Use that old Monitor - Atari option
29 replies to this topic
#26 Gunstar OFFLINE
Gunstar
    Gunstar
  • 8,484 posts
Posted Mon Apr 30, 2012 7:47 AM
I bought that exact video converter for use with a VGA monitor and VGA projector, though I don't think I ever used my 8-bit with it. It was for other composite video sources.
it worked pretty good, though it still wasn't as sharp on either my CRT VGA monitor or my LCD projector as direct video/S-video was on the LCD projector.
Also, it lasted for just under a year and died.
I use it as a paper weight now.
Yea, I can see a very negative downside to this. Cheap quality. :) My screen shot is off of a NEC 20" LCD that is 8-9 years old, state of the art when I got it.
You may get a longer life span out of it than me though, depending on how often it is used. I used mine on a nearly daily basis for several hours. I did notice on occasion that the case was quite warm when in use. Maybe less use and good airflow will make it last longer. Maybe even remove it from the solidly enclosed case with poor venting.
When and if it goes bad, check the power supply caps first. I just fixed a 20" Samsung monitor for $2 replacing 2 bad electrolytic capacitors, works like new again (that's the monitor seen on the photo a few messages back)
Mine going bad has nothing to do with the caps, the chip(s) actually malfunctioned/burned out. I can plug it in and it turns on and displays garbage graphics onscreen.
#27 Atari8bitCarts OFFLINE
Atari8bitCarts
  • 1,472 posts
Posted Mon Apr 30, 2012 8:12 AM
Also, note one of the main reasons I posted this was because I tried many devices to convert analog to VGA. For the price, this one can't be beat. They're not easy to find, but I'm sure a few of you already have sources and old projects doing this.
This looks identical to the one I got from monoprice. http://www.monoprice...&seq=1&format=2
Looks like you got quite a deal on yours, it's not often I see something undercutting monoprice.
Ouch $96! I didn't want to spend more than $30. At $96 you could almost buy a decent LCD TV. :)
#28 kurtm OFFLINE
kurtm
    Moonsweeper
  • 284 posts
Posted Mon Apr 30, 2012 8:14 AM
?!? I had to double check, but it's only $32. Where did you get $96 from?
#29 Atari8bitCarts OFFLINE
Atari8bitCarts
  • 1,472 posts
Posted Mon Apr 30, 2012 11:03 AM
Sorry, I guessed I was using the 'Compare at" price. Not sure where they got that? For $32, that makes more sense, even if it craps out after a year or so :)
#30 Bryan OFFLINE
Bryan
  • 10,724 posts
  • Cruise Elroy = 4DB7
Posted Mon Apr 30, 2012 11:14 AM
Does the chip get hot? Maybe a heat sink would fix the problem.
