flashjazzcat Posted December 30, 2012 Share Posted December 30, 2012 Here's an SDX test driver which supports hot-swapping: myide2_test01.zip If the driver detects a media change, it automatically resets the card and reads the partition table before carrying out the original SIO request. I came unstuck at the next stage, however: The SDX ROM for MyIDE 2 is only 128KB long, and so there's only 8KB of space left in the user area - enough for the soft driver and CONFIG.SYS. Attempts to put SDX on the MyIDE 2 cart failed completely: the AtariMax Cart Studio software naturally expects a 512KB ROM image, and the SDX ROM is only 128KB. Is there a build of SDX which doesn't require the MyBIOS boot screen process? Anyway: there's the driver. I can't get things configured as I want them at the moment, but hopefully the driver is useful. 1 Quote Link to comment Share on other sites More sharing options...
Louis Posted December 30, 2012 Share Posted December 30, 2012 I'm really a newbie at making a config.sys file. Using the SDXImageUser I made a new ROM. Made the Config.sys look like this: USE NONE DEVICE SPARTA BANKED DEVICE SIO /A DEVICE ATARIDOS DEVICE JIFFY DEVICE MYIDE2.SYS Replaced this ROM with the ROM on the TEST-2.mcw workbook. Programmed the MyIDE-2. All doing well. Except when booting SDX. I get the error Config Error (179): DEVICE MYIDE2.SYS Any ideas? Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted December 30, 2012 Share Posted December 30, 2012 Anyway: there's the driver. I can't get things configured as I want them at the moment, but hopefully the driver is useful. Excellent now working ok and consistent between reboots and changing machines. Quote Link to comment Share on other sites More sharing options...
Louis Posted December 30, 2012 Share Posted December 30, 2012 In the meantime... I changed by SDX-ROM on the U1MB. Add MYIDE2.SYS and changed the line in the config. Placed the cartridge in the slot. Boot with OPTION held!! U1MB booted right to SDX, and your driver was nicely loaded. Some CF-cards I initialized with the IDE+ device were recognized. So... the driver works. Hot-swapping is also working. The FDISK however, did not respond to it. I had to exit FDISK (2.5beta), open a drive (failed because of empty CF-card) and then FDISK recognized the CF. No a major problem. Now, how to get it working with the Flash-portion of the MYIDE2 ? 1 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted December 30, 2012 Share Posted December 30, 2012 In the meantime... I changed by SDX-ROM on the U1MB. Add MYIDE2.SYS and changed the line in the config. Placed the cartridge in the slot. Boot with OPTION held!! U1MB booted right to SDX, and your driver was nicely loaded. Excellent... this was going to be my next test for MyIDE II on my Ultimate set up. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted December 31, 2012 Share Posted December 31, 2012 The FDISK however, did not respond to it. I had to exit FDISK (2.5beta), open a drive (failed because of empty CF-card) and then FDISK recognized the CF. No a major problem. I have to say I've been hampered a bit in testing by FDISK playing up. RWCRC completed a faultless run on a 130XE, but FDISK was sometimes getting transfer errors when reading the partition table. The same FDISK works with SIDE, so I have to put this down to hardware issues - perhaps different CF cards will be more reliable. The machine in question has a lot of upgrades in it, which might have thrown things off a bit. What I want to know is how to flash SDX to this cartridge so it boots without holding down any keys. SDX for MyIDE 2 is supposed to run out of the first 16 banks, but it locks up - so I'm assuming the MyIDE 2 doesn't set the flash ROM bank register to 0 at coldstart? Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 1, 2013 Share Posted January 1, 2013 I have to say I've been hampered a bit in testing by FDISK playing up. RWCRC completed a faultless run on a 130XE, but FDISK was sometimes getting transfer errors when reading the partition table. The same FDISK works with SIDE, so I have to put this down to hardware issues - perhaps different CF cards will be more reliable. The machine in question has a lot of upgrades in it, which might have thrown things off a bit. What I want to know is how to flash SDX to this cartridge so it boots without holding down any keys. SDX for MyIDE 2 is supposed to run out of the first 16 banks, but it locks up - so I'm assuming the MyIDE 2 doesn't set the flash ROM bank register to 0 at coldstart? Try this workbook: SDXBOOTNOW.ZIP Quote Link to comment Share on other sites More sharing options...
