wannabeteacher85 Posted September 12, 2012 Share Posted September 12, 2012 Had this atari for a while and always worked fine. Was playing the other day, turned off, came back later. Now it will not turn on. Flipped power switch and nothing. Any ideas? Quote Link to comment Share on other sites More sharing options...
feather Posted September 12, 2012 Share Posted September 12, 2012 Check the power supply. Quote Link to comment Share on other sites More sharing options...
john-m Posted September 14, 2012 Share Posted September 14, 2012 When you say nothing, do you have the power led light up? Do you have another power supply you can try? Also, you might want to check the power supply pins with a volt/ohm meter set to volts. What type of power supply are you using? You can give the number on it to help us determine what type it is. Quote Link to comment Share on other sites More sharing options...
