Jungle Adventure (Was: My next project, Pitfall type game DPC+)
51 replies to this topic
#1 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
  • 10 PRINT CHR$(205.5+RND(1));
Posted Wed Mar 27, 2013 6:21 PM
I've been playing around with the DPC+ kernel for weeks now and would like to use it for my next project. I usually start my projects with a basic game engine and then see if I can come up with a good game concept around it, which is what this is. I have a hard drive full of abadoned projects just like this one that just didn't work out. This demo works perfectly in Stella but loads with a blank black screen on a Harmony cart on real hardware, and I was hoping someone more knowledgable than me might be able to figure out why.
This game is a platformer and there are 15 screens that you can freely roam left to right. My idea was to have random treasures, enemies and ladders on each screen, and all the rooms would connect in a large maze-like world. I don't have any other ideas past that, this is just a proof of concept at this point and the sprites are just placeholders. The ladders probably won't work correctly on any of the screens beyond the initial screen, I haven't gotten that far yet. I've really only worked on the first screen. I'd just like help figuring out why it doesn't seem to work on the Harmony.
Thanks,
Steve
EDIT: The latest version is titled "jadv" (August 2013) and it will run on the Harmony.
#2 iesposta OFFLINE
iesposta
  • 3,876 posts
  • Retro-gaming w/my VCS
Posted Wed Mar 27, 2013 8:48 PM
There is no such thing as "bank 7." Remove that.
Using " return thisbank" will save hundreds of bytes.
Just 2 quick tips. Haven't even played it yet or tried on real hardware.
#3 Cybearg OFFLINE
Cybearg
    Dragonstomper
  • 950 posts
Posted Thu Mar 28, 2013 2:16 AM
If you make the character attack with poisonous farts, you could call it "Poots and Ladders"
#4 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,291 posts
Posted Thu Mar 28, 2013 2:19 AM
I think you need to go back to sleep, man. 4am is no time to try to provide relevent advice :) R.T. handles the scat related comments here.
#5 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Thu Mar 28, 2013 10:31 AM
:lol:
#6 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Thanks, I forgot about that. I removed 'bank 7'. I'll also make sure and update return calls as needed.
#7 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Thu Mar 28, 2013 10:34 AM
I haven't checked it on real hardware again, but I made a few changes this morning. You can now navigate everywhere on the map and all of the ladders work. I'm assuming the Harmony compatibility problem is just a simple mistake on my part. Now it's time to think about how to make this into an actual game. :)
#8 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Thu Mar 28, 2013 12:30 PM
I noticed that the player would occassionally get stuck on a ladder. This revision fixes that. I'll probably hold off on posting another revision until I've fleshed this out a bit more as an actual game.
#9 Gemintronic OFFLINE
Gemintronic
  • 9,291 posts
Posted Fri Mar 29, 2013 6:17 AM
What's to figure out? This is obviously the game between Pitfall 2 and Super Pitfall :)
#10 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Fri Mar 29, 2013 2:36 PM
Ha. Yeah, this concept seems to be leading to a Pitfall-type sequel. With that in mind, I changed the graphics to more resemble Pitfall. No other changes, I was just playing around with background graphics and colors. It still doesn't work on the harmony and I haven't figured out why yet.
#11 iesposta OFFLINE
iesposta
  • 3,876 posts
Posted Sat Mar 30, 2013 6:20 AM
You have a "return otherbank" when you are only in bank2, should be "return thisbank" and all "return" should be "return thisbank"
If that still doesn't make it run on the Harmony, put "DF0FRACINC = " etc. right before "drawscreen" It is in a gosub.
#12 iesposta OFFLINE
iesposta
  • 3,876 posts
Posted Sat Mar 30, 2013 7:07 AM
You get 216 bytes back changing return to "return thisbank"
At the top, after the rem statements, put (starting each line with a space):
bank 1
temp1=temp1
set tv ntsc
set kernel DPC+
set smartbranching on
set optimization inlinerand
set kernel_options collision(playfield,player1)
goto Start bank2
My compile now shows bytes left. 391 left in bank 2. With return thisbank 607 bytes left.
283 bytes left in graphics bank. This is my problem with Donkey Kong. Lots of playfield data.
If I or cybearg or anyone could figure out how to use pointers we could PUSH data statements right to the playfield using rom banks for data and getting back graphics bank space.
#13 iesposta OFFLINE
iesposta
  • 3,876 posts
Posted Sat Mar 30, 2013 7:44 AM
I never set playerXheight. Is this needed?
rem it out saves 40 bytes.
It gets into the asm file without setting it. Maybe it is useful if you wanted a height larger or smaller than its data? IDK
You have (had) players 1, 2 & 3 as a ladder.
You can define them all once, (but colors still need player1color: player2color: player3color:)
Player1-3:
%10000001
%10000001
%11111111
etc.
end
I have lots of programming tips, I just wish I could get a whole game made :)
#14 iesposta OFFLINE
iesposta
  • 3,876 posts
Posted Sat Mar 30, 2013 7:57 AM
Another tip:
You can define global variables in bank 1. I usually set some, and the score color pretty much fills it.
