Colleen: Android emulator
Android emulator Atari
86 replies to this topic
#76 shanti77 OFFLINE
shanti77
    Chopper Commander
  • 165 posts
Posted Fri Nov 2, 2018 2:23 PM
Best Android Emu
Tap screen after start (when show text SDL) to setup interface.
Edited by shanti77, Fri Nov 2, 2018 2:47 PM.
#77 adam242 OFFLINE
adam242
    Dragonstomper
  • 989 posts
Posted Fri Nov 2, 2018 8:33 PM
(deleted)
I was thinking of droid800..
Edited by adam242, Fri Nov 2, 2018 8:41 PM.
#78 erichenneke OFFLINE
erichenneke
    Moonsweeper
  • 394 posts
Posted Sat Nov 3, 2018 9:52 AM
I sent the patch upstream and built this new (still unsigned) apk.  Enjoy.
attachicon.gifcolleen-hack3-debug.apk.zip
Is there a trick to getting this to apk to install?
I already had colleen installed on my phone (for quite a long time now actually), but when I try to install this apk it fails.
And I already had the security option to allow for apps from unknown sources set to "on".
-Eric
#79 shanti77 OFFLINE
shanti77
    Chopper Commander
  • 165 posts
Posted Sat Nov 3, 2018 10:33 AM
Mayby unpack file, this is .zip
#80 slaker OFFLINE
slaker
    Space Invader
  • 11 posts
Posted Sat Nov 3, 2018 11:18 AM
Because the app uses the same name but comes from a different source, Android will refuse to install over it.
Just uninstall the old one first.
#81 erichenneke OFFLINE
erichenneke
    Moonsweeper
  • 394 posts
Posted Sat Nov 3, 2018 5:29 PM
ok, that worked.
However, when I run the app I don't see the keyboard shown in the screen shots in the your posts above.  I still see the keyboard like Colleen had before.
Is there something else you have to do to see the keybaord with CTRL ALT FN keys, etc.?
Edited by erichenneke, Sat Nov 3, 2018 5:31 PM.
#82 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 5,978 posts
Posted Sat Nov 3, 2018 5:36 PM
perhaps uninstall and delete all data? only thing I can think of. I've seen aberrant things when uninstalling but not deleting all data with certain apps
#83 slaker OFFLINE
slaker
    Space Invader
  • 11 posts
Posted Sat Nov 3, 2018 7:35 PM
Colleen doesn't provide its own keyboard.  If your device's standard keyboard doesn't provide CTRL, ALT, etc. (and it probably doesn't), you'll have to install a third-party keyboard app.  I use the Hacker's Keyboard (https://f-droid.org/...ion.pckeyboard/), but others may also work, like the AnySoftKeyboard.
#84 erichenneke OFFLINE
erichenneke
    Moonsweeper
  • 394 posts
Posted Sun Nov 4, 2018 10:18 AM
OK,  great . That worked.
Hmmm, that makes me pretty nervous when you have to accept the warning that the keyboard app could be capturing all keystrokes including passwords!!
#85 em_kay OFFLINE
em_kay
    Space Invader
  • 14 posts
Posted Tue Nov 20, 2018 2:19 AM
finally got colleen hack 3 loaded onto my nvidia shield and seems to be working fine with a ps4 controller
I'm having to use the 'mouse toggle' app to be able to press top right to get the start;select;options keyboard overlay and also the menu to insert disks
It would be nice to be able to map some of the ps4 buttons to start key etc...
#86 kiwilove OFFLINE
kiwilove
    Dragonstomper
  • 939 posts
Posted Tue Nov 20, 2018 3:43 AM
I do use a NV Shield - and it did work fine for some time - but then - it stopped supporting the external controller - was using a Microsoft gamepad.
I think it must have been the 3rd update to the tablet that broke the support.  Would like an easy way to restore or restart back with the old OS?
But can't find a solution.  Tried a X-Box controller - but that didn't work at all.  Maybe a NV controller would fix my woes?
Harvey
#87 em_kay OFFLINE
em_kay
    Space Invader
  • 14 posts
Posted Tue Nov 20, 2018 4:16 PM
Best Android Emu
tried this on my nvidia shield as well as colleen and it too works fine
I do like the save/load states
Both seem equally good as each other, I might need to play a lot more blue max to give them a good workout
Also tagged with one or more of these keywords: Android, emulator, Atari
