0
Need Your Help Testing New AtariAge Server
11 replies to this topic
#1 Albert ONLINE
Albert
    Greetings, Avatar!
  • 28,743 posts
Posted Mon May 7, 2012 9:30 AM
I'm in the process of setting up a new server for AtariAge.  In theory it should be MUCH FASTER because it has a ton of RAM (24GB), versus the 4GB in the current server.  I've setup a HUGE cache for the database server, which will allow it to store quite a bit of the database in RAM.  I'm also experimenting with using InnoDB tables instead of MyISAM (you database geeks will know what I'm talking about), and I'm curious to see how well that works (or doesn't!)  Anyway, if you want to play around with the new server, you can do so here:
http://atariage.dynd...ver.com/forums/
Anything you do on this server will not be saved, as it's just a testbed at the moment.  If you see anything weird, please report back here so I can investigate.  In particular, I'm curious how fast the server seems compared to this one.  Although it may be tough to tell without getting the same number of people logged in, so I may not really know until the server is switched over.  But I want to make sure any obvious issues are nipped in the bud before I flip the big switch.  :)
Thanks!
..Al
#2 revolutionika OFFLINE
revolutionika
  • 7,319 posts
Posted Mon May 7, 2012 9:50 AM
I made a post on that new server.
http://atariage.dynd...do-nes-section/
Also, the chat room works for me!!!!!   On this current server, the chat never works!
Edited by revolutionika, Mon May 7, 2012 9:51 AM.
#3 cmart604 OFFLINE
cmart604
  • 5,029 posts
Posted Mon May 7, 2012 10:54 AM
Lol! Looks like Rev can be an ass on more than one server at a time! :-D
#4 revolutionika OFFLINE
revolutionika
  • 7,319 posts
Posted Mon May 7, 2012 12:44 PM
Even more than that, Im an Ass on multiple website too!!!
Seriously though, why does the chat work over there and not on the current server?  Weird...
#5 Albert ONLINE
Albert
    Greetings, Avatar!
  • 28,743 posts
Posted Mon May 7, 2012 12:55 PM
I'll take a look at that when I get home.
  ..Al
#6 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 7,114 posts
  • Busy bee!
Posted Mon May 7, 2012 1:01 PM
Birthdays aren't working on the new server either.
#7 roland p OFFLINE
roland p
  • 1,591 posts
  • RLA
Posted Mon May 7, 2012 1:09 PM
Avatar is missing when I click on my name for the popup menu: http://atariage.dynd...-of-the-screen/
#8 roland p OFFLINE
roland p
  • 1,591 posts
  • RLA
Posted Mon May 7, 2012 1:23 PM
By the way, something minor, it seems that old avatars dont get removed if you use different extensions:
http://www.atariage....thumb-15728.gif  (old)
http://www.atariage....thumb-15728.png  (new)
#9 revolutionika OFFLINE
revolutionika
  • 7,319 posts
Posted Mon May 7, 2012 1:28 PM
Is that other Forum like a parallel universe?
:-o
#10 sloopy OFFLINE
sloopy
  • 2,387 posts
  • lookin for bits, i like bits...
Posted Mon May 7, 2012 4:21 PM
I tried logging in, and since i long ago forgot my AA password, i use FB when i login, and it gives me this when i try:
   "error": {
      "message": "Invalid redirect_uri: Given URL is not allowed by the Application configuration.",
      "type": "OAuthException",
      "code": 191
I would venture to guess tho this is cause of the ip/domain name its coming from?
sloopy.
#11 roland p OFFLINE
roland p
  • 1,591 posts
  • RLA
Posted Tue May 8, 2012 12:28 AM
   "error": {
  "code": 191
sloopy.
Those are two errors. 1. the errormessage itself 2. the json message should not be seen this way.(which seems a javascript related bug?)
#12 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 7,114 posts
  • Busy bee!
Posted Fri May 11, 2012 3:26 AM
Selecting Likes from your own profile page works as expected on the new server but it doesn't work on this one.
