Images generated by RastaConverter
Images Gallery RastaConverter Colors
2016 replies to this topic
#26 potatohead OFFLINE
potatohead
  • 4,404 posts
Posted Sun Jul 15, 2012 11:38 PM
FWIW, I love this one:
http://www.atariage....ttach_id=251215
My favorite so far.
#27 frogstar_robot OFFLINE
frogstar_robot
    Dragonstomper
  • 754 posts
Posted Mon Jul 16, 2012 7:22 PM
A common Spider-Man background pic. Original:
Resized to 320x240 and remapped to indexed laoo pallette in GIMP. Brought in with:
./rastaconv spiderman_6.png /filter=box /pal=Palettes/laoo.act
and run through 465 million iterations:
Edited by frogstar_robot, Mon Jul 16, 2012 7:23 PM.
#28 Goochman OFFLINE
Goochman
  • 6,986 posts
  • Moongates to the Past
Posted Mon Jul 16, 2012 7:50 PM
frogstar_robot, that Spiderman pic would've been killer back in 1980 if the tech existed to produce it like that - nice!
#29 davidcalgary29 OFFLINE
davidcalgary29
  • 6,210 posts
Posted Mon Jul 16, 2012 8:08 PM
That Spiderman pic is killer now. :)
#30 Sikor OFFLINE
Sikor
  • 1,462 posts
Posted Mon Jul 16, 2012 10:46 PM
3 from me:
#31 AtariNerd OFFLINE
AtariNerd
  • 1,101 posts
  • For Illustrative Purposes Only.
Posted Tue Jul 17, 2012 12:27 AM
Too much awesomeness.
I must say, monochrome,with 8 shades in 160 mode, gives that certain 80 column mode a good kick to the shins. ;) Certainly, an alternative, if not a replacement.
#32 emkay OFFLINE
emkay
  • 9,710 posts
  • What's up?
Posted Tue Jul 17, 2012 12:45 AM
Alternative, yes. But the 16 shades do simply more benefits to an image than the higher resolution.
#33 emkay OFFLINE
emkay
  • 9,710 posts
  • What's up?
Posted Tue Jul 17, 2012 12:59 AM
The picture may demonstrate some important points.
Attached File  emkay_cyb450.xex   18.63KB   307 downloads
The banding gets visual reduced, when a cross check is happening.
Particular C64 Pictures don't have more than 16 colour per scanline. The resolution has to be set to 160 width directly, so no additional dither gets used for the pixel, just for details, where 16 colours per scanline cannot be used.
The best imgage type for the A8 is some picture with up to 128 colours of the indexed palette and approx. 9 colour per scanline.
A preprocessing of the dependend colours will reduce visual banding from the beginning.
#34 ilmenit OFFLINE
ilmenit
    Moonsweeper
  • 413 posts
Posted Tue Jul 17, 2012 11:01 AM
RastaConverter Beta5:
http://www.atariage....00#entry2561078
#35 emkay OFFLINE
emkay
  • 9,710 posts
  • What's up?
Posted Tue Jul 17, 2012 1:48 PM
This one is running for 330M evaluations.
Attached File  emkay_21C330.xex   18.68KB   250 downloads
Now I try the new version.
#36 rdea6 OFFLINE
rdea6
  • 2,799 posts
Posted Tue Jul 17, 2012 5:53 PM
First post in this thread only because I think I finally got almost good.
Attached File  rdea6 cactus.xex   21.3KB   337 downloads
atariwinpus palette.
#37 Stephen OFFLINE
Stephen
  • 7,535 posts
  • A8 Gear Head
Posted Tue Jul 17, 2012 8:29 PM
Wow - that one looks really nice!
Edit - the source image looks really nice! I thought that was what the Atari was generating.
