D.K. VCS
872 replies to this topic
#26 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Tue Dec 18, 2012 5:06 PM
Impressive!
Thank you!
Scrolling the levels is a slick idea, though it does feel cramped due to how far down BONUS ends up combined with the early termination of the screen kernel (it looks like the visible portion of the screen is only 170 scanlines).
Yes, the scrolling window is only 3 floors (girder + corridor) plus 1 girder high (3*32+8 = 104 lines). I'm currently out of resources to add another floor, but will revisit it when the rest of the game is there.
- RAM: only 2 bytes left in ZP. I can probably move the sound variables to SARA RAM, but I first need to have the enemy AI done before I know how much space I would have for that.
- ROM: another floor will need another subkernel in the display bank, which will limit the space available for graphics. I will see that when the levels are done.
- Cycles: The enemy AI might not fit into vblank + overscan and may need to be in the black area. But not all enemies move every frame, so maybe that can be timescliced.
Not impossible, but better not hold your breath for it :)
#27 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Tue Dec 18, 2012 5:24 PM
Do keep working on this and feel free to take any inspiration with what I did so far in batari Basic - graphic or sound wise!
Mine looks like DK, is starting to sound like DK, but I don't know if I know enough or know if I have enough space to do game logic yet.
Thanks! The level design you have is awesome, particular the elevator level.
I do not yet want to release the complete source at this point, but if you are not scared of 6502 assembly you can take a look at my game logic. Mario is controlled by a state machine which can be found at line 1020. I think there recently even was a tutorial about state machines in the programming forums.
Edited by Joe Musashi, Tue Dec 18, 2012 5:42 PM.
#28 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Tue Dec 18, 2012 5:40 PM
This is impressive Mr. Musashi! Please finish this game!
I'll post a mockup of others stages that I didn't finish for the demo, perhaps it can be used as inspiration, I don't really think on 2600 limitations to make them, that's why the laddes are white :
(The first screen need an inclinated girders, the elevator screen is too much optimistic for 2600 hardware, the pie factory and blue-ish screen is very doable IMO).
Thank you! Your work is a great inspiration. The first level will probably look very much like your mockup. I can't do tilted girders, but the oil barrel will definitely be there.
#29 xybot67 OFFLINE
xybot67
    Moonsweeper
  • 309 posts
Posted Wed Dec 19, 2012 7:47 PM
Wow, this is amazing! It's more than I ever thought possible. Keep up the great work, I truly hope you complete it. I can't wait to send you my money!
#30 Kosmic Stardust OFFLINE
Kosmic Stardust
    Cyborg Bounty Hunter
  • 18,461 posts
  • Alita Jean
Posted Thu Dec 20, 2012 12:45 AM
I looked at your sprite sheet; they appear to be either the arcade or NES versions. The Atari VCS really isn't capable of multicolor sprites like this.
#31 KevinMos3 OFFLINE
KevinMos3
  • 1,609 posts
  • Founder of the Timothy Dalton as Bond fan club
Posted Thu Dec 20, 2012 5:58 AM
You should look again. ;)
The sprite sheet shows how it's done and the demo shows them in action.
#32 jrok OFFLINE
jrok
  • 1,155 posts
Posted Thu Dec 20, 2012 10:48 AM
The sprite sheet shows the individual 30hz flicker frames that creates the illusion of multiple colors on a line (and so does his demo binary, for that matter).
#33 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Thu Dec 20, 2012 4:14 PM
I try to base everything on the arcade version (dkong in MAME). The NES seems to be mostly pixel accurate but has fewer colors.
The sprite sheet above shows a number of different multi-color techniques.
  • Shown on the left is overlapping two colors. This gives you three colors per line that will have a similar tone.
  • In the middle it's alternating between two colors. This allows for arbitrary colors (half as bright with a black background), but you will have only two per line.
  • On the right is the most interesting method. This is eshu's player, missile, ball trick, which works without flickering.
Please note that Pauline and Mario are not flickering in the opening and ending sequences, and thanks to Omegamatrix' help I"ll get rid of the dot flicker as well.
So, under some conditions the VCS is capable of displaying multi-colored objects.
