Transfer of .ATR images via APE or Prosystem
ape prosystem 1050 density atr image transfer
28 replies to this topic
#1 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Thu Dec 27, 2012 11:53 PM
Greetings,
I have been trying to copy some disk images in ATR format via the APE and Prosystem PC applications, via SIO2PC (USB) and Atari 1050 drive. I know the drive and interface work because I've successfully loaded programs from both into my 800XL. The problem is, when I try to transfer the disk image to real floppy, the copy fails - I believe this is because all of the ATR images I'm finding online are double density (180kb), and my stock 1050 disk drive is only designed to read/write single density.
Does this sound correct? And if so, is there any convenient way around this, aside from upgrading my 1050 to read/write double density?
I'd be content to just load files from the emulated drives available via APE and the SIO2PC interface, but the interface is on loan from a friend so I'd like to get some disks made before returning it.
Thanks in advance for any advice!
#2 Kylev OFFLINE
Kylev
    Chopper Commander
  • 152 posts
Posted Fri Dec 28, 2012 12:19 AM
mos6502,
The least expensive option for you would be to create 2 empty single density disk images and copy the contents of your double density disk to those images. Fill the first image and then put the remainder on to the second image. The single density images should copy successfully to real disks
This won't work for any commercial software images. They aren't formatted in standard DOS layout and must stay on their original density.
Hope this helps,
Russ
#3 russg OFFLINE
russg
  • 1,648 posts
Posted Fri Dec 28, 2012 9:52 AM
Greetings,
You can format a 5.25" floppy in your 1050 using SpartaDOS XINIT.COM or MyDOS or DOS 2/2.5 format. Then you can boot from APE in D1: and have the double density .ATR you want loaded, say at D4: on APE.
Your 1050 should be set as, say, D2:
Now you can copy individual files, or alphabet choices from D4: to D2: using the COPY command in SpartaDOS or MyDOS copy command, using wildcards.
SpartaDOS: "COPY D4:*.COM D2:" or "COPY D4:A*.* D2:" Using MyDOS you can also specify wildcards with the COPY command. You can also write DOS files from D1: to D2: with MyDOS/2.5. To make
a Sparta boot disk, COPY the *.DOS file to D2: then "BOOT D2:X32G.DOS" if that's the Sparta version you're using.
Edited by russg, Fri Dec 28, 2012 9:55 AM.
#4 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Fri Dec 28, 2012 10:29 AM
Thanks guys! I will try both methods. Are there any Atari DOS quick command references, and .atr disk image editors, that you'd recommend?
#5 rdea6 OFFLINE
rdea6
  • 2,817 posts
Posted Fri Dec 28, 2012 7:43 PM
Read this thread..
http://www.atariage....i/#entry2663528
#6 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Sat Dec 29, 2012 10:02 PM
Ok, so I'm having success creating single density (or "enhanced" since I'm using a 1050) .ATR images, moving files over from existing double density images into them, and copying these ATRs over to real floppy. Thanks for the link to the ATR editor info!
Now there are new problems...
1 - the disk images have several games on them, listed first when I view them in an ATR editor like makeATR. Then below that, there's a ton of garbled text. I don't know if these are necessary files or what.
2 - I copy just these files over to real floppy via SIO2PC/Prosystem using my newly created single density ATR file... and it works, but then when I boot up the Atari nothing loads. "BOOT ERROR".
3 - I tried again but included a DOS file (.DOS file from a SpartaDOS disk) thinking that perhaps it couldn't boot because it needs this, but that time I got "Error: No DOS".
For example's sake, I've tried this entire process with a games disk here: http://www.mushca.co...ndex.php?dl=001
I don't know anything about Atari DOS or what the computer needs to load files. Does it need to load some type of operating system from a disk like an early IBM PC to have any capability at all? Or does it have some built-in DOS capabilities like a C64?
#7 wood_jl OFFLINE
wood_jl
  • 6,910 posts
Posted Sun Dec 30, 2012 12:58 AM
The Atari needs to load DOS - in some form - from the disk, when it's powered on with a disk drive connected.
With "conventional" Atari DOS (DOS 2.0 or 2.5) there are 2 files - DOS.SYS and DUP.SYS. DOS.SYS is DOS (sorry I'm not well-versed, here) and DUP.SYS is "Disk Utility Package." This is a menu-driven DOS, rather than command-line driven, like SpartaDOS.
