Gury Posted August 18, 2012 Share Posted August 18, 2012 http://www.virtualdub.org/altirra.html 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 18, 2012 Share Posted August 18, 2012 Direct link to binary.. http://www.virtualdub.org/beta/Altirra-2.20-test1.zip Quote Link to comment Share on other sites More sharing options...
ACML Posted August 18, 2012 Share Posted August 18, 2012 I noticed under the change notes for Altirra 2.1 that is supports the 1200XL. What exectly does that mean? I can run the 1200XL operating system using OTHEROS.ROM. What is the filename it is looking for when you select 1200XL firmware? Quote Link to comment Share on other sites More sharing options...
fibrewire Posted August 18, 2012 Share Posted August 18, 2012 Sweet! Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 18, 2012 Share Posted August 18, 2012 To run the 1200 you need to go to firmware and point to one of the two bios roms for it in System/firmware/rom images.. After that just set it to 1200 in System/Hardware mode and there you are.. Quote Link to comment Share on other sites More sharing options...
MaPa Posted August 18, 2012 Share Posted August 18, 2012 I think Altirra 2.1 has some timing issues. At least it behaves slightly different from version 2.0. See attached screenshot from intro Atallax. The color split was not there in previous versions, and I don't think it's there on real HW. Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 19, 2012 Share Posted August 19, 2012 Thanks, I've queued a fix. This was an odd case that allowed ANTIC to read one byte at the beginning of the scanline before it had been fetched. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 20, 2012 Share Posted August 20, 2012 Beta 2 not happy in portable mode (crashdumps)...Thanks to Breaker for spotting this.. Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 20, 2012 Share Posted August 20, 2012 I'm normally a "real-hardware" guy, but because of my interest in SlightSid, I've been using Altirra 2.10. Question/comment -- the graphics 0 (Dos) screen text looks "fuzzy." Do I have something amiss in the settings or? -Larry Quote Link to comment Share on other sites More sharing options...
bfollett Posted August 20, 2012 Share Posted August 20, 2012 Under the View menu, change the filter mode. I think "Sharp Bilinear" looks good if you want sharper text but I think "Point" is the sharpest. No display back in the day was ever that sharp. Quote Link to comment Share on other sites More sharing options...
+Larry Posted August 20, 2012 Share Posted August 20, 2012 Yes, "Point" helps significantly -- nice and clear. Thanks! -Larry Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 20, 2012 Share Posted August 20, 2012 Is there any way to emulate U1MB in Altirra 2.1 yet? -- didn't see an option for it in the menu. If not, is support planned for the future. Thanks. Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 21, 2012 Share Posted August 21, 2012 I have a fix for the portable mode crash -- it's related to the addition of the MyIDE II ROM -- but I can't push it yet because my dev tree is unstable. No U1MB support yet. Haven't looked into what it would take. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 21, 2012 Share Posted August 21, 2012 ok, thank you Avery. Quote Link to comment Share on other sites More sharing options...
atarixle Posted August 21, 2012 Share Posted August 21, 2012 How can I let Altirra hold the additional memory (a.k.a. the RAM-Disk) when rebooting with Shift-F5? I'm programming a lot on Altirra as my space is limited and I don't have a real Atari set up for programming. My GUI is using the behavior a lot, that the RAM-Disk remains untouched when Booting. (I also have an Atari with buffered RAM-Disk ... is there a way to emulate that?) Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 21, 2012 Share Posted August 21, 2012 I have a fix for the portable mode crash -- it's related to the addition of the MyIDE II ROM -- but I can't push it yet because my dev tree is unstable. No problem, we just wanted to make sure you knew about it.... Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 22, 2012 Share Posted August 22, 2012 How can I let Altirra hold the additional memory (a.k.a. the RAM-Disk) when rebooting with Shift-F5? I'm programming a lot on Altirra as my space is limited and I don't have a real Atari set up for programming. My GUI is using the behavior a lot, that the RAM-Disk remains untouched when Booting. (I also have an Atari with buffered RAM-Disk ... is there a way to emulate that?) Does your Atari actually have a battery backed up RAM disk? Shift+F5 is cold reset in Altirra, so it's supposed to simulate what you get when powering up an Atari after leaving it off for a while. This includes all RAM data going bye-bye. Quote Link to comment Share on other sites More sharing options...
carmel_andrews Posted August 22, 2012 Share Posted August 22, 2012 Phaeron, do you have the link to drac o/s, since i recall your emu supports 65816 mode and i wouldn't mind having a looksie at this o/s Quote Link to comment Share on other sites More sharing options...
