F18A programming, info, and resources
f18a fpga vdp 9918a 9928 video hardware mods upgrade updates
616 replies to this topic
#601 Ikrananka OFFLINE
Ikrananka
  • 3,108 posts
Posted Fri Jan 4, 2019 12:47 PM
I too just updated my F18A ColecoVision with the v1.9 firmware.  Flawless update using Tursi's excellent updater via my AtariMax Ultimate SD cart.  Huge thanks to Tursi for making this such a painless process.
Even more thanks to Matthew for this awesome update.  One of my issues was that the VGA output from my F18A would not display on my relatively old (2006) Sharp LCD TV.  I would get just a blank screen.  The v1.9 firmware has fixed this problem and for the first time ever I can now play my F18A enabled CV on this TV instead of my other displays.  Thanks Matthew  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:
Edited by Ikrananka, Fri Jan 4, 2019 12:48 PM.
#602 matthew180 OFFLINE
matthew180
  • 2,630 posts
Posted Fri Jan 4, 2019 4:59 PM
I'm glad it fixed problems with your display.  It is amazing to me how much trouble 6.4 pixels can cause!
#603 matthew180 OFFLINE
matthew180
  • 2,630 posts
Posted Fri Jan 4, 2019 5:07 PM
Hi Matthew,
do you have a (direct?) link to the v1.9-update ? I cannot find it.
(I used the link from post #1 and some more).
I only see this:
thx
There is a zip file in the first post of this thread. It appears to be what you are looking for.
Did you find it? Chue's comment was spot-on, you are looking for the F18A_V19.zip file at the bottom of the first post. Here is a direct link (I think):
http://atariage.com/...ttach_id=612778
I have not updated my website yet, it ends up being lower on the priority list.
#604 arcadeshopper OFFLINE
arcadeshopper
  • 4,403 posts
Posted Fri Jan 4, 2019 7:28 PM
update works flawlessly off TIPI
tossed dsk image onto tipi drive, auto unpacks to a f18A_V19 folder
make that folder DSK1 in tipicfg or tipimap
load ea3 DSK1.F18AUPD
folllow on-screen instructions
Greg
#605 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Fri Jan 4, 2019 8:33 PM
I need to burn a 512K cartridge image and try it against one of my TI machines. . .then I'll have a fully portable update device.
#606 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Fri Jan 4, 2019 9:20 PM
The update gave me a good 'excuse' to set up my F18A / CF7+ system today.  It took me a while to figure out that my ubergrom UART/serial connection was plugged into a cable that went... nowhere. Ugh.  Anyway, once I get the files transferred and update my F18A, I'll upload a TI archive  to Heatwave, as a few people nabbed earlier updates that way in the past.
Edit: updated to v1.9 successfully and uploaded the files in the disk image.
Edited by InsaneMultitasker, Sat Jan 5, 2019 2:35 AM.
#607 sparkdrummer OFFLINE
sparkdrummer
  • 1,099 posts
  • Status? I don't need no stinkin' status!
Posted Sat Jan 5, 2019 7:13 AM
Matthew
I just attempted to update my F18A to version 1.9, but the CRC in the upper left shows A374. It also states FOUND V 1.8.
i did continue per your instructions on your website. What should I do?
#608 sparkdrummer OFFLINE
sparkdrummer
  • 1,099 posts
Posted Sat Jan 5, 2019 7:58 AM
I meant to say I did NOT continue.
#609 matthew180 OFFLINE
matthew180
  • 2,630 posts
Posted Sun Jan 6, 2019 12:22 AM
My website is not up to date with the V1.9 firmware, you need to download the F18A_V19.zip file from the *first post of this thread*.  Here is a link to the file:
I suppose I should update my website too...
#610 Tursi OFFLINE
Tursi
  • 5,666 posts
  • HarmlessLion
Posted Sun Jan 6, 2019 4:34 AM
I just reprogrammed my F18a with the v1.9 firmware. It was a flawless update using Tursis excellent updater on my Super ColecoVision.
I can't take full credit, all I did was wrap Matt and Rasumus' original excellent updater with some more GPU code so it could be easily ported. ;)
#611 sparkdrummer OFFLINE
sparkdrummer
  • 1,099 posts
Posted Sun Jan 6, 2019 7:02 AM
I had the right file, but I copied again from your post above..
Still shows A374 in the upper left.
FOUND F18A: V1.8
UPDATE FILE: V1.9
I'm fearful to continue
#612 Asmusr ONLINE
Asmusr
  • 3,146 posts
Posted Sun Jan 6, 2019 7:38 AM
FOUND F18A: V1.8
UPDATE FILE: V1.9
I think A374 is the correct checksum for the disk version of the updater.
#613 matthew180 OFFLINE
matthew180
  • 2,630 posts
Posted Sun Jan 6, 2019 2:07 PM
Ah, yes, that is correct, I forgot that the CRC will be different between the disk updater and the ROM updater (and probably the CV ROM updater).  A374 is correct for the 99/4A disk updater.  Sorry for the confusion, and thanks Rasmus for pointing this out.
#614 sparkdrummer OFFLINE
sparkdrummer
  • 1,099 posts
Posted Sun Jan 6, 2019 3:39 PM
Thanks gentlemen!
#615 Tursi OFFLINE
Tursi
  • 5,666 posts
  • HarmlessLion
Posted Sun Jan 6, 2019 4:40 PM
The updater is pretty paranoid, and every block is checked before the F18A is modified. Don't be too worried about the initial checksum displayed on the screen - that is the program checksum and has /also/ been verified by the program to be correct. It's displayed only to make it easier for people who are BUILDING the tool to get the correct checksum to put in the code.
#616 Swim OFFLINE
Swim
    Chopper Commander
  • 176 posts
Posted Wed Jan 16, 2019 5:43 PM
Thanks for continuing the real TI file ARC tradition on Heat Wave. I mirror it on the Hidden Reef.
#617 Swim OFFLINE
Swim
    Chopper Commander
  • 176 posts
Posted Sat Jan 19, 2019 10:54 PM
Just an FYI here that the F18A 1.9 update package works as expected when the F18A is installed in a console with the 32k on the 16 bit buss running a 3.58MHz clock crystal. However, if you have just completed updating some F18A equipped consoles running at stock 32k and 3.0MHz clock speed and then move to update a 32k on the 16 bit buss console running a 3.58MHz clock crystal your heart may wind up in your throat and you may look for something to hold on to as the binary code rolls by almost faster than you can read it and you finish in almost half the time it takes to update a stock console. The F18A is a fantastic piece of hardware and the F18A firmware update software is a fantastic software package.
That is all. :)
Also tagged with one or more of these keywords: f18a, fpga, vdp, 9918a, 9928, video, hardware, mods, upgrade, updates