See the bottom of the pic - you have 93 bytes.
They use up fast with just a few variables and sometimes it may stop reporting bytes left, but it is a little space you can use.
#15 Byte Knight OFFLINE
Byte Knight
  • 1,126 posts
  • Intellivision / Apple II
Posted Sat Mar 30, 2013 9:22 AM
Gotta love a Pitfall-style game! I think I recognize the player. ;)
Quick question - how did you make the playfield extend to the horizontal edges of the screen? Is this a feature of 1.1d?
#16 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Sat Mar 30, 2013 12:12 PM
Another tip:
Thank you for all the useful tips, iesposta! I will definitely review everything you've mentioned and make some changes.
I was being lazy using the cave in character sprite. I didn't want to take the time to create a new animated sprite with this demo, I was intending on changing it. The platforms stretch out to the sides of the screen using background colors, it's not actually using the playfield. I like the effect of it looking like a stretched screen. :)
#17 bogax OFFLINE
bogax
    Dragonstomper
  • 787 posts
Posted Sat Mar 30, 2013 12:38 PM
I know nothing of DPC+
Are you trying to minimize code size?
I just assumed you weren't worried about it for a demo.
Theres several places you could squeeze out a few bytes.
one bit of code puzzles me.
  if collision(player0,playfield) then skip_ud
  if collision(player0,playfield) && player0y=71 then player0y=player0y+1
  if collision(player0,playfield) && player0y=111 then player0y=player0y+1
  if collision(player0,playfield) && player0y=151 then player0y=player0y+1
  if !collision(player0,player1) then skip_ud
dontskip
  p0_y = 0
  if joy0up then p0_y = 255
  if joy0down then p0_y = 1
  player0y = player0y + p0_y
skip_ud
The first if statement means the next three will
never be true.
Your playfields are so simple I think you could
draw them with lines and save some bytes.
It would be a lot slower I'd guess.
#18 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Sat Mar 30, 2013 1:16 PM
dontskip
p0_y = 0
skip_ud
never be true.
It is just a demo, and you are right about that section of code. I tend to try something out and then never clean up, what you pointed out does seem to be redundant. There are many optimizations that could be made. As the code is written now, the different playfields are necessary for going up and down the ladders & vines. There is an "invisible" hole where you go up and down, you can't see it because the background color hides the hole in the playfield.
#19 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Sat Mar 30, 2013 1:42 PM
There is a bug in the latest posted bin (that changed the colors), you may get stuck on a ladder on the top platform. There's definitely a whole lot of code optimization and changes that need to be made. This demo is a long way from being a playable game.
#20 iesposta OFFLINE
iesposta
  • 3,876 posts
Posted Sat Mar 30, 2013 4:31 PM
With my above changes, it runs on my Harmony.
The player man stops and starts moving left or right what seems like every third animation. In Stella it is just a slight pause.
When you say it doesn't run on Harmony, do you mean not at all?
#21 stephena OFFLINE
stephena
  • 3,331 posts
  • Stella maintainer
Posted Sat Mar 30, 2013 4:57 PM
Just a reminder that the DPC+ support in Stella isn't quite the same as on the Harmony. In particular, if you have a section of ARM code that would run past the allowable time on the Harmony, it would probably result in a corrupted image, slowdowns, or some other related issue. But in Stella, it would probably look fine, or just be a slight pause (like you're seeing). This is because Stella doesn't (yet) have any concept of how long the ARM code takes to run WRT the 6507, and essentially always runs in zero CPU elapsed time. This is on the TODO list to fix, and is something to always be aware of when developing DPC+ games.
#22 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Sat Mar 30, 2013 5:01 PM
Yes, I meant not at all. It rolls the screen for a second or two and then displays a blank black image. I'm glad your changes at least allow it to show up on the screen on real hardware. :)
#23 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Sat Mar 30, 2013 5:05 PM
Thank you for explaining that, Stephen. One of my demos from a few weeks ago in the "Getting started with DPC" thread works initially but after playing for a short while goes to a blank black screen also on the Harmony. I'm sure you have a very long to-do list, and I'm very much looking forward to your distella integration. :)
#24 Byte Knight OFFLINE
Byte Knight
  • 1,126 posts
Posted Sat Mar 30, 2013 11:30 PM
Ahhhh - sneaky!
#25 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,884 posts
Posted Mon Apr 1, 2013 5:41 PM
Could you post your modified source that works on the Harmony? I implemented your suggested changes and I'm still having trouble. I'd like to compare what you did to what I did. I made a few more minor changes. Some animation & the pitfall scorpion were added, a few bug fixes, and I moved the specific room changes to individual subroutines. There's no way everything would ultimately fit in bank 2. The score also displays which room number you are in (0-15), that makes it a bit easier for development.