#34 Cortat G OFFLINE
Cortat G
    Dragonstomper
  • 776 posts
Posted Thu Dec 20, 2012 4:56 PM
This is amazing!
Posted ImagePosted Image
#35 Omegamatrix OFFLINE
Omegamatrix
  • 6,241 posts
Posted Thu Dec 20, 2012 9:53 PM
IMHO Joe I would make Mario and the Fireball out of just one color change per line. Even with the phosphor effect in Stella you see the ladder through Mario. He just looks like a faint ghost.
#36 almightytodd OFFLINE
almightytodd
    Dragonstomper
  • 845 posts
  • Infrequent Poster
Posted Thu Dec 20, 2012 11:06 PM
I'm astonished... ...words fail me. Just when I start thinking the VCS has been pushed as far as it can go, something like this comes out and blows me away all over again. Wow...
#37 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Sun Dec 23, 2012 9:47 AM
That's true, transparency is one of the annoying side effects of flicker. Another problem is that motion needs to be at 30Hz because otherwise the eye will not correctly fuse the images, which leads to even more ghosting.
I still prefer the multicolor approach as it is more consistent with the overall design. It would, however, be worth trying how it looks with a single color per line. I could probably put a #define in the source and compile an edition without Mario flicker for players who like that better.
#38 roland p OFFLINE
roland p
  • 2,455 posts
  • $23
Posted Sun Jan 6, 2013 5:33 AM
I like it!
Arcade graphics, good gameplay, sound and animation is spot-on. It looks almost like a finished game! :-) Keep up the good work!
#39 xybot67 OFFLINE
xybot67
    Moonsweeper
  • 309 posts
Posted Thu Jan 10, 2013 2:49 PM
Bump, any new development on this game?
#40 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Fri Jan 11, 2013 3:49 PM
Soon :grin:
#41 xybot67 OFFLINE
xybot67
    Moonsweeper
  • 309 posts
Posted Fri Jan 11, 2013 4:52 PM
Soon :grin:
Great news! Can't wait
#42 StephenJ OFFLINE
StephenJ
    Moonsweeper
  • 364 posts
Posted Fri Jan 11, 2013 5:29 PM
"...Can't wait..."
Same here!!
#43 PacManPlus OFFLINE
PacManPlus
  • 4,989 posts
  • Atari 7800 & NES Developer
This is too excellent. It's amazing what you are doing here. :)
#44 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Mon Jan 14, 2013 12:33 PM
Thanks Bob!
I'm probably going to play your latest Crystal Quest release after I've posted the next D.K. version :D
#45 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 311 posts
Posted Mon Jan 14, 2013 1:09 PM
Time for another update. I've now started working on the 25 m and 75 m stages.
These are the ones where I'll have to make the most compromises, be warned :)
This update includes the following changes:
  • Non-flickering title screen letters, courtesy of Omegamatrix.
  • We welcome new enemies: Oil Barrel, Wood Barrel, Cement/Pie, and Flame.
  • And an all new 25 m stage, including broken ladders and additional Kong graphics.
Spoiler
As usual it's playable but not really a game yet.
Have Fun!
#46 TrekMD OFFLINE
TrekMD
  • 4,031 posts
Posted Mon Jan 14, 2013 4:28 PM
I am speechless!
#47 xybot67 OFFLINE
xybot67
    Moonsweeper
  • 309 posts
Posted Mon Jan 14, 2013 4:43 PM
Wow, I couldn't wait to get home and try this! I was amazed! Keep up the great work.
#48 VGC1612 OFFLINE
VGC1612
    Chopper Commander
  • 198 posts
Posted Mon Jan 14, 2013 6:57 PM
Unbelievable!The sale will be when?
#49 sqoon OFFLINE
sqoon
  • 1,094 posts
Posted Mon Jan 14, 2013 7:09 PM
Looks excellent, but I am curious to know why the stage 1 screen is broken into two separate screens on your screen shots.
#50 Csonicgo OFFLINE
Csonicgo
  • 2,794 posts
  • OPL Goddess
Posted Mon Jan 14, 2013 9:36 PM
I can't believe I'm playing this. This is phenomenal!
