Berzerk - Exterminate ! Exterminate! Exterminate !
5 replies to this topic
#1 Kirmo OFFLINE
Kirmo
    Combat Commando
  • 9 posts
Posted Sun Apr 29, 2012 12:42 PM
YOU WILL BE EXTERMINATED...
A graphic hack of Berzerk , taken from "Whoniverse" of the Doctor .
Posted Image
Evil Otto has also been replaced ....
Here a video
and bin file
Edited by Kirmo, Thu May 3, 2012 5:42 AM.
#2 SpiceWare OFFLINE
SpiceWare
  • 9,624 posts
  • Medieval Mayhem
Posted Wed May 2, 2012 1:27 PM
Has promise, the Dalek animation is nicely down. However, you've got a couple glitches that need to be fixed.
1) The daleks sometimes shoot themselves when firing left/right, so their initial shot position needs to be tweaked. If you look at the source you can see a couple tables that should help fix that:
InitRobotMissileYOffset
   .byte 0						  ; not moving
   .byte 7						  ; missile traveling right
   .byte 7						  ; missile traveling left
   .byte 0						  ; left and right (IMPOSSIBLE)
   .byte 6						  ; missile traveling south
   .byte 6						  ; south and right
   .byte 0						  ; south and left
   .byte 0						  ; south and left and right (IMPOSSIBLE)
   .byte 1						  ; missile traveling north
   .byte 6						  ; north and right
   .byte 0						  ; north and left
InitRobotMissileXOffset
   .byte 3						  ; not moving
   .byte 9						  ; traveling right
   .byte 3						  ; traveling left
   .byte 3						  ; left and right (IMPOSSIBLE)
   .byte 4						  ; traveling south
   .byte 10						 ; south and right
   .byte 3						  ; south and left
   .byte 3						  ; south and left and right (IMPOSSIBLE)
   .byte 4						  ; traveling north
   .byte 3						  ; north and right
   .byte 3						  ; north and left
They start at FC91 and FC9C in your ROM. I'd start by changing the 9 to 10 for "traveling right", as well as 3 to 2 for "traveling left". If that doesn't fix it then try 11 and 1 and so on. If your hack tool is using HEX then use 0a for 10, 0b for 11. While I doubt you'll need it, -1 is the same as 255, or if you need to use HEX then use FF. -2 = 254 = FE.
Also the cyberman graphic "bleeds" 3 lines down the screen. The 3 lines will destroy any daleks they come in contact with.
#3 Kirmo OFFLINE
Kirmo
    Combat Commando
  • 9 posts
Posted Wed May 2, 2012 2:08 PM
Thanks for feedback SpiceWare !
Cyberman should be fixed reducing the number of lines of its sprite. Dalek has been already fixed, indeed was the missiles offset ...
Edited by Kirmo, Wed May 2, 2012 2:18 PM.
#4 Nerf Herder73 OFFLINE
Nerf Herder73
    Chopper Commander
  • 145 posts
Posted Wed May 2, 2012 3:59 PM
I think that the Cyberman should be Davros instead. :)
Edit: Just remembered this one:
http://www.atariage....twareHackID=289
Edited by Nerf Herder73, Wed May 2, 2012 4:03 PM.
#5 TrekMD OFFLINE
TrekMD
  • 2,935 posts
Posted Wed May 2, 2012 9:27 PM
Cool. Love those Daleks!
#6 Kirmo OFFLINE
Kirmo
    Combat Commando
  • 9 posts
Posted Thu May 3, 2012 5:45 AM
Wow , very cool , better than my !!! (I worked for nothing....)
EDIT : Added fixed bin file