With a "conventional" bootable DOS disk (will get to unconventional in a moment) there needs to be DOS.SYS as a minimum. If you want to get to the DOS menu (sort of - from a functional standpoint - kind of like being a a command prompt) it will need to load DUP.SYS. For example, if you boot with BASIC enabled and you're at the "READY" prompt, and you want to do some DOS functions, you type "DOS" and it then loads the DUP.SYS and goes to the DOS menu.
With these DOSses, you can autoload a binary file - say a game - by naming it "AUTORUN.SYS". Say you had a binary load game you wanted to run (just one) then you could format a blank disk, write DOS.SYS to the disk, copy the game to the same disk, rename it AUTORUN.SYS, and skip DUP.SYS since you're just going to autoload the game and never need to load the Utility Package (DOS menu). You'd boot with BASIC disabled and it would load the DOS.SYS and then the game (now called AUTORUN.SYS) automatically. This is just for the sake of argument, to discuss what part of DOS would be required. In reality, this would be a terrible waste of disk space, because you've just wasted an entire disk for one game; this was just to illustrate the necessity (or lack thereof, in this case) of the DUP.SYS file.
For multiple games, you'd need to be able to access the DOS menu to select which file to load. So you'd format a blank disk and write DOS.SYS and DUP.SYS to it, and now it's bootable to the DOS menu (with BASIC disabled, of course). You could copy as many binary load games to this disc as you'd have room for. You'd then use the DOS menu (necessitating the DUP.SYS file to get there) and then view a directory, pick out a game to load, and then use the [L]oad menu selection and type the name. This is how I did it as a beginner, of course, long ago.
(the "unconventional" part): But then, you're wasting disk space, with DOS.SYS and DUP.SYS, where another game(s) could reside on those sectors, and wasting time waiting for all the DOS.SYS and DUP.SYS to load. So enterprising folk (not me!!!) made little "mini-DOS" type loaders, that load in a few sectors, and then bring up a menu of binary files on the disk, for you to choose from. There are several of these in existence, and they're definitely the way to go when making game disks. It's been so many years since I made one (literally) that I can't remember, but I think you use a utility to write those sectors (the mini-DOS). There are so many more knowledgeable people here that they'll tell ya.
The disk image that you linked to appears to be one of these bootloader disks.....
.....so when you copy the files from it to another disk, the mini-DOS-type-thingy sectors isn't copying; just the game files. Frequently, once you create one of these mini-DOS (bootloader) disks, you won't see the mini-DOS bootloader thing on a directory of the disk, as it's kind of hidden in a few sectors. Hence my layman's term of calling this "unconventional." But very neat! What you need is the utility (A utility) to write this to your disk, in the density which you are using. I've been out of the loop (and using other people's images) for SO LONG I can't recommend one, on account of I'm ignorant in these matters. But stuff like "MyPicoDOS" (author is on AtariAge and it is awesome) is (I think) what you are looking for.
Now that I've wasted your time with my extreme layman's perspective, someone else can correct my mistakes and make a proper recommendation. I tried! :) :) :)
#8 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Sun Dec 30, 2012 1:28 AM
Thanks so much for taking the time to explain some of this. It's all new to me so this is very helpful.
How can I just load something from the DOS prompt? MyDOS 4.53 doesn't appear to have an option to load a program from the DOS menu. I have a disk with a game called FOOTBALL, that appears as such upon listing the directory. Somebody else suggested it'd be like this:
LOAD"D:FOOTBALL"
This did not work... the drive spins up for a second, then I get "ERROR - 21".
#9 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,103 posts
Posted Sun Dec 30, 2012 8:31 AM
LOAD"D:FOOTBALL"
Well,
the file you are trying to load is most likely a binary ML file (*.COM / *.XEX / *.EXE), so it will not load with the Basic load command (this will only load Basic files). Since you speak of MyDOS, it does have an option to load ML files - option "L" binary load file. So, type L and then type in the filename and press Return. The ML file should be loaded then... if you are lucky...
Alas, there are lots of ML files that overwrite DOS, so they cannot be loaded with DOS binary load function (often you will see a message like "need MEM.SAV to load..." but in reality DOS cannot load this file at all). Thats where those mini-DOS or gamedos programs come into play, they need less memory, since they only load files (no copy, delete, rename, erase, or other DOS function they only load a file).
