bB Tricks Thread
28 replies to this topic
#1 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 8,955 posts
Posted Mon Mar 4, 2013 9:54 PM
Basically, if you've come up with a novel technique for code ease, speed, size or economy of variables post it here. Examples are worth a thousand words.
Oh, and don't be shy of posting on techniques at are only SLIGHTLY different. Every viewpoint or take on a problem counts.
My first try?
TheLoon Tip #1 (EASE OF CODING) - Constants for colors.
Not everyone remembers $0E is white. Using constants to pick colors can be easier than constantly flipping through VisualbBs chart. Also, it lends greater readability to your fellow coders should they peruse your code. A further use would be to have a comparable set of constants for both NTCS and PAL. Choosing between regions would be as easy as removing the color set for the opposite standard.
Here are my colors:
rem My 25 standard colors for NTSC
const _brown = $F2
const _pink = $3C
const _skyblue = $98
const _olive = $E4
const _lilac = $7A
const _aqua = $B8
const _orange = $38
const _blue = $86
const _red = $46
const _purple = $64
const _lime = $DA
const _gold = $2E
const _navy = $84
const _green = $C6
const _maroon = $42
const _yellow = $1E
const _fuchsia = $58
const _cyan = $A6
const _white = $0E
const _ltgray = $0C
const _silver = $0A
const _gray = $08
const _dkgray = $02
const _black = $00
const _tan = $FC
const _forestgreen = $D2
#2 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,688 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Mon Mar 4, 2013 10:04 PM
For me, trying to remember something like _lilac is harder than just selecting a color from either Visual batari Basic's color chart or from one of these color charts:
www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#colorchart
www.randomterrain.com/atari-2600-memories-tia-color-charts.html#ntsc_color_tool
This isn't exactly a trick, but I start variable aliases with one underscore and labels with two underscores. Then I don't have to worry if I'm using a keyword by mistake and I don't have to worry if a label has the same name as a variable alias.
#3 Gemintronic OFFLINE
Gemintronic
  • 8,955 posts
Posted Mon Mar 4, 2013 10:06 PM
@R.T. I like your style. If we're gonna comment on the tips we may as well try to add one of our own at the same time. The topic would get pretty dirty fast if we all called out the lunacy of my techniques :)
TheLoon Tip #2 (ECONOMY OF VARIABLES) - Boolean and tender
Variables are very scarce in bB. If something is either one state or another then you can use single bits out of a variable to store that state. making boolean variables is a two step process. First, we must use up a variable:
dim boolean = a
THEN we use defines to cut up our one variable into up to 8 true/false variables. The {0} through {7} part marks which bit in variable a to use.
def enemydir=boolean{0}
def canshoot=boolean{1}
def scrolling=boolean{2}
def heatseeking=boolean{3}
def youwon=boolean{4}
etc..
The one variable a was defined multiple times in different bit-wise places to give us up to 8 different boolean variables!
Remember: you must make your if .. then statements slightly different when using bitwise values. They look more like this:
rem If scrolling (boolean{2}) equals 1 (true) then scroll down.
if scrolling then pfscroll down
Notice we didn't say if scrolling = 1? We CAN, however declare scrolling = 1 to indicate scrolling should be true and scrolling = 0 for false. IF .. THEN statements just can't handle it the = 0/1 way. Another gotcha is that we cannot use constants for bitwise statements. So if scrolling = _false is out of the question (if _false is defined as a constant)
#4 RevEng OFFLINE
RevEng
  • 4,809 posts
  • Bitnik
Posted Mon Mar 4, 2013 10:21 PM
Nice topic, theloon!
RevEng Tip #1 - organising a large multi-bank game
When I'm working on a large multi-bank game, I add descriptions of what each bank does to the bB compile messages. It allows me to see at a glance which part of the program is getting tight on space, and allows me to quickly jump to the right bit of code I want by searching for the bank.
Here's an example of the description for the first bank in 21 Blue...
  asm
  echo " "
  echo "****** Starting a new pass..."
  echo " "
  echo "BANK 1: main game loop."
end
...and the sample output from compiling 21 Blue...
106 bytes of ROM space left in bank 1
BANK 2: girl data, game+minigame vblank code. (soundfx, score adjust)
51 bytes of ROM space left in bank 2
BANK 3: girl data, titlescreen basic code.
