Cybearg Posted February 19, 2013 Share Posted February 19, 2013 As suggested by Random Terrain in this thread, I've made a new thread to ask the specific question: How do I get the driving paddle to work? I know that it's been done in zombie chase and the code is something akin to this (this version was tweaked a bit by bogax: const nomove = 1 const turnright = 0 const turnleft = 2 data ptbl nomove, turnright, nomove, turnleft turnleft, nomove, turnright, nomove turnright, nomove, turnleft, nomove nomove, turnleft, nomove, turnright end temp1 = SWCHA / 4 & $C temp1 = temp1 | last last = temp1 / 4 if ptbl[temp1] & nomove then goto no_move if ptbl[temp1] & turnleft then goto left else goto right However, when I try this, it just results in a constant turn one direction or the other. Note: that is using Stella with the Driving controller selected. Could someone perhaps give a very simple working example or maybe point out what's wrong, if anything? Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 19, 2013 Share Posted February 19, 2013 The driving controller has a few quirks about it. If you spin it really fast you start missing states as it changes it state faster then you are sampling. At slower speeds this seems fine, but you hit a secondary effect where if you turn to slow you continually stop and start. I was thinking about driving controllers today and in particular about your game, Cybearg and I got a routine working (in assembly). I hacked it into a quick and dirty reverse engineered source. It doesn't need to go where I put it, I just did it this way to get it in there. In the end the idea is BB doesn't know or care what controller is plugged in. It just checks left or right and moves the rings as it normally does. The process lies underneath and instead of using joyp0 or whatever it is called, you do just do bit tests on the variable I named "tempJoy". hbJoyDrive.zip The "old" rom is a really old rom that I got running the merged JoyDrive code on this afternoon. It works. The "new" rom I just did from the newest rom I could find, but I haven't tested it on real hardware. It is essentially the same code places in the new rom, and I expect it to work. I originally wrote a routine, and then went looking for betters ones until I found one on the Stella Mailing List by TJ. I couldn't get his super optimized code to work, so I started with his mid optimized one. EOR'ing instead of using a second table was a clever idea. I wrote a routine that does a little bit more then check if the controller is moving left or right. I made it continually check for is a driving controller or joystick is being used in a single port (in this case the left side). The driving control is not connected to pins 4 (right) and pin 3 (left) as can be seen here in the schematic. When the joystick is pressed in the right or left direction it grounds these pins. So the first check I do is to see if either pin is grounded. If it is I presume a joystick is plugged in. The driving controller is connected to the up (pin 1) and down (pin 2) pins. To check for the driving controller you can either check for the graycode pattern to appear, or what I did was look for both up and down to be pressed at the same time (this is simple and saves bytes). This condition doesn't happen too much for the joystick as you need to press left and right on the joystick to scroll the ring. However, when you scroll the knob even a little bit you will soon hit '00'. The main driving force between having the port handle both joystick and driving controller is that the player can switch the controller on the fly and not have to do anything. The secondary reason is I know at least for myself I never read the manual, so yes, I am guilty of being lazy like that. I'd just rather have something work without having to fiddle with thinking which switch to press. Finally, here are some Random Thoughts: - I tested this (well the rom marked old) on real hardware and it worked great! The response was spot on. - In emulation this might be a bit of a nightmare because you have to tell Stella that a driving controller is hooked up in which port. I don't know how it will react if you tell it that there is a driving controller plugged in when there really is a joystick. Using the difficulty switch won't help here, because this has to be updated in the game properties. The simple thing to do is use both ports, have one for the joystick and one for the driving controller. If you have only one Stelladapter then I'm quessing you'd have to tell the game if you were using the left or right port still. I don't think there will be any easy way about it in emulation, but I'm waiting to here what Stephena has to say. I do own a Stelladaptor, but I don't have it with me. Anyhow on real hardware no issues. It just works as is. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 19, 2013 Share Posted February 19, 2013 (edited) Before I forget, if you are using the DC with Stella, don't forget to press the tab button and go into "game properties". Select controller and from the dropdown use "driving" for the driving controller. You might have to restart Stella after this IIRC. Also relevant parts of the code (this is not contiguous): START: ;after clear routine, ;prep previous postion on driving controller at power on LDA SWCHA AND #UP_DOWN_MASK LSR LSR LSR LSR STA previousPos ;======================================= ;when testing left and right use tempJoy LF687: ; bit SWCHA ; 4 replacing SWCHA BIT tempJoy NOP LF698: ; bit SWCHA ; 4 BIT tempJoy NOP ;======================================= ;code that updates tempJoy: ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; Read Driving Controller ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; RIGHT_BIT = $80 LEFT_BIT = $40 DOWN_BIT = $20 UP_BIT = $10 LEFT_RIGHT_MASK = $C0 UP_DOWN_MASK = $30 tempJoy = $A9 previousPos = $AA joyCounter = $AB joyFlag = $AC TEST_DRIVE: sta WSYNC ;--------------------------------------- lax SWCHA and #LEFT_RIGHT_MASK cmp #LEFT_RIGHT_MASK bne .decisiveControl ; left or right pressed txa ; SWCHB and #UP_DOWN_MASK bne .finishContCheck ; branch if up, down, or both (up and down) not pressed... ; Don't branch when both up and down are pressed, ; unlikely for joystick, but happens all the time for DC. .decisiveControl: lda #0 ror sta joyFlag ; $80 = DC, $00 = Joystick .finishContCheck: txa ; SWCHB bit joyFlag sta WSYNC ;--------------------------------------- bpl .finishMove ; joystick being used and #UP_DOWN_MASK lsr lsr lsr lsr ldy previousPos sta previousPos eor NextLeftTab,Y beq .left eor #$03 beq .right cpy previousPos bne .continueLastDirection inc joyCounter lda joyCounter and #$0F bne .continueLastDirection sta joyCounter lda #(LEFT_BIT | RIGHT_BIT) .byte $0C ; NOP, skip 2 bytes .left: lda #~LEFT_BIT .byte $0C ; NOP, skip 2 bytes .right: lda #~RIGHT_BIT .finishMove: sta tempJoy .continueLastDirection: jmp FINISH_VSYNC NextLeftTab: .byte 1,3,0,2 Edit: having a hard time here with the forum eating my code, I edited a few times now! Edited February 19, 2013 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
Cybearg Posted February 19, 2013 Author Share Posted February 19, 2013 Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 19, 2013 Share Posted February 19, 2013 I have no idea what that is, or if he is happy, or if he just saw a horror show. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted February 19, 2013 Author Share Posted February 19, 2013 I have no idea what that is, or if he is happy, or if he just saw a horror show. It is a gasp of absolute joy, as the sparkles indicate. As always, thanks so much! Now, as much as you integrated everything so nicely in the assembly, I'd love it if we could get it working as an include or somesuch. I've sent you a PM to discuss the details. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted February 19, 2013 Share Posted February 19, 2013 I won't have much time for playtesting, unfortunately. I got more mid-terms coming up after this week, and after that it is the mad sprint towards the end of the semester. I did enjoy working on this though, and I learned a few things about how BB is structured so all in all it was a win-win for everyone. I just hope this last little bit goes smoothly. I also hoped you snagged yourself a driving control to try this on real hardware. It was a lot of fun with it! Quote Link to comment Share on other sites More sharing options...
Cybearg Posted February 19, 2013 Author Share Posted February 19, 2013 Yep, I've got a driving controller. I'm just waiting for a Harmony to arrive. Quote Link to comment Share on other sites More sharing options...
