xBIOS, new features
5 replies to this topic
#1 xxl OFFLINE
xxl
  • 1,126 posts
Posted Sat Jan 5, 2013 9:46 AM
like inflate on the fly...
http://atari.pl/xbios.atr
#2 Heaven/TQA ONLINE
Heaven/TQA
  • 11,192 posts
Posted Sat Jan 5, 2013 3:23 PM
hi xxl,
thx. xbios looks good. so I can pack xex with gzip, call "binary load" and it works?
and binary load can handle several segments?
#3 Creature XL OFFLINE
Creature XL
    Dragonstomper
  • 904 posts
Posted Sat Jan 5, 2013 4:17 PM
Oh, didn't really know what this XBIOS was used for. But after reading the page it looks like it can be used to load parts of, say a game, from disk.
Would be much easier then re-enabling the OS. Will have a look at it IF I need it :)
#4 xxl OFFLINE
xxl
  • 1,126 posts
Posted Sat Jan 5, 2013 4:50 PM
no, binary file works normally. there is modified Fox's inflate decompressor (512 bytes) you can do it this way:
org myproc
lda <DEST
sta inflate_zp+2
lda >DEST
sta inflate_zp+3
jsr inflate
; so source is not RAM but file
rts ; continue loading (1)
INI myproc
opt h-l+o+
ins 'deflated.df7'
opt h+l+o+
org mynextproc (1)
run mynextproc
if you prefere RLE there is 31 byte decompressor routine (source-file, dest-memory)
there is more, you can:
org NMIEN
.byte $00 ; NMI OFF
org $0000
; all zero page free to direct loading
and you can
org PORTB
.byte $fe ; ROM OFF
org $c000
; all RAM under ROM free to direct loading
and you can
org $ffff ; ;-)
.byte $ff
only MADS can build right binary file
and you can
org myproc
ldx #$ff
txs ; destroy stack
jmp xBIOS_BINARY_LOAD ; continue loading
and you can
jmp xBIOS_BINARY_LOAD ; binary load from any position in file
and you can
org my_proc
ldy <any_adress
ldx >any_adress
lda #%11 ; b0 = 1 - change RUNAD; b1 = 1 - change INITAD;
jmp xBIOS_SET_VECTORS
ini my_proc
org my_new_proc
org any_adress
.word my_new_proc ; - INI ADRESS
so memory $0200-$6ff free to direct loading
after that all you can still load or save data to any file
and ... http://xxl.atari.pl/?p=1076
#5 Creature XL OFFLINE
Creature XL
    Dragonstomper
  • 904 posts
Posted Sat Jan 5, 2013 5:23 PM
Could I read/write inside the XEX? The "point" function sounds like it could be done.
Loading/running a XEX. Then load the level data from the same XEX (if I know the byte-position in that file) ?
And later, writing "savegame" to a portion of that file?
#6 xxl OFFLINE
xxl
  • 1,126 posts
Posted Sat Jan 5, 2013 5:35 PM
yes
yes. point is relative file position (not like in dos2)
yes
yes, why not