Attached you will find such a gamedos / mini-DOS named MypicoDOS by HiasSoft. Just boot this disk, as soon as MypicoDOS is onscreen, insert an empty (formatted) disk into your drive and use option 1 to write the gamedos loader. When done, press 0 (zero) to leave the program and quit to DOS or DUP. Next copy all the game files (with DOS option "C" copy files or with one of the multi-file copy programs) onto the disk with the gamedos loader you just created. Finally boot the disk with the gamedos loader and the game files on it. You will see the directory of game files, choose a program with keyboard (+-*=) or joystick and press Return key or fire-button to load that program. You can add more game-files at a later time, if you wish, the MyPicoDOS menu will display the new files then without having to re-run (re-write / re-install) the gamedos loader again...
-Andreas Koch.
Edited by CharlieChaplin, Sun Dec 30, 2012 8:35 AM.
#10 russg OFFLINE
russg
  • 1,648 posts
Posted Sun Dec 30, 2012 8:34 AM
LOAD"D:FOOTBALL"
I'm not sure what you mean by 'load something from the DOS prompt'. Since you are typing LOAD"D:FOOTBALL", you are at the Atari BASIC READY prompt.
OK, say you have a single density ATR with FOOTBALL and a MyDOS 4.53 DOS.SYS on it. You would hold OPTION down when you boot in order to boot directly to the DUP.SYS menu of MyDOS 4.53, instead of stopping at
the BASIC 'READY' prompt. Now you can try to load FOOTBALL (probably has FOOTBALL.COM) from MyDOS DUP.SYS menu, with the 'L' (LOAD) option. Hit 'L' then type FOOTBALL or whatever is on the disk.
With MyDOS you would just hit a number to get the directory of that drive.
You have to create a bootable disk. With the SpartaDOS disk you mentioned you put a X32G.DOS or other Sparta DOS file on, all you have to do, assuming you have a Sparta boot .ATR to boot from, you
put the X32G.DOS on the disk you want to make a boot disk of and type, at the Sparta 'D1:' screen, type 'BOOT D2:X32G.DOS' that will make a Sparta boot disk on the D2: drive you have a real floppy on.
Oh, but first you have to format the D2: floppy before you can add anything to it. The key here is to get the 'D1:' Sparta prompt you've booted from an SpartaDOS boot .ATR on APE.
With 'D1:' Sparta prompt you would need the Sparta XINIT.COM file on the Sparta disk so you can format the real floppy in D2:
With MyDOS 4.53, you would boot from a MyDOS .ATR, holding OPTION and get to the DUP.SYS menu. Then you would have to format a real floppy in, say, D2: from MyDOS menu, and then write DOS files to it to make it bootable.
Probably you want to run a bunch of games from your real 1050 floppy drive. Here again, you need to format a real disk, write a boot to the floppy and then put the game files on the floppy. MypicoDOS sounds like a good
'mini' DOS to make a boot disk of several games like the menu disk you used earlier. You have to find the program that writes the picoDOS to a floppy, then copy your game files to the floppy.
Alternatively, you can probably find game .ATRs that are already made, single or enhanced density, probably single. If you find such single density boot multiple game ATRs, you can copy them to your 1050 using
a sector copier like Sparta SCOPY (I think that one is not good). There are other sector copiers, I don't know about, you can use my RW12.COM for instance.
So,
1. format your single density floppy (you can put a notch on the un-notched side and use both sides of the floppy, called a 'flippy'. There are special notch making tools.
2.make the floppy bootable with MyDOS init or SpartaDOS XINIT, or probably best, use mypicoDOS.
3. Either sector copy a single density disk from APE .ATR to your real floppy or write boot code using MypicoDOS or other Menu making program and copy the files to that floppy that you want.
I remember MENUMAKR from years ago, it gave an option to format the disk as well as make the boot menu code.
Also, you might want to run some BASIC programs. For that, you boot not holding OPTION to the 'READY' prompt and then you can run a BASIC 'LOAD' file, like 'FOOTBALL.BAS'
by typing 'LOAD D1:FOOTBALL.BAS" and "RUN", or just "RUN D1:FOOTBALL.BAS". BASIC files always have a .BAS extender. .COM, .XEX , and .EXE are Machine programs to load from DOS
or a menu disk.
Edited by russg, Sun Dec 30, 2012 8:53 AM.
#11 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Sun Dec 30, 2012 4:00 PM
Ok, so I copied MypicoDOS over to a real floppy. The 800XL boots with this disk, then pops up a menu. When I insert a blank formatted disk (tried single density, enhanced density, multiple good disks) and select "init disk" followed by the corresponding drive #, it fails and says "error creating PICODOS.SYS."
Then I tried creating a new .ATR image via the makeATR editor, hoping I could just put the DOS files on there along with some games. The disk does not boot - "BOOT ERROR". When creating this image, I've tried including the DOS.SYS and DUP.SYS, as well as putting ALL the files from the MypicoDOS image, still does not boot. Even when trying to create an .ATR that has NOTHING BUT the files from the MypicoDOS image, the disk doesn't boot.
