Any APE's for Mac OS X other than sio2osx?
28 replies to this topic
#1 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
  • Kinetic, Not synthetic.
Posted Mon Jul 23, 2012 12:35 PM
I need a good free atari peripheral emulator for my macbook pro. any suggestions?
#2 candle OFFLINE
candle
  • 2,793 posts
Posted Mon Jul 23, 2012 12:45 PM
aspeqt?
#3 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
Posted Mon Jul 23, 2012 12:47 PM
I tried getting the Qt Libraries on my computer. didn't work
#4 Sub(Function(:)) OFFLINE
Sub(Function(:))
    Moonsweeper
  • 430 posts
Posted Mon Jul 23, 2012 1:58 PM
http://www.atarimac.com/sio2osx.php
#5 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
Posted Mon Jul 23, 2012 2:15 PM
Did you even read the topic name?
#6 Sub(Function(:)) OFFLINE
Sub(Function(:))
    Moonsweeper
  • 430 posts
Posted Mon Jul 23, 2012 2:20 PM
yes, half of it anyway
:dunce:
#7 mellis OFFLINE
mellis
    Moonsweeper
  • 266 posts
Posted Mon Jul 23, 2012 2:25 PM
I've got one you can try. It is designed specifically to work with the FDTI-based adapters.
Documentation is available here.
The linked documentation explains how to build a cable.
Here's a screenshot from the documentation:
Posted Image
#8 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
Posted Mon Jul 23, 2012 2:35 PM
thanks guys!
#9 mellis OFFLINE
mellis
    Moonsweeper
  • 266 posts
Posted Mon Jul 23, 2012 3:59 PM
I probably should have included a link to the application, huh?
Sorry about that. Download it here:
http://www.ellissoft... Server.app.zip
#10 ivop OFFLINE
ivop
    Dragonstomper
  • 647 posts
Posted Mon Jul 23, 2012 5:05 PM
I don't have a Mac running Mac OS X at the moment, but it should be possible to get this to work with MacPorts and the Qt libraries. Perhaps you can get one of the Aspeqt devs to (cross)-compile a (static?) binary or work together to get the problems you experience resolved?
#11 atarixle OFFLINE
atarixle
    Moonsweeper
  • 293 posts
Posted Tue Jul 24, 2012 5:27 AM
I have a (yet untested) build of AspeQt 0.8.1 on my Homepage for Download.
Elsewise, you can run AspeQt 0.8.3 (which I didn't get to build) in Wine (also untested).
Both available for download at http://www.abbuc.de/...nload/index.htm ...
#12 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
Posted Tue Jul 24, 2012 10:24 AM
I got aspeqt to compile... now where is my sio2pc USB mounted on mac? i tried ttyUSB0 but that didn't work. I downloaded and installed the FTDI Drivers too
#13 atarixle OFFLINE
atarixle
    Moonsweeper
  • 293 posts
Posted Tue Jul 24, 2012 1:00 PM
lucky one, how did you do this?
I don't even get the version 0.8.1 compiled again, which I compiled before.
#14 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
Posted Tue Jul 24, 2012 1:13 PM
go to the directory that the source is in, then go into terminal and do:
qmake -spec macx-g++
make
#15 kogden OFFLINE
kogden
    Dragonstomper
  • 636 posts
Posted Tue Jul 24, 2012 1:19 PM
I never had luck getting Aspeqt to build and run properly under OSX....
Mr. Ellis's SIOServer he linked above is quite neat and has a great looking interface. I personally like it more than SIO2OSX but the disk image support is not quite as versatile as SIO2OSX. For example I had trouble getting it to work with larger 256BPS or 512BPS ATR images. I can live without the Quad-density.... 256BPS I kinda use though.
I do like SIO2OSX's peripheral emulation features I hardly ever use them.
#16 atari8warez OFFLINE
atari8warez
  • 2,724 posts
Posted Wed Jul 25, 2012 5:30 PM
Hey Atariaxle, I have linked my support page to your website for AspeQt Linux/Mac OS binaries. Great work by the way....
#17 atarixle OFFLINE
atarixle
    Moonsweeper
  • 293 posts
Posted Thu Jul 26, 2012 11:29 AM
Thank you! Keep up with that great work.
I will try to build the 0.8.3 for Mac OS X.
Btw, I tested AspeQt 0.8.1 on Mac OS X, but it didn't work for me. But no worry, this may just mean, that my USB-2-RS323 doesn't work with Mac OS X.
Can someone else test this? Is Mac OS X supporting serial connections anyway?
#18 atarixle OFFLINE
atarixle
    Moonsweeper
  • 293 posts
Posted Thu Jul 26, 2012 11:55 AM
make
Doesn't work for me (g++: Error: unknown option >>-h<<)
#19 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
Posted Thu Jul 26, 2012 1:24 PM
do you have the qt libraries installed?
