internal 16 bit 32K upgrade
41 replies to this topic
#26 mister35mm OFFLINE
mister35mm
    Star Raider
  • 80 posts
Posted Fri Feb 26, 2016 1:23 PM
I am trying to find a 16bit internal 32k that ACTUALLY works and, preferably using a PCB of some kind.
I don't mind a kit, infact, I'd prefer one. I am in London UK.
Stephen
#27 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Fri Feb 26, 2016 2:26 PM
The only recent mod with an available board keeps everything 8-bit (see the Hardware Project of the Quarter thread). Here's a link to a 16-bit mod--but it has no board. It is just a lot of wiring and chips. . .
#28 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 591 posts
Posted Tue Mar 22, 2016 6:17 AM
Like my modification, then. You can look here to find a few pictures of my system. Some are scanned color slides, hence the lower than normal today image quality.
#29 mister35mm OFFLINE
mister35mm
    Star Raider
  • 80 posts
Posted Sun Mar 27, 2016 4:47 AM
Has there been any prograss with this?
I have a few Ti-99/4a's that would benefit, especially as they'll be no more NanoPebs.
regards
#30 Tursi OFFLINE
Tursi
  • 5,572 posts
  • HarmlessLion
Posted Sun Mar 27, 2016 5:26 AM
The board linked to from post 27 works fine, and has the same performance as the NanoPeb. :)
#31 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 591 posts
Posted Mon Mar 28, 2016 2:07 AM
I can add that I have thought of, but never implemented, a further feature of my memory expansion. Since I already have the logic to enable and disable parts of the memory expansion by setting individual CRU bits, now decoded with base address 400H, I could add a secondary decoding scheme. If I included a four bit DIP switch, to select a number between zero and fifteen, I could make the 4000H-5FFFH RAM segment also answer when a CRU bit at 1X00H is set. Thus the memory in my expansion could work as a DSR in RAM too. That would make it easier to implement virtual cards in the machine, like a RAM disk or whatever.
As it is now, the RAM disk I have implemented, relies on having the DSR software on one of my other expansion cards in the box. That's a card I've built myself, which has RAM in the DSR space, to allow for all sorts of modifications at run time. But the internal expansion would of course be more convenient if that wasn't needed to implement a RAM disk or whatever. You could perhaps implement a printout spooler or something like that.
#32 xxx OFFLINE
xxx
    Star Raider
  • 53 posts
Posted Mon Feb 18, 2019 9:54 AM
is there an emulator that does this?
#33 Asmusr OFFLINE
Asmusr
  • 3,093 posts
Posted Mon Feb 18, 2019 10:09 AM
MAME and Win994a.
#34 FALCOR4 OFFLINE
FALCOR4
    Star Raider
  • 58 posts
Posted Wed Feb 20, 2019 12:49 PM
Here's a old 16/32K 16-bit daughter board sold back in 1985 by Radio Supply.  I'm posting the pic for those who may be interested in the history.  It had a 16k/32k switch attached to the wires you see that I removed and soldered it to 32k (the switch became flaky).
It did require you to unsolder the TMS9900 and remount it on the daughterboard.  A chore not for the faint hearted.  It doesn't appear that the motherboard has been modified by cutting traces; I see that the crystal is now mounted on the bottom of the motherboard and it has two wires on the top of the motherboard. But, they do not connect to the daughterboard.
Thanks to everyone for posting other mods.  I've been interested in them so this is educational for me.
I used this console back in the 80's because it would assemble quite a bit faster than a normal console. It cut my development time down which was helpful.  I never used it to play games so I wouldn't know how it reacted. Today, you can just use the PC for development; didn't have that back then (too bad!).
Attached File  Top Radio Supply 16_32K 16-bit memory board - 1985.jpg   1.73MB   1 downloads
Edited by FALCOR4, Fri Feb 22, 2019 3:57 PM.
#35 FALCOR4 OFFLINE
FALCOR4
    Star Raider
  • 58 posts
Posted Thu Feb 21, 2019 6:14 PM
Ok, I realized that I was speeding a little bit when I said, ",,,it would assemble quite a bit faster than a normal console."  I added the WDS100 HD at about the same time so, between the 16-bit memory AND the HD things went quite a bit faster.  Opps :-)
#36 Ksarul OFFLINE
Ksarul
  • 5,212 posts
Posted Thu Feb 21, 2019 6:36 PM
That's a bit of hardware I've never seen before--so documenting it is a good thing!  Many thanks for identifying yet another item to add to my "hunt this down" list!  :)  :)  :)
#37 FALCOR4 OFFLINE
FALCOR4
    Star Raider
  • 58 posts
Posted Thu Feb 21, 2019 7:44 PM
Top Radio Supply
17885 Mt. Elliott
Detroit, Michigan 48212
My console is a beige non-v2.2 sent in as defective that, evidently, they repaired? Or, they bought repaired?  It came with just the lower motherboard shield soldered to the board (top shield omitted) and a large resistor in-line with the power input (inside the console) to the newer switching P/S which may have been standard on those units by that time.  There was a heat sink added to the 9918 and the 9904 does not have a heat sink. Looks like their board is a hand layout and not a computer layout.  Something in-the-day you might etch in a pan or your sink (not saying i ever did that!!!!).
Those are some details that come to mind.  It was a gift from Craig to me and my favorite console....
Doug
Attached File  20190221_174810.jpg   1.35MB   0 downloads
Edited by FALCOR4, Fri Feb 22, 2019 5:32 PM.
#38 Opry99er OFFLINE
Opry99er
  • 10,678 posts
Posted Thu Feb 21, 2019 9:09 PM
Ooooooooh..... love the MG badges!!!!!!! :D
#39 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 591 posts
Posted Tue Feb 26, 2019 4:09 AM
Ah, an HP 16C to brighten things up too! My copy of that calculator says Hello!
#40 Vorticon OFFLINE
Vorticon
  • 3,619 posts
Posted Tue Feb 26, 2019 6:02 AM
Swiss Micros? I have their HP41CX reproduction.
#41 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 591 posts
Posted Tue Feb 26, 2019 4:19 PM
Sorry, by "copy" I rather meant "instance". MIne is a genuine Hewlett Packard, acquired in 1983. It's now on its second set of batteries.
But my HP 15C is a modern re-run, which I bought a few years ago.
#42 dhe OFFLINE
dhe
    Space Invader
  • 24 posts
Posted Fri Mar 8, 2019 1:29 PM
We have the same desk!
In my closet is my console with the Top Radio Supply of Chicago mod - w00t daughter board technology.
Also, on my desk is my trusty HP 16C. I like it much better than TI's LCD Programmer, which always had double bounce key problems.
Thanks for the photo.
d.