#12 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Sun Dec 30, 2012 4:26 PM
I also tried booting from SpartaDOS via APE, then formatting a real floppy with it and making it bootable via the command above "BOOT D2:X32G.DOS". I was able to create the disk successfully, but now I have no idea how to get the games over to it...
The manual for the 800XL and 1050 are both totally useless. I don't even know which DOS I should be using for what, there are half a dozen flavors or more... :mad:
#13 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Sun Dec 30, 2012 4:53 PM
Now I've found a manual for SpartaDOS here:.http://sdx.atari8.info/sdx_files/4.41/Manual%20V4-41.pd
Booting from SpartaDOS on APE drive 1, I attempted to copy a single game from APE drive 3 over to real floppy in drive 2, which has been formatted by SpartaDOS and made bootable. It appeared to copy the file, but then when I tried to boot from the new disk I got the SpartaDOS screen and when doing a DIR D2 it shows no files.
I think I need to just buy a double density upgrade for my 1050 so I can just dump the .ATRs over in bulk, or maybe some kind of SD card data storage unit... this is too painful... if I went with SD data storage, any suggestions on what's easiest to use?
#14 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,103 posts
Posted Sun Dec 30, 2012 6:17 PM
Hmm,
strange, but alright then - 1) here is another disk or better two 90k images with Mypicodos already initialized on them, MYPINITx.ATR. Make copies of one of these disk images with a sector copy program before using it or writing anything to it (and always keep at least one copy of the disk with only Picodos.SYS on it).
2) You will also find a disk/image with a sector-copy program attached here, Mycopy1.ATR - this is MyCopier version 1.c, simply boot it with or without Basic. This sector-copier works with 90k, 130k and 180k disks and ultraspeed if available. In the menu set "Enhanced density" to on, even if you don`t use enhanced density - this way the copier program will always test if sector 1040 is available or not (good for stupid XF551 and similar drives which cannot detect the disk density automatically). If your disk drive has a US-Doubler you may set the option "Sector skew" to on, otherwise always leave it off.
Press Start to copy a disk and insert source and destination disk(s) when prompted. When you are done with copying (afaik multiple copies can be done with Select or Option key), press Control-B to boot another disk, then press Start for a second (not longer!) to really boot another disk or Option to return to the copier program...
3) Last not least, I have attached a multifile-copy program on a DOS 2.x compatible disk for you, MFcopy.ATR. This one works with 64k RAM and only one disk drive. You can use it to copy all your game files onto the initialized Mypicodos disk (the one with Picodos.SYS on it). The program works with Start, Select and Option keys, Return key and -= keys as well as some other keys, think they are all mentioned in the program. Simply setup your source and destination drive, then press Start for a Directory of your game files (they have to be in DOS 2.x format!), choose the files you want to copy with Space or Return and press Start to copy the files. You may have to change disks every now and then (the program copies multiple files with up to 310 sectors in one go). When you are done with copying, press Option to go back to the main menu and there press ESC to leave the program and quit to DOS. The DOS on this disk can read, write and format 90k, 130k and 180k disks...
When all your games have been copied to the init. Mypicodos disk (the one with Picodos.SYS on it), boot this disk, then select and load your games from this disk. Good luck !
NOTE: All programs work alright on a 64k Atari XL/XE computer, I have no clue if any of these programs will work on an Atari 400/800 with 48k or less RAM, since I do not have these machines. And err, all programs work in DOS 2.x format, so your game files must also be on a disk with DOS 2.x format - luckily the Homesoft gamedisks are in DOS 2.x format (DD/180k)...
-Andreas Koch.
Edited by CharlieChaplin, Sun Dec 30, 2012 6:21 PM.
#15 russg OFFLINE
russg
  • 1,648 posts
Posted Sun Dec 30, 2012 6:55 PM
You're coming along. You've made progress. Things will settle down. Sorry.
If you type 'DIR D2' at the D1: SpartaDOS prompt, you will get no files reported. It will look for a file named D2. You have to type 'DIR D2:' or 'DIR D2:*.*', using wildcards can be useful. Gotta put the colon in there.
I know you probably don't want to learn SpartaDOS usage, probably want to make a menu disk with games on it. Many, maybe most, games won't run from SpartaDOS nor MyDOS. You gotta run them from
a menu disk, without BASIC.