112 bytes of ROM space left in bank 3
BANK 4: girl data, player/dealer hand score updater, draw boss-dealer.
18 bytes of ROM space left in bank 4
BANK 5: girl data, main blakjuko code.
62 bytes of ROM space left in bank 5
BANK 6: titlescreen kernel.
20 bytes of ROM space left in bank 6
BANK 7: kernel to draw chat, cards, etc.
148 bytes of ROM space left in bank 7
BANK 8: girl data, blakjuko utility routines, atarivox routines.
54 bytes of ROM space left in bank 8
Build complete.
#5 Random Terrain OFFLINE
Random Terrain
  • 28,688 posts
    Replay Value
    Nonlinear
Posted Mon Mar 4, 2013 10:24 PM
I ran into all kinds of weird, pull your hair out, suicide-inducing problems when using def in a very large program, so I gave up and use dim instead. Here's an example:
   rem  ****************************************************************
   rem  *
   rem  *  Create aliases for variables.
   rem  *
   rem  `
   rem  `  (You can have more than one alias for each variable.)
   rem  `
   rem  ````````````````````````````````````````````````````````````````
   rem  `  BitOp group 01.
   rem  `
   dim _BitOp_Group_01 = i
   rem  `  Tells program when to flip the playfield colors.
   rem  `
   dim _Bit0_Color_Flip = i
   rem  `  Keeps collision detection from registering more than once.
   rem  `
   dim _Bit1_Player_Hit_Wall = i
   rem  `  Turns the bonus item on or off.
   rem  `
   dim _Bit2_Bonus_On_Off = i
   rem  `  Channel 0 sound effects (group 1).
   rem  `
   dim _BitOp_Sound_Ch_0_Group_01 = j
   rem  `  Player hit wall sound effect.
   rem  `
   dim _Bit0_Sound_Wall_Hit = j
   rem  `  Channel 01 sound effects (group 1).
   rem  `
   dim _BitOp_Sound_Ch_1_Group_01 = k
   rem  `  Bonus item appearance sound effect.
   rem  `
   dim _Bit0_Sound_Bonus_Appear = k
Here's a small example in use:
   if _Bit0_Sound_Wall_Hit{0} then goto __Sound_Effect_Wall_Hit
Here's a tip for this thread. Instead of underlining title text, which usually means link on the internet, use larger, bold text.
So instead of this:
TheLoon Tip #3 (SPEED) - Eventually, everyone's survival rate falls to 0
You'd use this:
Or this:
Or this:
#6 Gemintronic OFFLINE
Gemintronic
  • 8,955 posts
Posted Mon Mar 4, 2013 10:35 PM
According to R.T.s guide some variables get cleared after each DRAWSCREEN. We can actually use that expectation to simplfy and speed up our code.
For instance, if we assume a variable is used up as a counter (dim counter = a) and an alarm for an animation is defined as such (def march = counter{4}) we can do this:
if march then REFP0 = 8 : REFP1 = 8
So, every time the forth bit of counter gets set to 1 we change the reflection flag on player0 and player1. When march is 0 (false) DRAWSCREEN already makes the reflection = 0 for both sprites without us doing any more code ourselves.
#7 RevEng OFFLINE
RevEng
  • 4,809 posts
  • Bitnik
Posted Mon Mar 4, 2013 10:48 PM
RevEng Tip #2 - display how much rom a section of code uses
Putting a couple of labels around the section of code and a single line of asm will allow you to see how many bytes the routine takes.
  rem ** checking how much space a particular bit of code uses
  player0:
  %11111111
  %11111111
  %11111111
  %11111111
end
  player0x=80
  player0y=40
mainloop
  COLUP0=$98
  drawscreen
control
  if joy0left then player0x=player0x-1
  if joy0right then player0x=player0x+1
  if joy0up then player0y=player0y-1
  if joy0down then player0y=player0y+1
controlend
  goto mainloop
  asm
  echo "DEBUG: the joystick control uses ",(.controlend-.control)d," bytes."
end
Here's the compilation output...
Starting build of scratch.bas
batari Basic v1.01 (C)2005-2007
2600 Basic compilation complete.
DEBUG: the joystick control uses 32 bytes.
2809 bytes of ROM space left
Build complete.
