Atari ATW800 video question
TXG/MNX
Well you will need at least a sync splitter and likely a scan doubler as well. Might be better to look for a used CRT Sony PVM monitor.
Mitch
According to wikipedia, the transputer video output ranges from 512*480 to 1280*960. So I think it outputs 31KHz signal so you don't need a scan doubler.
At work I have a 19" monitor with BNC connectors for RGB and H-SYNC and V-SYNC. Don't think it will work with sync on green.
At DealExtreme they have VGA to BNC cables. I suppose they are meant for VGA on PC and BNC on monitor but I think they should work the other way around to. About sync, I suppose you can try to connect green to V-Sync/H-sync connection too using a T-connector. I don't think modern monitors work without a signal on the sync inputs.
Robert
  • 2 weeks later...
  • 3 months later...
  • 1 year later...