Oh, and lots of the best games don't load from menu disk even. You gotta load them from an .ATR, using APE (or ASPEQT) or sector copy them from APE drive to your 1050. Just one game per disk that boots the game.
Since you've borrowed a SIO2PC cable and can use APE, you see how useful APE and a SIO2PC cable can be. You can use a 16 megabyte .ATR with APE. Might want to buy a SIO2PC of your own. All the
game ATRs you can find will work with APE. There are some .PRO images you can use also. A little expensive if you buy APE software and an APE USB adapter.
Edited by russg, Sun Dec 30, 2012 7:15 PM.
#16 russg OFFLINE
russg
  • 1,648 posts
Posted Mon Dec 31, 2012 9:18 AM
One more thing. It is hard to find 5.25" floppy disks now. And you can't use high density floppies, have to use double density. The double density come with a hub ring, a re-inforcement ring around the hole. High density have no ring.
#17 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Mon Dec 31, 2012 11:01 AM
I've got it working now, both methods. Victory! Thanks!
As it turns out, the file HAD copied after all. I have learned a little more about SpartaDOS, plus the very helpful advice here. It's a little like MS-DOS which is good for me.
I don't understand why I wasn't able to make my own MypicoDOS bootable disks, but the ones graciously provided above work fine. I can dump games on them in makeATR and copy to real floppy, works. That's going to be faster than manually copying files via SpartaDOS, although the knowledge gained there is good to have. My primary purpose here is to create music and maybe GFX, more so than play games, so file handling is necessary.
Do all Atari 8-bits have BASIC built in? Curious since there is a cartridge for it as well. Also, how long do I need to hold down option to disable it? When necessary, do I need to do this only once as the computer boots?
Also, when creating images via makeATR, I can specify different formats for a disk... for different DOSes. Maybe I chose the wrong type when creating my bootable image.
FYI, I have hundreds of new stock DS/DD floppies that work great with all my 8-bits... no problems there!
Thanks again for the ongoing help. Wouldn't have made it this far without it!
#18 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Mon Dec 31, 2012 11:07 AM
And about modern file transfer and storage, would you guys recommend any SD based options? SIO2PC w/ APE seems the most versatile, but requires a PC. With chiptune exhibitions in mind I would benefit from a more self-contained solution.
#19 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
  • It's easy living in a bubble
Posted Mon Dec 31, 2012 11:20 AM
400/800/1200Xls do not have basic built in hence the need for basic on cart.
As for storage I would suggest the SIDE II cart, very versatile device
Edited by mimo, Mon Dec 31, 2012 11:22 AM.
#20 Philsan OFFLINE
Philsan
  • 3,861 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Mon Dec 31, 2012 11:30 AM
Topic for newbies.
#21 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Tue Jan 1, 2013 2:37 PM
Topic for newbies.
Thanks. There are a lot of options to sort through. The SIO2PC/USB looks pretty awesome... anything that combines PC hardware emulation AND standalone SD storage should be optimal.
#22 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
Posted Tue Jan 1, 2013 3:05 PM
sio2pc USB is not a stand alone device, it just plugs into your pc USB port rather than the original sio2pc serial port version.
there Is an sio2usb device that is stand alone, but does not have any pc access
#23 Android8675 OFFLINE
Android8675
    Moonsweeper
  • 440 posts
  • Incognito'N
Posted Wed Jan 2, 2013 12:36 PM
I don't have one but there is an SIO2SD. Takes a FAT32 formatted SD card, and has a little LCD display that lets you choose the files from the SD card and insert them into D1-D4. Fast. I use a SIO2PC connected to a little PC laptop with a serial port. Works well, but obivously you need to have another computer to serve up files to the Atari. For standalone I think SIO2SD is what you're looking for.
This guy seems to be popular around here: http://www.lotharek....duct.php?pid=49
#24 mos6502 OFFLINE
mos6502
    Space Invader
  • 34 posts
Posted Thu Jan 3, 2013 9:56 PM
But wait... you guys haven't seen this?
http://www.atariage....or-atari-8-bit/
Unless I'm misunderstanding something, it's supposed to do both (standalone SD storage AND SIO2PC/USB interface). I've asked Santosp (the creator) about it, he's out of them but will be getting back to me... it looks perfect.
#25 mimo OFFLINE
mimo
    Preppie!
  • 6,828 posts
Posted Fri Jan 4, 2013 2:54 AM
Yep I know about them, but as the maker had said they were sold out I didn't suggest it. I thought you would like something you could buy
Also tagged with one or more of these keywords: ape, prosystem, 1050, density, atr, image, transfer
