0
Power Supply Question
2 replies to this topic
#1 TerryG OFFLINE
TerryG
    Combat Commando
  • 5 posts
Posted Thu Dec 20, 2012 10:52 AM
I recently dug out my old 2600 and decided to check the power supply with my multimeter before plugging it into the system.  When I checked the voltage I was getting somewhere around 13v, while the label on the power supply states it's only supposed to put out 9v.  Is this normal?
Thanks
#2 shadow460 OFFLINE
shadow460
    Gunslinger
  • 16,398 posts
  • *bink* Good Shot
Posted Thu Dec 20, 2012 1:18 PM
Yes. The rated voltage is a measure of what the power brick produces under load.
EDIT: To prolong the life of the power adapter, always plug it into the system before you plug it into the wall, and always unplug it from the wall before you unplug it from the system. That's due to the 1/8 inch mono plug they used on it.
Edited by shadow460, Thu Dec 20, 2012 1:19 PM.
#3 TerryG OFFLINE
TerryG
    Combat Commando
  • 5 posts
Posted Fri Dec 21, 2012 11:43 AM
Thanks for the tip, I really appreciate it.
