SIO2SD Micro
55 replies to this topic
#1 santosp OFFLINE
santosp
    Dragonstomper
  • 612 posts
Posted Sun Apr 29, 2012 12:15 AM
Hi to all. :)
This time I try to make the SIO2SD in micro version, and I like to think that I succeeded! :grin: As is, the size is identical to that of SDrive micro.
As regards the construction I have followed closely the design of original "version 2" schematic from SIO2SD wiki, but redesigned to a smaller pcb with smd parts.
The sd socket is push-push type, and the lcd screen is green backlighted with 2x16 characters mini display. Sorry for the green color, but is the only one I found available in this dimension, and at this price also!
Now the heart of the device the ATmega32A microcontroller, is the latest and optimized one with minimal consumption against the previous ATmega32-16. You can read for the migrating in the above link.
http://www.atmel.com...ges/doc8162.pdf
The 5 button have the same place and meaning as the original SIO2SD in its wiki page.
Internally a ISP connector exist for any update with a programmer. Alternative can be the same with the procedure of "Shift" + "K3" buttons.
The pull up resistor for the maximum 127Kb/s high speed, exist also in circuit.
The device is programmed with the latest firmware 3.1RC2, and work perfect with 3.5 fast loader.
Now about the plastic enclosure.
Because of the lcd display, isn't possible for me with conventional tools to make the hole. The result at least in my eyes is not acceptable, and of course, besides taking a long time to make. For that I addressed this in a local company with a cnc router, and which to arrive at a reasonable price, need to make minimum 50 enclosures. :-o
If you do like what you see and want to order one, as we all understand to be able to order materials should have at least 40 preorders...
The final price for this number of devices can be at 50 euros for each one.
Last the plastic enclosure of device shown in the photos, is hand made and used as a Demo. For that reason have some imperfection in the cut of the hole for the lcd. The final one if ever exist, will be flawless cut for all holes from professional cnc router.
Thank you all for your time. :thumbsup: :)
Posted Image
Posted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
Edited by santosp, Sun Apr 29, 2012 12:24 AM.
#2 Rybags ONLINE
Rybags
  • 14,194 posts
Posted Sun Apr 29, 2012 12:32 AM
Nice. What would be "nicer" is the option for a header that handles the buttons so you can relocate them wherever you want.
My SIO2SD is still bare, the overall design doesn't lend well to putting into a case without first doing mods to it.
Ideally I'd put one inside a machine or two if the price point was right.
#3 santosp OFFLINE
santosp
    Dragonstomper
  • 612 posts
Posted Sun Apr 29, 2012 1:11 AM
Do you have you some specific scheme or you want to relocate them from time to time?
#4 Philsan OFFLINE
Philsan
  • 3,055 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Sun Apr 29, 2012 1:13 AM
Owners of santosp's previous SDrive micro know the quality of his products and his flawless shipping.
The price is very low compared with other SIO2SDs on the market.
I hope it will have the success it deserves.
I will add it in the Topic for newbies. Added in Topic for newbies.
Obviously I am interested in buying one.
Edited by Philsan, Sun Apr 29, 2012 4:59 AM.
#5 beamer320i OFFLINE
beamer320i
    Moonsweeper
  • 293 posts
Posted Sun Apr 29, 2012 7:21 AM
Great news! Your last SDrive project was faultless in many ways - product quality, constant updates, communication and shipping. Please count me in for one unit, thanks!
Cheers,
Dom
#6 mimo OFFLINE
mimo
    Preppie!
  • 6,796 posts
  • It's easy living in a bubble
Posted Sun Apr 29, 2012 8:11 AM
Arrrrgh, no money left after incognito,side,sic,ultimate 1meg,uSDrive, Rana 1000, VBXE2 and XM upgrade.
However, I agree with Beemer, this guy is the perfect example of how a sale should be completed :)
#7 rdea6 OFFLINE
rdea6
  • 2,126 posts
Posted Sun Apr 29, 2012 9:11 AM
Hi to all. :)
I like this and will buy one.
Seller *****
#8 kheffington OFFLINE
kheffington
  • 1,722 posts
Posted Sun Apr 29, 2012 10:49 AM
Nice design, I would purchase one.
#9 MEtalGuy66 OFFLINE
MEtalGuy66
  • 2,662 posts
  • If it aint broke, fix it anyway!
Posted Sun Apr 29, 2012 3:09 PM
Posted Image
Mega-HZ showed me that almost a year ago..
#10 npturton OFFLINE
npturton
    Chopper Commander
  • 171 posts
Posted Sun Apr 29, 2012 3:12 PM
Hello Panos
Id get one also
#11 santosp OFFLINE
santosp
    Dragonstomper
  • 612 posts
Posted Sun Apr 29, 2012 11:28 PM
Hi guys. :) Thank you all for your good words. I am excited. ;)
As for the Mega-HZ device, if he can show this complete with enclosure and SIO cable to 50 euros, then YES!
Ladies and gentlemen we have an opponent! :thumbsup: I wish my attempt to make the other atari devices, most intergrated and cheaper simultaneously. :)
Edited by santosp, Sun Apr 29, 2012 11:28 PM.
#12 Defender II OFFLINE
Defender II
  • 1,042 posts
Posted Mon Apr 30, 2012 12:15 AM
I would like one, but when will you need the money? Does that include shipping?
