Ultimate 1Mb Upgrade
123 replies to this topic
#101 Eyvind Bernhardsen OFFLINE
Eyvind Bernhardsen
    Star Raider
  • 84 posts
Posted Fri Aug 19, 2016 11:34 AM
attachicon.gifUBIOS14MB.ROM
This is one of my older Pre Uflash and has the older menu.  Not sure of the PBI bios.  But you could test with Altirra [EMU] to verify..
Thanks! This is the the newest non-FJC ROM I've seen so far, according to the ROM Generator version numbers: BIOS 0.03, SIDE loader 1.20, PBI 1.1. The question is if I have the nerve to install it :)
I've tested it in Altirra, but the emulated U1MB has the v2 CPLD code so it won't tell me if this BIOS will kill my v1 U1MB.
#102 flashjazzcat ONLINE
flashjazzcat
  • 14,183 posts
Posted Fri Aug 19, 2016 12:11 PM
Presumably the revision and revision date for the main BIOS are heuristically generated (it contains neither, and the older, PBI-less main BIOS produces the same revision date as "0.03": 04/06/2012), but it is a late revision. Clearing out $D100-$D1BF doesn't appear to hang the machine, but I don't want to be the one to tell you to pull the trigger on it. :)
#103 phoenixdownita OFFLINE
phoenixdownita
  • 3,443 posts
Posted Fri Aug 19, 2016 9:58 PM
Pull the trigger, what's the worse that can happen?
That you need to buy a TL 866-CS/A and a PLCC adapter and a chip extractor and burn the flash via PC?
Been there than that ..... it's an extra 50/60US$ at most but you get to keep the programmer and the PLCC adapter and the chip extractor  :D
Annoying? yes ..... fun? that too!!!!
At a point I also thought to have had an earlier CPLD code (from L not C) and as suggested by Lotharek here it comes a Xilinx programmer and the Xilinx programming tools (all 14GB of them wtf) and the flywires to connect it and ..... I already had v2. In this second instance thankfully a friend lent me everything needed and I got to keep all of it (he was getting tired of FPGAs and gave away most of his stuff).
#104 Eyvind Bernhardsen OFFLINE
Eyvind Bernhardsen
    Star Raider
  • 84 posts
Posted Sat Aug 20, 2016 12:22 AM
I'm building up courage, don't rush me  :P
Baby steps: I flashed the XEGS OS into one of the slots. Now I have SELECT-key access to Missile Command again!
#105 Eyvind Bernhardsen OFFLINE
Eyvind Bernhardsen
    Star Raider
  • 84 posts
Posted Sat Aug 20, 2016 1:58 PM
I'm sure everybody is tired of hearing about my U1MB-flashing phobias, but here's the final update: I customised rdea6's ROM with the ROM Generator, then used uflash to install it...
...and it works. Anticlimactic, I know. The only (minor) problem is that I can't get the game slots to work, but SDX 4.48 and Altirra BASIC 1.51 are present and correct, as are all four OS ROMs.
Thanks to all for your help and support!
#106 flashjazzcat ONLINE
flashjazzcat
  • 14,183 posts
Posted Sat Aug 20, 2016 2:03 PM
You'll need to put the U1MB into XEGS mode (by jumpering the XEGS pins) as well as using the XEGS OS to use the game slots.
#107 Eyvind Bernhardsen OFFLINE
Eyvind Bernhardsen
    Star Raider
  • 84 posts
Posted Sat Aug 20, 2016 2:45 PM
It was already in XEGS mode, but I worked out what the problem is: it's still acting as if there is only one slot for BASIC and one for games, using what uflash calls BASIC slots 1 and 2, so every time I tried to start a game it ran BASIC rev C instead. Possibly due to the old CPLD code?
Ultimate Setup now lets me choose between BASICs and games, but changing the settings has no effect. It also has a couple of SIDE settings now, but I assume those won't work.
I worked around the problem by flashing Missile Command to the BASIC 2 slot, so I'm happy for the moment.
#108 flashjazzcat ONLINE
flashjazzcat
  • 14,183 posts
Posted Sat Aug 20, 2016 2:54 PM
Oh yes: I ran into that issue myself a while back on an v.2 Candle U1MB. Turns out there was a bug in the v.1 and v.2 CPLD code which prevented any but the first BASIC (and possibly XEGS game) slot from working. Caused me a fair bit of head-scratching until I tried an early Lotharek board and noticed the issue had been fixed, so I propagated the CPLD from that board to the other three machines.
Edited by flashjazzcat, Sat Aug 20, 2016 2:55 PM.
#109 Eyvind Bernhardsen OFFLINE
Eyvind Bernhardsen
    Star Raider
  • 84 posts
Posted Sat Aug 20, 2016 3:02 PM
Aargh. Which means that there are actually three CPLD code revisions, two of which are called "v2," and the v2 JED I had to scavenge from the Internets because it's no longer available from anywhere official is potentially not the good one?
...you wouldn't happen to still have that JED around, would you?
Also, I can't thank you enough for uflash. It really puts a friendly face on a potentially frightening process; my U1MB would still be running my original ROM if it wasn't for that.