atarixle Posted August 22, 2012 Share Posted August 22, 2012 (edited) How can I let Altirra hold the additional memory (a.k.a. the RAM-Disk) when rebooting with Shift-F5? I'm programming a lot on Altirra as my space is limited and I don't have a real Atari set up for programming. My GUI is using the behavior a lot, that the RAM-Disk remains untouched when Booting. (I also have an Atari with buffered RAM-Disk ... is there a way to emulate that?) Does your Atari actually have a battery backed up RAM disk? Shift+F5 is cold reset in Altirra, so it's supposed to simulate what you get when powering up an Atari after leaving it off for a while. This includes all RAM data going bye-bye. My current system is buffering the memory of the additional RAM. Actually, just rebooting the Atari (cold reset) keeps the RAM-data too, even without a buffered RAM-Disk and my GUI makes a lot of use of this behaviour. Edited August 22, 2012 by atarixle Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 22, 2012 Share Posted August 22, 2012 I think a cold boot option which doesn't clear any Ram (except what the OS does of course) would be a worthwhile modification, e.g. CTRL-F5 or similar. Quickest way I can think of to coldstart without Ram clear would be "E 244 1" in the debugger, then hit Reset. I'd assume that any of the config changes that cause a coldstart would also clear all Ram. Quote Link to comment Share on other sites More sharing options...
+JAC! Posted August 22, 2012 Share Posted August 22, 2012 (edited) I'd find it straighforward, if the extended RAM remained intact upon coldstart like on the real machine. You can "switch Altirra off" via ALT-F4 to lose its content, so it's even a perfect emulation then :-) Edited August 22, 2012 by JAC! Quote Link to comment Share on other sites More sharing options...
+JAC! Posted August 22, 2012 Share Posted August 22, 2012 From the docs: There is also a bug in MyDOS that prevents wildcarded copies from working when using H: as the source: MyDOS passes the wrong flags when enumerating files from non-disk devices, causing the copy to fail. Specifically, it attempts to read a directory listing using an AUX1 mode of $04 (open file) instead of $06 (open directory). I really suffer from this because I use H: a low. Do you have more infos here, so maybe I could patch MyDos. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 22, 2012 Share Posted August 22, 2012 (edited) From the docs: There is also a bug in MyDOS that prevents wildcarded copies from working when using H: as the source: MyDOS passes the wrong flags when enumerating files from non-disk devices, causing the copy to fail. Specifically, it attempts to read a directory listing using an AUX1 mode of $04 (open file) instead of $06 (open directory). I really suffer from this because I use H: a low. Do you have more infos here, so maybe I could patch MyDos. I did a MyDOS patch a while ago for Bob Wooley (specifically to eliminate indexed address wraparound for the benefit of the 65816). If I can dig out the sources I was using to write the patch I might be able to fix this issue as well. EDIT: Looks like it's this: ; C. COPY FILES ; DUPFIL = * CPYFIL .BYTE "File source, destination?",$9B,0 LDA #$20 ; space STA PAR3+2 ; DEFINE CHAR 3 OF DEVICE NAME LDA #$9B STA CPYTYP JSR GETFN ; GET SOURCE FILE NAME LDA # >DUPEND STA BUFAD+1 LDA # <DUPEND STA BUFAD LDA MEMTOP SEC SBC # <DUPEND STA BUFLEN LDA MEMTOP+1 SBC # >DUPEND STA BUFLEN+1 JSR DEFPAR LDA DELIM BMI SFNAME JSR GETFN2 LDA #0 SFNAME STA SWPFLG ASL WARMST LDA FNPTR+1 STA ICBAL+1+$20 LDA FNPTR STA ICBAL+$20 LDA PAR ; DISK DEVICE? CMP #'D BNE SGCOPY LDA # <PAR LDY # >PAR JSR DBUF10 LDA #'? LDY #11 Note the check for 'D' and the branch to SGCOPY towards the end of the snippet. This is in the MDUP2 source file (MyDOS 4.50). The patch will have to preserve the existing behaviour of copy from editor, etc. Edited August 22, 2012 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted August 22, 2012 Share Posted August 22, 2012 (edited) Phaeron, do you have the link to drac o/s, since i recall your emu supports 65816 mode and i wouldn't mind having a looksie at this o/s I presume you mean this.. http://drac030.krap....os-15082008.arc For Arcs I use http://www.izarc.org/download.html Edited August 22, 2012 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 23, 2012 Share Posted August 23, 2012 Yup, that D: check is the offender. I nuked it with MyDOS 4.50, and wildcard copies from H: started working. I guess instead of checking whether there were wildcards in the filespec, they just always did a directory scan for D: and then assumed a single file copy for CIO devices. Altirra can mount ARC files in its Disk Explorer, from which you can just drag out the files. I put this in because I was tired of having to boot into SDX in order to extract files off an ARC on a disk image and then reboot into another DOS to get the files off that into H:. 1 Quote Link to comment Share on other sites More sharing options...