classics Posted January 1, 2013 Share Posted January 1, 2013 I have to say I've been hampered a bit in testing by FDISK playing up. RWCRC completed a faultless run on a 130XE, but FDISK was sometimes getting transfer errors when reading the partition table. The same FDISK works with SIDE, so I have to put this down to hardware issues - perhaps different CF cards will be more reliable. The machine in question has a lot of upgrades in it, which might have thrown things off a bit. Program the shipping workbook on the cartridge and use the diagnostic program to do the read sector/write sector test. If there are no failures reading or writing to the card with the routines there, its more likely a problem with the implementation of the CF read/write code than a hardware problem. The diagnostic program pretty much uses the example routines that were provided for low level CF access. What I want to know is how to flash SDX to this cartridge so it boots without holding down any keys. SDX for MyIDE 2 is supposed to run out of the first 16 banks, but it locks up - so I'm assuming the MyIDE 2 doesn't set the flash ROM bank register to 0 at coldstart? The SDX image I have here was provided by Trub and was designed to run from ram on the cartridge. It works for me when loaded from the menu using Sijmen's ROM loader, or when loaded directly via the FAT32 loader. I'm just guessing here, but I'd suspect if it works fine in RAM but crashes when flashed to ROM, the program itself (SDX) is programming the memory mode register to RAM mode for the 'left cartridge' and pulling the rug out from under itself as its running, since it expect itself to be in the RAM banks, not the flash banks. so I'm assuming the MyIDE 2 doesn't set the flash ROM bank register to 0 at coldstart? The default is flash for left cartridge, page zero. These default should be listed in the hardware text document I posted and I believe they are accurate. If you find any errors please send me a message and I will update it, or fix the core so it is consistant with those values. Steve Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 2, 2013 Share Posted January 2, 2013 (edited) I have a SDX-bootpartition on the MyBIOS with Utilities, CONFIG and AUTOEXEC. That runs fine, there is no need to put all in flash when you have a harddrive The program BOOT-SDX is free, I'll zip and upload it tomorrow. It searches for the SDX string in flash and copies the 128k ROM to first 128k SRAM. Set SRAM to ReadOnly, select bank-0, powersup the CF and reboots. MyBIOS treads the first 128k of SRAM as protected area to run cartridge-images from. Larger versions of SDX are possible of course, need to contact Trub about this. All is done this way to be compatible with the ATARIMAX studio-design Later! Sijmen. Edited January 2, 2013 by mr-atari Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 2, 2013 Share Posted January 2, 2013 If there are no failures reading or writing to the card with the routines there, its more likely a problem with the implementation of the CF read/write code than a hardware problem. The diagnostic program pretty much uses the example routines that were provided for low level CF access. Funny thing is, RWCRC (which completes without errors) is using exact same R/W routines as FDISK is calling. In any case, I've seen weird behaviour like this with other interfaces, so maybe there's an intermittent bug in the application. The SDX image I have here was provided by Trub and was designed to run from ram on the cartridge. It works for me when loaded from the menu using Sijmen's ROM loader, or when loaded directly via the FAT32 loader. I'm just guessing here, but I'd suspect if it works fine in RAM but crashes when flashed to ROM, the program itself (SDX) is programming the memory mode register to RAM mode for the 'left cartridge' and pulling the rug out from under itself as its running, since it expect itself to be in the RAM banks, not the flash banks. Thanks for the explanation Steve. It seems the provided SDX build is completely unsuitable for what I had in mind. I've emailed KMK and Trub about it. The default is flash for left cartridge, page zero. These default should be listed in the hardware text document I posted and I believe they are accurate. If