#110 flashjazzcat ONLINE
flashjazzcat
  • 14,183 posts
Posted Sat Aug 20, 2016 3:24 PM
Just pulled this straight off my 1200XL's U1MB:
Attached File  U1MBv3_JED.zip   9.63KB   51 downloads
If it makes the process less intimidating and less prone to failure, then it's accomplished what I set out to do. The exercise was initially for my own benefit, since when developing the old PBI BIOS back in 2012 or so, I was updating just a small part of the ROM on real hardware several times a day and the cobbled-together, hard-coded tool I was using clearly wasn't a permanent solution. Since developing the new main BIOS and loader as well, I've been updating these sections of the ROM on four machines (five counting Incognito) countless times and the only time I had to resort to the USB programmer was when one of the old PLCC flash ROMs apparently wore out (replacing it fixed everything), or when some show-stopping Incognito bug emerged (since there's no way to test the Incognito BIOS in the emulator). The MADS target folder is mounted in RespeQt via SIO2PC and I can have the firmware on the target machine updated within a minute of assembling the code. The same folder is simultaneously mounted in Altirra and I even update the emulated U1MB using UFlash with F1 held down. :) There are probably more sophisticated ways of updating the emulator ROM using make tools as part of the assembly process, but since I require the firmware slot ROM for real hardware anyway, I stick with the usual procedures. I doubt I would have felt inclined to develop complete new firmware for U1MB and Incognito had this flashing tool not existed.
#111 Eyvind Bernhardsen OFFLINE
Eyvind Bernhardsen
    Star Raider
  • 84 posts
Posted Sat Aug 20, 2016 4:09 PM
Thank you! I can confirm that JED is different from the one I already had (lots of added PPMAPs, whatever they are :)). Now I'm really motivated to get that programmer working.
What I like most about uflash is the user interface: starting any process that takes time immediately provides a reward in that beautifully-rendered text mode progress bar, for example. First impressions are important.
Partial flashing is the killer feature, though; I wouldn't have dared replace the whole firmware if I hadn't successfully flashed an OS ROM earlier.
Sterling stuff.
#112 tjlazer OFFLINE
tjlazer
  • 2,132 posts
  • Retro Atari Addict
Posted Mon Mar 12, 2018 10:15 PM
I can use some help.  I finally installed my Ultimate 1MB and I believe I have the V1.  When it boots up I get QMeg OS.  Cannot seem to enter any setup menu.  I tried pressing HELP on powerup or reboot and it doesn't work.  I want to update everything to the latest firmware.  What all do I need to do?  I have an EPROM programmer, what chip type is the chip that needs to get programmed?  I assume I need to upgrade the JED on the board too?  Any help is appreciated!
Edited by tjlazer, Mon Mar 12, 2018 10:15 PM.
#113 Sugarland OFFLINE
Sugarland
    Chopper Commander
  • 202 posts
Posted Mon Mar 12, 2018 10:56 PM
You won't need an EPROM programmer it can be updated in software:
https://atari8.co.uk...e/ultimate-1mb/
After updating, hold help down while pressing RESET that will get you into the U1MB setup.
Edited by Sugarland, Mon Mar 12, 2018 11:22 PM.
#114 tjlazer OFFLINE
tjlazer
  • 2,132 posts
Posted Tue Mar 13, 2018 2:15 AM
Thanks, Turns out I have a bad Mylar, help doesn't work. Need to get a new Mylar, and it looks like I have a V2 so that's good!
Edited by tjlazer, Tue Mar 13, 2018 2:15 AM.
#115 Sugarland OFFLINE
Sugarland
    Chopper Commander
  • 202 posts
Posted Tue Mar 13, 2018 12:16 PM
Conductive paint can also fix it. Worked wonders with my XE mylar.
#116 kheller2 OFFLINE
kheller2
  • 1,303 posts
Posted Tue Mar 13, 2018 1:42 PM
I will remind people:
Note: Owners of Ultimate 1MB with the original v.1 CPLD code from Candle’s first run of boards must ensure that they update to the current JED prior to installing the new BIOS. Boards with the PBI feature (including all manufactured by Lotharek and those from Candle’s second run) will safely run the new BIOS without modification.
#117 tjlazer OFFLINE
tjlazer
  • 2,132 posts
Posted Tue Mar 13, 2018 2:51 PM
Yep I saw that, glad I have a V2! (Look at the back of board, look for a pic of a garbage bin with a X on it)
#118 phoenixdownita OFFLINE
phoenixdownita
  • 3,443 posts
Posted Tue Nov 13, 2018 1:04 AM
For posterity here's a direct link to Candle's v2 JED:
http://www.spiflash....imate1mb-v2.jed
I also attach it to this post.
Attached File  ultimate1mb-v2.jed   122.64KB   9 downloads
#119 flashjazzcat ONLINE
flashjazzcat
  • 14,183 posts
Posted Tue Nov 13, 2018 3:30 AM
V3 is the one to go for if you want secondary BASIC slots to work correctly:
Attached File  U1MBv3.zip   9.63KB   23 downloads
#120 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 550 posts
Posted Tue Nov 13, 2018 12:34 PM
Should I flash that V3 on a U1MB installed in a 1088XEL?
Someone should do a V4 to remove the XEGS slots and add them to the OS/BASIC slots for non XEGS users
Edited by Mr Robot, Tue Nov 13, 2018 12:35 PM.
#121 phoenixdownita OFFLINE
phoenixdownita
  • 3,443 posts
Posted Tue Nov 13, 2018 1:14 PM
FJC is THE developer for the U1MB BIOS in all incarnations, so when in doubt do as he says.
#122 SS ONLINE
SS
  • 6,239 posts
Posted Tue Nov 13, 2018 1:36 PM
I'm not all that interested in more BASIC or built-in game slots myself but a few more open OS slots would be brilliant.
#123 flashjazzcat ONLINE
flashjazzcat
  • 14,183 posts
Posted Tue Nov 13, 2018 1:46 PM
I think the most useful addition would be one or more emulated 16K OSS carts, but although I imagine more than one pair of eyes has seen the U1MB JED source code, my eyes are not among them.
#124 Kyle22 OFFLINE
Kyle22
  • 3,753 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Tue Nov 13, 2018 11:10 PM
Yes, my thoughts exactly. Built in OSS (or 2) would be awesome!
