which are not available in Atari BASIC, like LEFT$, RIGHT$ and MID$.
But... you can do without them as well.
How?
- Instead of LEFT$(A$,X) use A$(1,X).
- Instead of RIGHT$(A$,X) use A$(LEN(A$)-X,LEN(A$)).
- Instead of MID$(A$,X,Y) use A$(X,X+Y).
Of course the above instructions should be TRAPped, to avoid goig out range error.
OK, back to the program... Type in your name (12 chars maximum, or else it will be cut), and watch you name turning into... Hehe, no more hints. Just run it! :)
SPACE restarts the effect, any other key ends the program.
Edited by miker, Tue Apr 24, 2012 10:51 PM.
#12 NuY OFFLINE
NuY
    Chopper Commander
  • 196 posts
Posted Thu Apr 26, 2012 4:02 PM
Slight correction - RIGHT$(A$,X) returns the last X characters of a string, so if one had a string of "1234567890", RIGHT$("1234567890",3) would return "890". In your example, this would come out as A$(LEN(A$)-3,LEN(A$)), which evaluates as A$(7,10), which returns the last four characters.
So, to get the equivalent, you need to add 1 to X in RIGHT$, hence:
RIGHTS$(A$,X) becomes A$(LEN(A$)-(X+1),LEN(A$))
Similar for MID$ - MID$("1234567890",5,3) would return "567", which would need to be in Atari Basic as A$(5,7). Hence:
MID$(A$,X,Y) becomes A$(X,X+(Y-1))
This should be correct for standard Atari Basic and Turbo, not sure about Basic XL/XE or any others.