#38 ilmenit OFFLINE
ilmenit
    Moonsweeper
  • 413 posts
Posted Wed Jul 18, 2012 6:13 AM
Beta 5.1 with /continue option fixed:
http://github.com/il...erter/downloads
#39 R6502A OFFLINE
R6502A
    Star Raider
  • 70 posts
Posted Wed Jul 18, 2012 6:29 AM
I like it a lot but it does highlight the saturation weaknesses of the Atari and the lack of reds. There are too many green/blues in the Atari pallet.
#40 MrFish ONLINE
MrFish
  • 5,422 posts
Posted Wed Jul 18, 2012 9:07 AM
No lack of reds on the NTSC side... although saturation is apparent on both. I'll take either's A8 pallet over the C64's any day though. ;)
#41 AtariNerd OFFLINE
AtariNerd
  • 1,101 posts
Posted Wed Jul 18, 2012 9:56 AM
Most 8-bits only have the one shade of fire-engine red. ;) To render the Spidey pic, they'd have to dither in browns, pinks, shades of grey and play with complementary/contrasting colors - which might be a nice effect, actualy, but not the semi-rendered-looking quality, achieved here.
#42 MrFish ONLINE
MrFish
  • 5,422 posts
Posted Wed Jul 18, 2012 10:09 AM
You'd better check your palette again. My NTSCs all have no less than two distinct reds: fire-engine red and a tomato paste red. PAL Ataris, from my limited experience, seem to have the more tomato paste red and a maroon that's nearly red. I've never had a problem coming up with an appropriate red in any situation on an NTSC Atari, unless the phase was out of adjustment.
#43 AtariNerd OFFLINE
AtariNerd
  • 1,101 posts
Posted Wed Jul 18, 2012 10:14 AM
I'm sorry, I meant most other 8-bit computers. ;) I should have been more clear. :D :thumbsup:
#44 MrFish ONLINE
MrFish
  • 5,422 posts
Posted Wed Jul 18, 2012 10:26 AM
Ah, ok, you meant PAL. No problem, just a misunderstanding.
#45 AtariNerd OFFLINE
AtariNerd
  • 1,101 posts
Posted Wed Jul 18, 2012 10:30 AM
Heh. Seems I did it, again. I meant most other brands, other than the Atari 8-bit line of computers, seem to have only one true type of red, usually a very bright, vibrant one and usually only in one shade, maybe two if you're lucky.
#46 MrFish ONLINE
MrFish
  • 5,422 posts
Posted Wed Jul 18, 2012 10:37 AM
Haha... ok. I thought when you said "8-bits", you meant THE 8-bits. ;)
#47 emkay OFFLINE
emkay
  • 9,710 posts
  • What's up?
Posted Thu Jul 19, 2012 2:17 AM
Atari does not have "all" red variations due to the type of colour production...
As the palette is a "cycle" of the available TVset colours, they were depending in a good way...
You can use either 6 colours of red , blue, or green, to make the images using a nice colour room, not leaving red, blue , or green there...
Attached File  emkay_dragons100.xex   22.08KB   246 downloads
Edited by emkay, Thu Jul 19, 2012 2:22 AM.
#48 ilmenit OFFLINE
ilmenit
    Moonsweeper
  • 413 posts
Posted Fri Jul 20, 2012 4:15 AM
ilmenit_roger.png Attached File  ilmenit_roger.xex   18.71KB   281 downloads
ilmenit_mk.png Attached File  ilmenit_mk.xex   18.7KB   316 downloads
ilmenit_ham6.png Attached File  ilmenit_ham6.xex   22.04KB   292 downloads
#49 Josť Pereira OFFLINE
Josť Pereira
  • 4,217 posts
Posted Fri Jul 20, 2012 5:21 AM
Delected...
Edited by Josť Pereira, Fri Jul 20, 2012 5:22 AM.
#50 Josť Pereira OFFLINE
Josť Pereira
  • 4,217 posts
Posted Fri Jul 20, 2012 5:24 AM
If this was possible to use on the game!...
:woozy:
Edited by Josť Pereira, Fri Jul 20, 2012 5:24 AM.
Also tagged with one or more of these keywords: Images, Gallery, RastaConverter, Colors
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