#13 BillC OFFLINE
BillC
  • 1,426 posts
Posted Mon Apr 30, 2012 2:23 AM
I would agree that for a complete cased unit your version is a good value, for putting inside an Atari computer or other desired enclosure think the Megahz version would be better. Its' mounting holes line up well enough that the circuit board and display can become a single unit if desired, and the switches/LEDs being in a single row simplifies case modification a bit.
From your silkscreen markings it appears that you didn't follow his example in replacing the 74HC245 with a 74LVC125, this was to provide a lower voltage IO signal to the SD card.
#14 candle OFFLINE
candle
  • 2,774 posts
Posted Mon Apr 30, 2012 2:51 AM
if you leave it like it is now, with hc245 chip, it will kinda work
best would be to put cpu and sd card on the same logic levels (3.3V) and buffer sio signals with lvc/lvc125 chip
also, you need a reservouar cap as close to the sd card connector as possible (47uF will suffice)
don't copy errors that original authors made
#15 santosp OFFLINE
santosp
    Dragonstomper
  • 612 posts
Posted Mon Apr 30, 2012 6:42 AM
Please guys dont compare my device with Mega-HZ one. Besides, this is not the purpose of the topic. :)
I would agree with you but I do not sell a generic structure to put it where everyone wants! My construction is complete with enclosure and cable, ready to run! So what would be fair to do the comparison and to export any results, with another device in the same class. ;)
No I didn't follow nothing from his work. After some discussion with the inventer I decide to "tack with its own water". But.....After all what is the problem? The device is here and work perfect with last firmware revision,
Hi Sebastian! Can you suggest some programs that may experience glitches to try them in this construction?
Also what happen with the cart project? I have long time to hear from you. :?
Edited by santosp, Mon Apr 30, 2012 6:44 AM.
#16 doomguy OFFLINE
doomguy
    Space Invader
  • 37 posts
Posted Mon Apr 30, 2012 7:06 AM
I would like to buy one.
#17 candle OFFLINE
candle
  • 2,774 posts
Posted Mon Apr 30, 2012 7:23 AM
Panos, it's not about programs, it's about SD cards - it works with some of them, but not all of them, and it may vary from device to device - all this because of marginal IO logic levels present in this design
with SDrive you were safe because whole thing runs at 3.3V, here you have mixed 5V and 3.3V lines, and to make matters even worse, both are CMOS
as for the cartridge - you wanted me to evaluate feasibility and fitabliity of some vhdl code i need to write, thus, it will take some time, since my resources are elsewhere
#18 RevEng OFFLINE
RevEng
  • 3,977 posts
  • Bitnik
Posted Mon Apr 30, 2012 7:31 AM
I'm also interested in buying one.
#19 Philsan OFFLINE
Philsan
  • 3,055 posts
Posted Mon Apr 30, 2012 7:46 AM
Panos,
I think it would be a good idea to follow Candle's suggestions.
#20 HiassofT OFFLINE
HiassofT
    Dragonstomper
  • 951 posts
Posted Mon Apr 30, 2012 8:22 AM
The main problem with the HC245 is that a high level on the (Atmel-side) inputs will drive VCC of the SDcard from 3.3V to something like 4.5V. So far most cards seem to have survived this, but it's definitely a very bad idea...
so long,
Hias
#21 FULS OFFLINE
FULS
    Moonsweeper
  • 268 posts
Posted Mon Apr 30, 2012 9:52 AM
I'm in for one, maybe two.
#22 santosp OFFLINE
santosp
    Dragonstomper
  • 612 posts
Posted Mon Apr 30, 2012 10:04 AM
so long,
Hias
Sure. But judging by the volume of sales of this device from such others that also follow prototype design of inventer, for example Lotharek, must be hundrends! ;)
#23 sloopy OFFLINE
sloopy
  • 2,407 posts
  • lookin for bits, i like bits...
Posted Mon Apr 30, 2012 10:29 AM
so long,
Hias
I would have to agree with Candle and Hias, I bought one of your uSDrives, and its a very decent product... Keep your quality and engineering standards high.
If you make this suggested (or more correctly, required) change, i would be interested in 2...
sloopy.
#24 santosp OFFLINE
santosp
    Dragonstomper
  • 612 posts
Posted Mon Apr 30, 2012 11:04 AM
Hi sloopy. :)
As you can see very clearly, untill now none post the alternative circuit! Maybe is a TOP SECRET? Untill it down to, as you understand I must go with the existing from the inventer. ;)
Please guys to restore the matter to the original flow, this thread isn't about Mega-HZ device. Has to do entirely with my own version. Once more, is the latest version from original manufacturer and WORKS PERFECT with my Atari in latest 3.5 firmware.
Please let the post to run about the "Interest".
Edited by santosp, Mon Apr 30, 2012 11:05 AM.
#25 sloopy OFFLINE
sloopy
  • 2,407 posts
Posted Mon Apr 30, 2012 11:56 AM
I could tell you exactly how to do it, and all i did was look at a pinout of the 125 and 245, and the sio2sd schematic... but i would have to charge you a consulting fee :D
Have pins 22, 23, 24 coming out of the Atmega32, go into pins 2, 5, 9, 12 of the '125
Have pins 1, 2, 5 of the SD Card go into pins 3, 6, 8, 11
then have what was originally on pin 1 of the 245, go to pins 1, 4, 10, 13 of the 125...
this was just a quick look, so you may want to double check it...
sloopy.
