atari800 H1: sub directory access
atari 800 dosxl spartados H1: directory
5 replies to this topic
#1 eed002 OFFLINE
eed002
    Space Invader
  • 18 posts
Posted Sun Nov 4, 2012 9:30 PM
Hi,
I am using the atari800 emulator on my Ubuntu machine. I own several 800's and I am an old 8biter.
In the emulator I am trying to access subdirectories on H1:.
I have tried dosxl and spartados. Has anyone gotten this to work? I have searched the forms and cant find anything useful.
I can access the main H1: directory, but when I try to access the subdirectory, I get a write protected error.
I also can not CWD to the location I want. It seems that the H1: access is limited to one level.
Any help is appreciated.
Thanks,
Edward
#2 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
  • What is your Alternate Reality?
Posted Mon Nov 5, 2012 1:32 PM
I'm not an emulator user but I guess it's just that. Access is limited to one level.
#3 phaeron OFFLINE
phaeron
  • 2,672 posts
Posted Mon Nov 5, 2012 3:05 PM
Strange, subdirectory access works for me with Atari800 2.2.0 on Win32 using H1:FOO> syntax, at least.
#4 rdea6 OFFLINE
rdea6
  • 2,777 posts
Posted Mon Nov 5, 2012 3:11 PM
http://sourceforge.n...atari800/2.2.1/
The most current version works also with MyDOS and SpartaDos 33x.
And SDX 445 under basic at least.
Edited by rdea6, Mon Nov 5, 2012 3:13 PM.
#5 a8isa1 OFFLINE
a8isa1
  • 1,545 posts
Posted Mon Nov 5, 2012 4:01 PM
Hi,
Thanks,
Edward
Subdirectories are not limited to one level.
I'm not sure what is the cause of your problem but here are few items to consider.
- If the host system allows case sensitivity for filenames then it is usually in effect in Atari800
- copying files from DOS menu or CLI to H: drive using wildcards appears to be NOT PERMITTED.
- Atari800 has it's own parsing of long filenames. Filenames longer than 8 characters will show up as 8 characters '+' 3 characters. In a directory listing the '+' is returned instead of a period.
- If you are attempting to list a directory then the DOS you are a using may be doing it's own parsing thus adding it's own restrictions or quirks.
Here are some examples.
H: is implemented as an escape in Atari800. No DOS is needed in the emulated Atari to access H: drives
DOS 2.0D.
Note that this DOS in itself does not support subdirectories yet you can sort of access them.
However, see what happens when the path is longer.
The situation gets better with SpartaDOS (3.2x).
Notice that that I'm typing the subdirectory names in upper case yet it still works. [EDIT - obviously that's not true. Sorry]
Making H1: focal, creating a subdirectory, and nested subdirectories are all allowed.
Oops. I see others have posted replies while I was typing and testing :D
BTW, I'm using Atari800 2.1.0 which is a little out of date.
Edited by a8isa1, Mon Nov 5, 2012 4:07 PM.
#6 eed002 OFFLINE
eed002
    Space Invader
  • 18 posts
Posted Tue Nov 6, 2012 1:29 AM
Hi,
Many thanks. After I saw that it works, I figured something was wrong with my dos version. I was using ftesdtka.dcm (which is 3.2 with the toolkit). When I used ftesd32f.dcm image it was working.
Thanks all for the help.
-Edward
Also tagged with one or more of these keywords: atari 800, dosxl, spartados, H1:, directory