you find any errors please send me a message and I will update it, or fix the core so it is consistant with those values. Thanks - will do. Better get back to some hardware jobs in the meantime - I just couldn't resist playing with this cart for a few hours. Larger versions of SDX are possible of course, need to contact Trub about this. All is done this way to be compatible with the ATARIMAX studio-design Right, I think I understand now. A build of SDX which simply runs in the flash ROM and (optionally) uses the rest of the ROM space for CAR: would be rather useful for SDX fans. The on-board RAM could then be put to different uses. It's all about flexibility... Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 3, 2013 Share Posted January 3, 2013 I asked Trub for larger SDX versions today. Since ATARIMAX has the option to load .rom files, I'm going to drop the (temporarily born out of need) BOOT-SDX. Users can load SDX with the loader now, theoretical upto 512k images. I'll include your MYIDE2.SYS in the new upload. To answer your question about SDX-only: You can not flash the 512k and put the SDX in the first 128/256k. Simply because the SDX-build uses SRAM in RO mode to select banks, not flashROM. Can SDX use BANKED refered to the SRAM on the cartridge? Blended in at $8000 size $2000 (8k) this would be a powerful update to reduce stock memory-usage. You could configure 256k for SDX run from SRAM and use the other 256k for other uses. Just take care not to use SRAM needed for the MyBIOS. (I'm going to change that to the last 1.25k of the SRAM, instead of the 1.25k directly after the currently 128k reserved for rom-images run from SRAM). Flexibility is all given by the SDX-guys, I only ask Later! Sijmen. Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 3, 2013 Share Posted January 3, 2013 Version #4. -Found a little bug in percom-reply from D8: SRAM RAMDISK. Did only work if the current MyIDE-partition was SD. -Added latest ATARIMAX fat32-loader. -Removed BOOT-SDX, you can load the SDX.ROM from FAT32 now. http://www.atarimax.com/flashcart/forum/viewtopic.php?p=7148#p7148 Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 3, 2013 Share Posted January 3, 2013 Just got SDX 4.46 / 256k for MyIDE-II from trub. Will play with it tomorrow and release if it seems to work. Bundled with MYIDE.SYS and MYIDE2.SYS Need to change the D8: SRAM RAMDISK driver to coop with "only" 254.75k ram left Also working on close to 100% OSB-compatibility, almost got it working. Added 8k/16k-paged rom support from SRAM in RO upto 256k. -Nice- Quote Link to comment Share on other sites More sharing options...
Louis Posted January 5, 2013 Share Posted January 5, 2013 Booting SDX from the Fat32 Loader is a very nice feature. Most of all if you have to test several SDX versions. It works really well. Also got MyBIOS working together with U1MB SDX and MyIDE2.sys driver. So now I finally can copy files from one place to another. 1 Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 6, 2013 Share Posted January 6, 2013 (edited) SDX 4.46 for MyIDE-II can now be downloaded from the ATARIMAX-forum. The SDX-package. [updated 5-jan-2013] Simply put the .ROM file in your FAT32-area and load it with the ATARIMAX FAT32-loader. This is 3rd-party software, please consult the SDX-homepage and manual. You need to modify the original SDX-image to your needs. MyIDE.SYS and MYIDE2.SYS is 3rd party software from Jonathan Halliday. http://www.atarimax....hp?p=6958#p6958 Edited January 6, 2013 by mr-atari Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 6, 2013 Share Posted January 6, 2013 (edited) Version #5 -Call this version "a" 20130106 -Added ATARIMAX FAT32-loader (R2/F2), configurable KEYHOLE bytes (see MyBIOS manual) -Added full OSB-support (R2/F2). -Added SIC! cartridge support (R2). -Fixed some minor bugs. http://www.atarimax....hp?p=7157#p7157 Edited January 6, 2013 by mr-atari Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 7, 2013 Share Posted January 7, 2013 Version #5(b) -added latest ATARIMAX FAT32-loader. -changed the workbook font (Thanks to my lovely wife). I would call this a final version http://www.atarimax.com/flashcart/forum/viewtopic.php?p=7161#p7161 Quote Link to comment Share on other sites More sharing options...