#8 Gemintronic OFFLINE
Gemintronic
  • 8,955 posts
Posted Mon Mar 4, 2013 11:00 PM
@R.T. I'll defer to your professional web expertise. No underlines.. sigh :)
TheLoon Tip #4 (ECONOMY OF VARIABLES) - You don't hafta work for the TSA to screen
If you lay out your game correctly you can use the playfield for both visual queues and variable use. For instance, in my game M.M.S.B.C. II the topmost playfield pixels represent the main heath bar:
playfield:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX <--
...........X..................X.
..........XXXXX..............X.X
....................X...........
X..XXX.X.X.X..XX.X.X.X.X..X..XXX
X..X.X.X.X.X.X...X.X.X.X..X..X..
X..X.X.X.X.X..X..X.X.X.X..X..XX.
X..X.X.X.X.X...X.X.X.X.X..X..X..
XX.XXX.XXX.X.XX...X..X.XX.XX.XXX
end
As the players lose hit points the rightmost pixels get turned off until even the very leftmost pixels are gone. AT THAT POINT the var0 (top-leftmost 8 pixels) should equal 0.
if var0 = 0 then goto game_over
Notice I didn't have to use a variable for that main health stat!
#9 Gemintronic OFFLINE
Gemintronic
  • 8,955 posts
Posted Tue Mar 5, 2013 4:15 AM
TheLoon Tip #5 (GRAPHICS) - Flip the ball over for massive damage!
While the missiles and balls can only be one rectangular shape at a time we can alternate between shapes to create distinct objects! Once again this example relies on a variable called counter that increments once every main game loop. Since counter{0} is true every other frame we can use that to change our missile/ball shape quickly enough so that our eyes see a more complicated shape - in this case a sword with hilt!
draw_weapon
 bally = bally - 2
 if bally < 4 then bally = 0 : ballx = 0 : return
 if counter{0} then goto shaft else goto hilt
shaft
 ballx = ballx + 1
 bally = bally + 2
 CTRLPF = $11
 ballheight = 9
 return
hilt
 ballx = ballx - 1
 bally = bally - 2
 CTRLPF = $21
 ballheight = 1
 return
There are one or two gotchas with this technique. First off, any area of the sword that isn't overlapping both frames of animation will be semi-transparent. So, count on the edges of the hilt and tip/handle of the sword to be darker than the middle. In addition, collision will be effected due to the actual ball/missile being shifted around each frame.
#10 RevEng OFFLINE
RevEng
  • 4,809 posts
  • Bitnik
Posted Wed Mar 6, 2013 8:11 PM
RevEng Tip #3 - (GRAPHICS) cheap transporter/yars safety zone/explosion with the standard kernel
Originally from this thread. (well, originally from Yar's Revenge)
You can point the player data pointers to random game code, and set the height as you like. If you test this with a an empty program the effect will be be more solid, but as your bank fills up with code the effect will become more randomish.
datastart
  const datastarthi=(#>.datastart)
  player0x=50
  player0y=90
  player0height=90
  player0pointerhi=datastarthi
gameloop
  rem divide by two to avoid hotspots in bank-switched games...
  player0pointerlo=rand/2
  COLUP0=rand
  REFP0=rand
  NUSIZ0=$07
  drawscreen
  goto gameloop
#11 Gemintronic OFFLINE
Gemintronic
  • 8,955 posts
Posted Tue May 7, 2013 1:13 AM
TheLoon Tip #6 (EDITOR) - Import Changes back into VisualbB
Sometimes you may start out creating a sprite or playfield in the VisualbB editor but end up hand tweaking things until your code and VisualbB don't match. Fear not! You can manually re-import the changes with ease!
1. Select the entire pfcolors: and playfield/playercolors: section for your sprite or playfield in your code and copy them to the clipboard. Make sure you copy *just* the bare two sections mentions and not any extraneous code.
2. Open your original sprite/playfield in VisualbB.
3. Right mouse-click on your selected sprite.spr or playfield.pla filename and hit "View in Notepad..."
4. In notepad clear out the old contents and PASTE the contents of the clipboard.
5. SAVE in Notepad.
6. Back in VisualbB right mouse-click on the sprite.spr or playfield.pla we were working with and hit Reload.
BAM! Now our hand-tweaked items are back in the full editor for great justice.
