M.U.L.E. for TI
PROGRAMMING ATARI MULE
121 replies to this topic
#26 Willsy OFFLINE
Willsy
  • 3,105 posts
Posted Sat Jan 5, 2013 5:31 AM
I use notepad++ for everything, but each to their own. It's just what you're familiar with, I suppose.
notepad++ has syntax colouring for C/C++ plus a myriad of other languages, and there are also syntax files available for TI assembly language, extended basic and Forth. The assembly language and Forth allow folding of subroutines etc. See the development resources thread, bottom of section 4.
#27 JamesD OFFLINE
JamesD
  • 8,481 posts
Posted Sun Jan 6, 2013 7:20 AM
I use Notepad++ and have even created custom language highlighting for a couple CPUs.
I just wish it had some of the split screen options some other editors I've used have had.
#28 Lee Stewart OFFLINE
Lee Stewart
  • 3,990 posts
Posted Sun Jan 6, 2013 8:50 AM
It does!: View-->Move/Clone Current Document ...unless I miss your point.
...lee
#29 Willsy OFFLINE
Willsy
  • 3,105 posts
Posted Sun Jan 6, 2013 12:32 PM
...lee
Yeah - I use it all the time!
#30 JamesD OFFLINE
JamesD
  • 8,481 posts
Posted Sun Jan 6, 2013 10:48 PM
The editor I used to use could split the screen left and right, top and bottom, or a combination of the two.
For example, I could have the left side of the screen full height but the right side split top and bottom.
It was pretty handy for some things.
#31 adamantyr OFFLINE
adamantyr
  • 1,526 posts
Posted Mon Jan 7, 2013 12:21 PM
Any particular reason why nobody is proposing writing M.U.L.E. in assembly? :)
Without actually sitting down and writing it, I'd guess that Extended BASIC would have enough memory to implement the game, but you'd have to simplify the interface and drop the music and cut scenes.
I agree that bitmap is not really necessary. Graphics were not a huge requirement of the game, although the interface that has you moving your player into separate stores would be a challenge to implement in Extended BASIC efficiently. Also, the frequent screen changes would mean you would have to store the game map and redisplay it, something Extended BASIC isn't that good at without using the sluggish DISPLAY AT.
The original game was designed for up to four players, which could be tricky on the TI. You'd have to separate reading the two joysticks from the left and right keyboards, or split the keyboard into four sets of keys for each player to use.
Does anyone know if there is source code available? I've learned the hard way that re-implementation really requires COMMENTED source code if you want an accurate version.
Adamantyr
#32 JamesD OFFLINE
JamesD
  • 8,481 posts
Posted Tue Jan 8, 2013 9:38 AM
There is a disassembly of the Atari version out there but it has almost no comments through most of the code.
#33 adamantyr OFFLINE
adamantyr
  • 1,526 posts
Posted Tue Jan 8, 2013 5:50 PM
Ugh... yeah, I had a partially commented listing of Eastern Front 1941 to work off of... The good part was that it was the original Chris Crawford work, so the variables had sensible names and there was a comment or two which gave you a rough idea of what the code section was doing.
The problem was trying to reverse-engineer the algorithms being used, which was really difficult to do. It's kind of like trying to see the forest by assembling all the leaves and branches in a pile to try and assemble a tree.
If you can find the disassembly of the Atari version in 6502 code, post a link here.
Adamantyr
#34 JamesD OFFLINE
JamesD
  • 8,481 posts
Posted Tue Jan 8, 2013 8:18 PM
I'd start here:
http://www.atariage....-decompilation/
http://www.worldofmule.net/
#35 hloberg OFFLINE
hloberg
    Dragonstomper
  • 776 posts
  • Location:Land of the Road Runners (they don't go beep,beep)
Posted Wed Jan 9, 2013 3:03 PM
I'd start here:
book marked the 'world of mule' looks like i can get a bunch good info there.
thanks, HLO
#36 hloberg OFFLINE
hloberg
    Dragonstomper
  • 776 posts
Posted Wed Jan 9, 2013 3:26 PM
Adamantyr
From my experience with 6502 Atari assembler its not much like the 9900 TI-99 assembler. How the Atari handles video would be the biggest rewrite. The Atari relies a lot on bit-map graphics and the TI on character graphics. The Atari uses DLIs something TI couldn't do easily and has several character sizes to the TI one, only 5 sprites (player/missles) to the TI 32 and video memory access is also very different.
Having all said that, someone did manage to do a direct translation of PITFALL! to TI so I guess it could be done.
My plan is to do most in 'C' or FORTH and assembler. Your right, XB would only get me about 80% of the way there.
I do have a copy of the some notes made by the programmers so that should help.
Also, I plan to limit the game to 2 humans and 2 computer (I believe that was the way the C64 had it).
Interesting story, i once read that when when the Atari programmers were given a game to translate from another company (arcade, another computer) all Atari ever gave them was the machine (or cartridge) and a copy of the instructions and said 'go to it', which frustrated the programmers to no end since Atari always did have the rights to the code but was too lazy to get it from the source.