Louis Posted January 7, 2013 Share Posted January 7, 2013 Great work Sijmen! 1 Quote Link to comment Share on other sites More sharing options...
AtariMagic! Posted January 8, 2013 Share Posted January 8, 2013 (edited) I have to get one! Edited January 8, 2013 by AtariMagic! Quote Link to comment Share on other sites More sharing options...
+Larry Posted January 9, 2013 Share Posted January 9, 2013 I don't think this has been announced, and it is quite useful, especially for new users and those unfamiliar with the FAT32 portion of the new MyIDE-II. Steve posted a new video showing how to set up a MyIDE-II card for both the MyBios portion and the FAT32. See it at: http://www.atarimax....php?f=17&t=1333 -Larry Quote Link to comment Share on other sites More sharing options...
FULS Posted January 10, 2013 Share Posted January 10, 2013 Just ordered my second Atarimax MyIDE 2. RED one this time. I love this product. So easy to use and powerful. Great company and great support. Thanks for all the software updates, Doug 1 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 10, 2013 Share Posted January 10, 2013 Excellent... this was going to be my next test for MyIDE II on my Ultimate set up. I didn't modify my sdx446 rom 'config.sys' but I did change my Autoexec.bat file loaded from D1:. Where I also loaded the myide2.sys driver to drive D1: SET ED=20 SET DAYTIME=1 SET MAXDRV=K: SET PROMPT=$L$P\ SET CAR=K:CAR.SAV SET MANPATH=D:MAN SET PAGER=LESS;/C;% SET BASIC=K:BASIC.SAV SET PATH=CAR:;:;H:;C:SYS;C:SDOS POKE $2C8,$94 POKE $2FC,$C DATE /T if NOT $boot C:> a:>myide2.sys else ECHO Lost in Limbo. fi So when the boot code doesn't return C:> the autoexec.bat will run the myide2.sys file donated by 'fjc' .. Thanks Jon.. 1 Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 10, 2013 Share Posted January 10, 2013 Update on MyBIOS firmware: Version #6. -Fixed garbage around image-number (image-menu) -Fixed some error handling when using device X: http://www.atarimax.com/flashcart/forum/viewtopic.php?p=7181#p7181 Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 11, 2013 Share Posted January 11, 2013 Update for ATARIMAX MyIDE-I Version #3 -Added full OSB support -Implemented some MyIDE-II code Compiled all three possible setup situations: ROM-versions. For all types of MyIDE, supports FLASH-content of MyIDE-I and MyIDE-II This is a replacement OS for inside your atari. Use SETUP to install MENU's and SIDE on your IDE-device. (Hold SELECT in the bootscreen, then press I to disable IDE) DISK-versions. For all types of MyIDE, supports FLASH-content of MyIDE-I and MyIDE-II This is a MyBIOS loaded from IDE that runs in RAM. Use SETUP to install MyBIOS, MENU's and SIDE on your IDE-device. (Hold SELECT in the bootscreen, then press I to disable IDE) Use LOAD to start your setup. Flash-version. For all types of MyIDE, supports FLASH-content of MyIDE-I and MyIDE-II But special build for the ATARIMAX 1mb + IDE cartridge. R1 is a replacement OS for inside your atari. F1 is a packed BIOS to be used with your ATARIMAX STUDIO software. All MENUs are loaded from FLASH. http://www.atarimax.com/flashcart/forum/viewtopic.php?p=7201#p7201 Quote Link to comment Share on other sites More sharing options...
Greg2600 Posted January 11, 2013 Share Posted January 11, 2013 I've been waiting for this forever, how did I miss this thread? So this will work on 8-bit xl/xe without any hardware mod? 1 Quote Link to comment Share on other sites More sharing options...