#20 atarixle OFFLINE
atarixle
    Moonsweeper
  • 293 posts
Posted Sun Jul 29, 2012 4:25 AM
yes.
it compiles for Linux on the very same system.
#21 esplonky OFFLINE
esplonky
    Moonsweeper
  • 440 posts
Posted Sun Jul 29, 2012 8:48 AM
Hm. Do you have Xcode on your Mac? Because you need it to use the 'make' command in terminal
#22 atarixle OFFLINE
atarixle
    Moonsweeper
  • 293 posts
Posted Sun Jul 29, 2012 9:50 AM
you mean, you built AspeQt on your Mac? I was thinking, you cross-build it on Linux for Mac OS X ... my fault.
on the mac, I always get the same error, either I build it in QT Creator or Terminal:
$ /Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/qmake -spec macx-g++
$ make
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic mainwindow.ui -o ui_mainwindow.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic optionsdialog.ui -o ui_optionsdialog.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic aboutdialog.ui -o ui_aboutdialog.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic createimagedialog.ui -o ui_createimagedialog.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic diskeditdialog.ui -o ui_diskeditdialog.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic autobootdialog.ui -o ui_autobootdialog.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic textprinterwindow.ui -o ui_textprinterwindow.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic cassettedialog.ui -o ui_cassettedialog.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic helpcontentwindow.ui -o ui_helpcontentwindow.h
/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/bin/uic docdisplaywindow.ui -o ui_docdisplaywindow.h
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o main.o main.cpp
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o mainwindow.o mainwindow.cpp
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o sioworker.o sioworker.cpp
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o optionsdialog.o optionsdialog.cpp
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o aboutdialog.o aboutdialog.cpp
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o diskimage.o diskimage.cpp
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o diskimagepro.o diskimagepro.cpp
g++ -c -pipe -g -gdwarf-2 -arch x86_64 -Xarch_x86_64 -mmacosx-version-min=10.5 -Wall -W -DVERSION=\"0.8.3\" -DQT_GUI_LIB -DQT_CORE_LIB -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/mkspecs/macx-g++ -I. -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtCore.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/lib/QtGui.framework/Versions/4/Headers -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtGui -I../../../QtSDK/Desktop/Qt/4.8.0/gcc/include -I. -I. -F/Users/helge/QtSDK/Desktop/Qt/4.8.0/gcc/lib -o diskimageatx.o diskimageatx.cpp
diskimageatx.cpp: In member function ‘virtual bool DiskImageAtx::readSector(quint16, QByteArray&)’:
diskimageatx.cpp:240: error: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
../../../QtSDK/Desktop/Qt/4.8.0/gcc/include/QtCore/qbytearray.h:475: note: candidate 1: bool QByteRef::operator==(char) const
diskimageatx.cpp:240: note: candidate 2: operator==(int, int) <built-in>
make: *** [diskimageatx.o] Error 1
Edited by atarixle, Sun Jul 29, 2012 9:54 AM.
#23 JAC! OFFLINE
JAC!
  • 1,690 posts
  • Always looking for GFX and MSX for my demos
Posted Sat Jul 6, 2013 5:48 AM
Now that's what I call I cool error message :-)
#24 freetz OFFLINE
freetz
    Chopper Commander
  • 241 posts
Posted Mon May 26, 2014 8:59 AM
I had troubles compiling AspeQt on my Mac, too, lots of libraries missing or no longer supported with Mac OS Mavericks (stropts.h, termio.h, linux/serial.h, among probably others). Then I found this site: http://optixx.org/20... my workaround:
1. Download said app from here: http://cl.ly/0c420q0g2Z1m
2. Install Qt 5.2.1 (not any other version) from http://download.qt-p...installers/1.6/ (only the clang packet is necessary to select)
3. Switch to user root on the shell and create the necessary directory:
mkdir -p /Users/david/Devel/tech
4. Then make a symbolical link to your Qt-installation (adjust the first part to your individual setup accordingly):
ln -s /Users/frederik/Qt/ /Users/david/Devel/tech/qt
Afterwards launch the downloaded app, it should now work without the startup error. I'm away from home at the moment, so I cannot test whether the actual hardware connection works, but at least it gives me an error that it cannot open the serial port (which is not present on my Mac at work).
Hope this helps to get this program running on other Macs as well - and hope even more that the changes that guy made make it to the mainstream AspeQt code :)...
#25 atari8warez OFFLINE
atari8warez
  • 2,724 posts
Posted Mon May 26, 2014 4:04 PM
They did indeed, I have implemented his changes into the mainstream code and the source will be available tonight through Sourceforge