#12 Random Terrain OFFLINE
Random Terrain
  • 28,688 posts
    Replay Value
    Nonlinear
Posted Tue May 7, 2013 1:20 AM
You can also save your program with a different name, then right click on it in the Project Explorer and select Generate Items From Code. You'll have a fresh, updated batch of sprites and playfields to play with.
#13 Gemintronic OFFLINE
Gemintronic
  • 8,955 posts
Posted Tue May 7, 2013 1:25 AM
Sounds like a different, but useful tip in itself!
#14 Random Terrain OFFLINE
Random Terrain
  • 28,688 posts
    Replay Value
    Nonlinear
Posted Tue May 7, 2013 2:33 AM
It's very useful if you change a lot of sprite frames in your program without using the sprite editor, then wish to edit them with the sprite editor later.
#15 abaudrand OFFLINE
abaudrand
    Chopper Commander
  • 236 posts
Posted Wed Jun 19, 2013 2:58 PM
Ive read the tip 1 of revenge with the echo command but I lack knowledge how I can use it to write the state of a variable. I would like to see which number is stored on a certain variable thru the game by using the echo command several time to check if the number is constant or modified by something I m missing. Could someone help?
#16 Random Terrain OFFLINE
Random Terrain
  • 28,688 posts
    Replay Value
    Nonlinear
Posted Wed Jun 19, 2013 4:05 PM
If you'd like to have the value of a variable displayed in the score, you can use this:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#testvariables
#17 RevEng OFFLINE
RevEng
  • 4,809 posts
  • Bitnik
Posted Thu Jun 20, 2013 5:42 AM
Echo outputs info at compile-time, not run-time. No code gets put into your game when you add an echo statement.
As RT suggests, you need to use the score or stella's debug facility to get run-time info.
#18 abaudrand OFFLINE
abaudrand
    Chopper Commander
  • 236 posts
Posted Thu Jun 20, 2013 1:03 PM
thanks for the help guys :) I ve seen the page you mention RT but I hoped something prior to play the game on stella.
#19 Random Terrain OFFLINE
Random Terrain
  • 28,688 posts
    Replay Value
    Nonlinear
Posted Thu Jun 20, 2013 2:14 PM
I'm not sure what you are saying, but I wasn't just linking to a page, I was linking to a specific place on the page that has code you can use in your program to run using Stella.
#20 iesposta OFFLINE
iesposta
  • 3,738 posts
  • Retro-gaming w/my VCS
Posted Tue Sep 10, 2013 4:37 PM
iesposta Tip #1 (MUSIC) data reduction.
If the Control channel [aka Tone, Voice, Distortion] doesn't change in your data for AUDC0 and/or AUDC1,
set the AUDC0 = (that value) and/or AUDC1 = (value) and remove all the repeated channel numbers (and any 0's) from the data statement.
Any Control value with a volume of 0 is still Volume 0, so 0, 0, 0 or 0, 4, 0 act the same.
Example saved (approximately) 57 bytes (the value 12 in Channel 0 and the value 4 in Channel 1):
Before:
   rem  *  Play channel 0
   AUDV0 = musicData[x] : x = x + 1
   AUDC0 = musicData[x] : x = x + 1
   AUDF0 = musicData[x] : x = x + 1
   rem  *  Play channel 1
   AUDV1 = musicData[x] : x = x + 1
   AUDC1 = musicData[x] : x = x + 1
   AUDF1 = musicData[x] : x = x + 1
   rem  *  Set duration
   duration = musicData[x] : x = x + 1
   goto GotMusic
   rem  *  Music Data Block
   rem  *  Format:
   rem  *  v,c,f (channel 0)
   rem  *  v,c,f (channel 1)
   rem  *  d
   rem  *
   rem  *  Explanation:
   rem  *  v - volume (0 to 15)
   rem  *  c - control [a.k.a. tone, voice, and distortion] (0 to 15)
   rem  *  f - frequency (0 to 31)
   rem  *  d - duration
  data musicData
  4,12,19
  4,4,19
  24
  4,12,19
  4,4,17
  0,0,0
  16
  4,12,26
  4,4,14
  16
  4,12,19
