0
INTV 1 that goes to black screen after a few minutes
7 replies to this topic
#1 flammingcowz OFFLINE
flammingcowz
    Moonsweeper
  • 447 posts
Posted Mon Apr 23, 2012 3:24 PM
OK I have had this one for a while. After a couple minutes of playing, it will go to a black screen. Once you reset it, it goes for even less time.
I tested the voltage and this is how it reads out:
green & blue               - 18.3 - was told it should be 18
green/yellow & green  - 9.25 - was told it should be 9.25
green & green             - 19    - was told it should be 18.5
Any experts have any ideas?
#2 thegoldenband OFFLINE
thegoldenband
  • 3,367 posts
Posted Mon Apr 23, 2012 8:32 PM
I have two that do the same thing.  One lasts for ten minutes and goes downhill with each restart; the other is lucky to make 30 seconds.
I know Intellivision I units were prone to overheating, but no one (that I know of) has ever quantified exactly which part is failing, and whether it can be ameliorated with a heatsink or something.  (It would certainly be a huge help if anyone's up for doing that!)
At some point, I'll try to set up the diagnostic program on my Cuttle Cart 3 and see if it tells me anything.
#3 flammingcowz OFFLINE
flammingcowz
    Moonsweeper
  • 447 posts
Posted Tue Apr 24, 2012 2:15 AM
I have read when other people ask this same thing, they are told to clean the cartridge port. How could I do that? And carts are a lot harder to push into this one, like someone pushed the pins out before.
#4 sqoon OFFLINE
sqoon
    Dragonstomper
  • 919 posts
Posted Tue Apr 24, 2012 5:45 AM
I would start by using Radio Shack electronic parts cleaner to thoroughly clean the console's power switch. I had one with a black screen where I could stil hear game sounds, and this did the trick.
#5 SlowCoder OFFLINE
SlowCoder
  • 3,686 posts
Posted Tue Apr 24, 2012 8:01 AM
Looks like the transformer is within tolerances.  What are you getting from the power supply?
I'd doubt the cart port as the culprit.  It sounds like we're talking heat expansion.  Check that your chips are seated properly.  You'll have to desolder the shielding around the motherboard to get to them.
#6 flammingcowz OFFLINE
flammingcowz
    Moonsweeper
  • 447 posts
Posted Tue Apr 24, 2012 8:09 AM
How do I test the power supply? I got those readings from the metal box that connects to the power outlet.
It gets pretty hot so I put a fan in the system and cut out a spot for it to blow out hot air, and it will stay cool. I cleaned a cart pretty good and it worked for about 20 minutes and went to the black screen issue again.
I'll take it apart later and try messing with the chips. Is there a specific one I should focus on?
#7 SlowCoder OFFLINE
SlowCoder
  • 3,686 posts
Posted Tue Apr 24, 2012 9:26 AM
I don't have access to the specs right now.  I'll try to post them later, unless someone else beats me to it.
Once you get to the board, there are 5-6 chips that are hopefully socketted.  You'll want to gently remove them, and reinsert them.
#8 pimpmaul69 OFFLINE
pimpmaul69
  • 1,618 posts
  • INTV Brotherhood Technician
Posted Fri May 4, 2012 10:19 PM
Most people cant test them but another problem can also be the 2 large capacitors. Easy thing to do is resolder them to board. Sometimes they get cracked solder joints and cause this. No matter where the problem is, honestly it is probably just a cracked solder joint. Possibly a chip, but easier to look for cracked or loose solder joints and more likely. One of these days i am gonna  take my spare intv and make it a test machine so i can test chip out of other systems.
