Tapatalk problems
7 replies to this topic
#1 ProWizard OFFLINE
ProWizard
  • 2,332 posts
Posted Sat May 12, 2012 4:48 PM
Anyone here using tapatalk on iPhone?
It happens a lot that when I want to read a topic that there is no content shown in tapatalk. Is this known? And is there a solution?
#2 Creature XL OFFLINE
Creature XL
    Dragonstomper
  • 526 posts
Posted Sun May 13, 2012 1:50 AM
Same prob with Android version.
I then use the option "open in browser". The mobile version of AA is perfect. Even better then then using taptalk. However, I seem not to be able to select pages. And it is tiresom to click "next" in some of the bigger threads :)
#3 Mitch OFFLINE
Mitch
  • 5,941 posts
  • 7800 Guy
Posted Sun May 13, 2012 9:59 PM
You need to post this in the website comment forum not the A8 forum. I doubt Albert will notice it in here.
Mitch
#4 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,758 posts
Posted Tue May 22, 2012 12:28 PM
I've updated the Tapatalk module for the forum. Can you try it again? I'm using it now and it seems to work fine.
Thanks,
  ..Al
#5 Cebus Capucinis OFFLINE
Cebus Capucinis
    Jolly Retard
  • 7,735 posts
  • Wiseass Extraordinaire
Posted Tue May 22, 2012 12:29 PM
One of the things I consistently forgot about the mobile version of AA is that if you tap on the little circle next to the post title, it will take you to unread posts. So if you're looking at, for example, the Thrift Finds thread, and you want to just see what the latest post was, you can tap the circle next to the title, it will take you to the end of the thread, and thus you don't have to tap 'next' 442 times. :)
#6 ProWizard OFFLINE
ProWizard
  • 2,332 posts
Posted Tue May 22, 2012 5:04 PM
Thanks,
  ..Al
It keeps failing. I tried to open the topic Atari 800xl failure in this 8bit forum and I saw a blank screen in tapatalk. That is what I have when a topic seems to be incompatible.
Thanks for checking it out!
Greetz
Marius
#7 Albert OFFLINE
Albert
    Greetings, Avatar!
  • 28,758 posts
Posted Wed May 23, 2012 8:14 AM
I'll need to investigate this to see if I can reproduce it.  The Tapatalk guys have been pretty good about fixing problems of this nature, so if I can give them a recipe that they can duplicate, I'd expect a fix fairly quickly.
Thanks,
..Al
#8 ProWizard OFFLINE
ProWizard
  • 2,332 posts
Posted Sun Jun 10, 2012 12:49 AM
Thanks,
..Al
Did you succeed in reproducing the issue? At this moment I can not read the ultimate 1 mb preorder topic in tapatalk. Also I can not read the midnight magic topic. Both actual topics.
Also tried as guest but that made no difference.