  4,4,14
  0,0,0
  4,4,17
  4,4,17
  4,4,19
  16
  4,12,26
  4,4,17
  16
  4,12,29
  4,4,21
  16
  4,12,26
  4,4,21
  3,4,21
  2,4,21
  1,4,21
  0,0,0
  0,0,0
  0,0,0
  16
  2,12,14
  0,0,0
  16
  255
end
   goto GotMusic
After:
   rem  *  Check for end of current note
   duration = duration - 1
   if duration>0 then GotMusic
   rem  *  Check for end of data
   if musicData[x]=255 then duration = 1 : x = 0 : goto GotMusic
   AUDC0 = 12
   AUDC1 = 4
   rem  *  Set duration
   goto GotMusic
   rem  *  Format:
   rem  *  d
   rem  *
   rem  *  Explanation:
   rem  *  d - duration
  data musicData
  4,19
  4,19
  24
  4,19
  4,17
  0,0
  16
  4,26
  4,14
  16
  4,19
  4,14
  0,0
  4,17
  4,17
  4,19
  16
  4,26
  4,17
  16
  4,29
  4,21
  16
  4,26
  4,21
  3,21
  2,21
  1,21
  0,0
  0,0
  0,0
  16
  2,14
  0,0
  16
  255
end
   goto GotMusic
#21 kdgarris OFFLINE
kdgarris
    Moonsweeper
  • 333 posts
Posted Wed May 24, 2017 12:09 PM
This is small, but variable-saving.  The playerNx and playerNy variables can be used as part of fixed point variables.  I was surprised that this worked, but I guess they are variables like any other.:
   dim EnemyXPos = player1x.f
   dim EnemyYPos = player1y.g
#22 Random Terrain OFFLINE
Random Terrain
  • 28,688 posts
    Replay Value
    Nonlinear
Posted Wed May 24, 2017 12:18 PM
Yep, that's actually on the bB page, but you have to scroll down to the fourth example box to see it:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#fixedpoint
Maybe I should make it stand out somehow so people won't miss it.
#23 kdgarris OFFLINE
kdgarris
    Moonsweeper
  • 333 posts
Posted Wed May 24, 2017 12:43 PM
Perhaps, but me missing something like that is hardly unprecedented.  :-)  I did read the section on fixed point variables, but I must have missed that.
#24 iesposta OFFLINE
iesposta
  • 3,738 posts
Posted Sat Jun 17, 2017 10:55 AM
Optimizations to save cycles, get ROM space:
Put all same value declarations on one line (until compile errors out due to too many).
examples:
 player0x=0: c=0: d=0: missile1x=0: temp2=0: timer=0
 DFRACINC0=32: DFRACINC1=32: DFRACINC2=32: DFRACINC3=32: DFRACINC4=32: DFRACINC6=32
Technical explanation:
This
compiles into:  load register with 32, set all the data-fetchers to 32
This
 DFRACINC0=32
 DFRACINC1=32
 DFRACINC2=32
 DFRACINC3=32
 DFRACINC4=32
 DFRACINC6=32
compiles into: load register with 32, set data-fetcher 0 to 32, load register with 32, set data-fetcher 1 to 32, load register with 32, set data-fetcher 2 with 32, load register with 32, set data-fetcher 3 to 32, load register with 32, set data-fetcher 4 to 32, load register with 32, set data-fetcher 6 to 32
See how efficient the first explanation is, and how wasteful the second explanation is?
#25 RevEng OFFLINE
RevEng
  • 4,809 posts
  • Bitnik
Posted Sat Jun 17, 2017 11:19 AM
RevEng Tip #4 - (CYCLES) only run things when you need to, with a simple scheduler
Not everything needs to happen at 60Hz/50Hz in your game. Some things can happen every other frame, or every 4th frame. Balance when these things happen, to make the most of available cycles...
mainloop
  frame=frame+1
  rem ** alternate "goat AI" routine with "check goat collision", every other frame
  rem ** (frame&1 is always either 0 or 1)
  if (frame&1)=0 then gosub GoatAI
  if (frame&1)=1 then gosub CheckGoatCollision
  rem ** spread movement logic for 4 enemy trolls across 4 frames
  rem ** (frame&3 is either 0, 1, 2, or 3)
  if (frame&3)=0 then gosub Troll1Logic
  if (frame&3)=1 then gosub Troll2Logic
  if (frame&3)=2 then gosub Troll3Logic
  if (frame&3)=3 then gosub Troll4Logic