Edited by hloberg, Wed Jan 9, 2013 3:55 PM.
#37 JamesD OFFLINE
JamesD
  • 8,481 posts
Posted Wed Jan 9, 2013 7:47 PM
thanks, HLO
The disassembly was pointed to by a link in the thread I linked to. The site seems to be offline at the moment.
#38 Raccoon Lad OFFLINE
Raccoon Lad
    Moonsweeper
  • 478 posts
  • I Like Pixels
Posted Fri Jan 11, 2013 12:01 AM
Here's some graphics I put together for fun.
Attached File  shop-ti3.png   3.88KB   48 downloadsAttached File  map-TI2.png   4.16KB   40 downloads
The map screen is partly based on the NES version of mule, but with the graphics improved and made compatible with the TI video chip.
#39 Willsy OFFLINE
Willsy
  • 3,105 posts
Posted Fri Jan 11, 2013 1:48 AM
HI Racoon Lad, is that bitmap mode or character mode?
#40 retroclouds OFFLINE
retroclouds
  • 1,705 posts
Posted Fri Jan 11, 2013 1:52 AM
I suppose this is character mode. Raccoon Lad is very talented in doing graphics. He did the Tutankham graphics for me (level maps, sprites and bit-map titlescreen)
#41 sometimes99er OFFLINE
sometimes99er
  • 4,230 posts
Posted Fri Jan 11, 2013 2:11 AM
Yep, seems to fit character mode.
Hmmm, here I thought it was you, retroclouds.
Racoon Lad, just into graphics or did you have a TI-99/4A at some point ? Do you program too ?
#42 hloberg OFFLINE
hloberg
    Dragonstomper
  • 776 posts
Posted Fri Jan 11, 2013 9:32 AM
Wow. Well, now I have a bench mark.
If you have a listing or how you created the graphics that would be greatly appreciated.
#43 hloberg OFFLINE
hloberg
    Dragonstomper
  • 776 posts
Posted Fri Jan 11, 2013 9:41 AM
Here is a guy who has reverse engineered MULE. I downloaded his stuff.
http://bringerp.free.fr/RE/index.php5
#44 Willsy OFFLINE
Willsy
  • 3,105 posts
Posted Fri Jan 11, 2013 9:53 AM
Check out magellan, a nice tool (so I'm told) for designing graphics for the TI VDP chip. Sometimes also has a number of nifty tools for designing sprites, and has a collection of hundreds of fonts an associated tools. Check out section 4 of the utilities thread.
#45 hloberg OFFLINE
hloberg
    Dragonstomper
  • 776 posts
Posted Fri Jan 11, 2013 12:42 PM
Looks to be a broken link. Someone got a copy they could send me.
Edited by hloberg, Fri Jan 11, 2013 12:43 PM.
#46 retroclouds OFFLINE
retroclouds
  • 1,705 posts
Posted Fri Jan 11, 2013 12:54 PM
Hmmm, seems that codex took it down.
Here's a link to my (unofficial) updated version. While working on Tutankham I found some bugs in Magellan and I fixed those. Hence the "unoffical" updated version. :-D
http://www.atariage....50#entry2302456
Seems that I need to update the Development Resources thread. Crazy how stuff breaks after a while ;-)
Edited by retroclouds, Fri Jan 11, 2013 12:56 PM.
#47 hloberg OFFLINE
hloberg
    Dragonstomper
  • 776 posts
Posted Fri Jan 11, 2013 1:45 PM
Thanks. FYI, also looks like grapefruit is also a broken link.
#48 Raccoon Lad OFFLINE
Raccoon Lad
    Moonsweeper
  • 478 posts
  • I Like Pixels
Posted Fri Jan 11, 2013 8:34 PM
I never had a TI-99/4a, but I have a fondness for the TMS-9918a. Making TI/Coleco/Sg-1000/MSX graphics is fun and challenging, and every so often I get the bug to make art with the 16 colors 2 colors per line / character limitations. I poke me head in here every so often because I love to see people making games. That's probably the main reason I hang around AA is for the homebrew scene.
Anyway, for graphics, I use ProMotion. It's kind of expensive for the average user, but I got a copy for free some years back while doing professional game art. When I do tms9918a graphics, I usually just turn on the 8x8 pixel grid, zoom in and try to remember to keep the colors to 2 per character.
Here's graphics for the other primary screens in the game.
Attached File  barter-ti3.png   2.85KB   27 downloadsAttached File  wampus-TI2.png   3.16KB   33 downloadsAttached File  title-ti.png   1.42KB   23 downloads
#49 Raccoon Lad OFFLINE
Raccoon Lad
    Moonsweeper
  • 478 posts
  • I Like Pixels
Posted Fri Jan 11, 2013 8:50 PM
Attached File  status-ti2.png   2.4KB   18 downloads
Almost forgot this one.
#50 hloberg OFFLINE
hloberg
    Dragonstomper
  • 776 posts
Posted Fri Jan 11, 2013 10:38 PM
thanks, they look great
Also tagged with one or more of these keywords: PROGRAMMING, ATARI, MULE
