60 fps video using SIDE 2
219 replies to this topic
#126 Wrathchild ONLINE
Wrathchild
  • 1,949 posts
Posted Sat May 28, 2016 7:48 AM
I have been experimenting with the encoders and although still more investigation required to make improvements on the colour mapping, thought I'd share some progress.
As described before in this thread, I attach these bin files as a SIDE 2 Hard Drive image within Altirra and then run associated player.
I haven't yet tried moving an image to a CF card and running this on my 800's Incognito so feedback on how they look on a TV would be helpful.
Enjoy,
Mark
Edited by Wrathchild, Sat May 28, 2016 7:52 AM.
#127 rdea6 ONLINE
rdea6
  • 2,668 posts
Posted Sat May 28, 2016 2:45 PM
NTSC Samples..  I ran all of them on Altirra, but only the all intro on CF card and real hardware.  On the 800XL there was static (noise) and a small amount of flickering.  It was way to short for good feel of difference between these examples and the one put out by the original thread poster.  Sound voices and colors were OK.
I think I will merge all BINS and put on CF card for longer play if possible.
Edited by rdea6, Sat May 28, 2016 2:53 PM.
#128 grzybson OFFLINE
grzybson
    Space Invader
  • 13 posts
Posted Sat Mar 18, 2017 9:13 AM
I'm sorry for digging up this old topic, but I've lost to VirtualDub. I've downloaded PAL package posted by phareon, compiled encoders using Codeblock with MinGW, but I don't know how to configure properly the encoders and set the encoding options metioned by phareon. Can anyone provide me a detailed instruction? Screenshots of Virtual Dub config would be very appreciated :)
Encoding parameters are: 160x192 4:2:0 progressive YCbCr at 49.86 fps, 15.557KHz 8-bit mono audio.
#129 Wrathchild ONLINE
Wrathchild
  • 1,949 posts
Posted Sat Mar 18, 2017 10:01 AM
Its been a while since I played with this, but these might help?
#130 Wrathchild ONLINE
Wrathchild
  • 1,949 posts
Posted Sat Mar 18, 2017 12:50 PM
These are (more or less) the steps to take:
1) Pick and prepare (if required, e.g. crop to a useful length) your chosen video.
2) Load this up in VirtualDub
3) Load the vdscript for the conversion
4) Run "save as avi..." from the File menu. I choose a consistent filename stub, <title>_<region>, e.g. "tron_ntsc", so the file is "tron_ntsc.avi".
5) Now load the avi produced (File/Open video file...)
6) From the file menu, choose Export/Raw Audio.... I append the stub with "_au" and no extension, e.g. "tron_ntsc_au"
7) From the file menu, choose Export/Raw Video.... I append the stub with "_au" and no extension, e.g. "tron_ntsc_av"
Format: 4:2:0 YCbCr planar, R.60.1, 8-bit, Y:16-235 centred
Secondary plane order: Cb/Cr (V/U)
Scanline alignment: 4 bytes
Vertical orientation: Top-down
8 ) From a command prompt, encode the audio: "encaudio60 ntsc_au < tron_ntsc_au"
9) Then encode the video: "encvideo60n ntsc_av < tron_ntsc_av"
10) Combine the to files: "mux60n ntsc_av ntsc_au tron_ntsc.bin"
You now have the hard drive image that can be mounted as a Side 2 Hard Disk within Altirra.
From the "File/Boot Image...", load the "movplay60n.obx" and the video should play.
Edited by Wrathchild, Sat Mar 18, 2017 1:07 PM.
#131 grzybson OFFLINE
grzybson
    Space Invader
  • 13 posts
Posted Sat Mar 18, 2017 1:05 PM
Thanks Wrathchild! Scripts were enough for me to move forward, but I'll carefully read the instructions you posted as well.
As it appeared, I made much more mistakes:
  • When configuring external encoders in virtual dub, I forgot to surround command line parameters with double quotes
  • I used unstable DirectShow input plugin to import MP4 video. So I decided to switch to ffmpeg plugin for virtualdub, but it didn't work on win XP
After that I successfully converted video and played it under Altirra. The converted file soon will be available here (it's PAL video): https://1drv.ms/f/s!...ep1YlMp3VD_SOOg
Then I decided test it on real hardware. I have SIDE version 1 and two CF cards: Kingston Elite Pro 1GB (the blue one) and Alan - Bradley Industrial Standard 128MB card (yes, it's from the PLC manufacturer). To move data to I used HDDRawCopy on Windows.
Immediately after running the MOVPLAY.XEX on Atari I receive message "IDE Command error 5000 00000000". However, after few restarts of Atari it played! The video is superb, but the audio.. disappointing. During whole movie I can hear loud sound similar to shooting gun making it unpleasant to listen to. Check the recording I made during playback with my phone - it's also on Onedrive (or soon will be)
So I questions are:
  • what can be done with "IDE command error"?
  • is there any chance two remove that loud "gun-like" noise from audio?
#132 phaeron OFFLINE
phaeron
  • 2,458 posts
Posted Sat Mar 18, 2017 3:51 PM
Machine-gun sounds suspiciously like NTSC and PAL toolchains might have been mixed. The audio track in particular is formatted differently. Make sure you're using all PAL/50Hz tools and player for a PAL system.
#133 grzybson OFFLINE
grzybson
    Space Invader
  • 13 posts
Posted Sat Mar 18, 2017 4:05 PM
I have used from post #62 of this topic: http://atariage.com/...-3#entry2747884
The player comes from post #98 since it seems to be able to detect PAL/NTSC http://atariage.com/...-4#entry2796714
For conversion I used PAL script attached by Wrathchild.
Which tool did I choose wrong?
EDIT:
And most important, what is the reason the IDE error?
Edited by grzybson, Sat Mar 18, 2017 4:08 PM.
#134 grzybson OFFLINE
grzybson
    Space Invader
  • 13 posts
Posted Sun Mar 19, 2017 12:41 PM
Check out these two recordings - one I a sample from Scorpions video I made, another one is from Skyfall by Wrathchild:
https://1drv.ms/u/s!...F4Y3ttr9PLORLdQ
https://1drv.ms/u/s!...G0asnHZZL2nocCA
These were made using mobile phone, so they are quiet. But when you play it on the earphones, you can easly hear that the level of noise is much more higher than the vocals. I am aware that some white noise is inevitable when downsampling, but when played on Altirra the difference is not so huge.
Another interesting idea came up on AtariArea. My friend Pinokio tested the video I produced and he claims that the quality of audio track is superb. He thinks that it may be caused be the CompactFlash used. He says that he had tried a dozen of cards before he found the two of them that gave satisfying results.
#135 a8isa1 ONLINE
a8isa1
  • 1,460 posts
Posted Sun Mar 19, 2017 2:31 PM
I can only watch your video via Altirra as I don't own any PAL Ataris but I really enjoyed seeing it all the same.  The sound *is* quite good.
This is the first rock video I've ever seen for Atari!  I hope there will be more.  Thanks.
For my own conversions I used the linux tools mencoder and sox and perhaps audacity.  I would love to try VirtualDub but didn't then and again I don't have now a Windows machine.
I could never get rid of some ugly clipping sounds and white noise using the aforementioned tools.   I'm sure it's more my lack of understanding the cause of the problem and my non-expert use of the tools than my choice tools.
p.s. Thanks for pointing the dual video standard player, MOVPLAY.XEX.  I had missed seeing this before now.
-SteveS
Edited by a8isa1, Sun Mar 19, 2017 2:32 PM.
#136 grzybson OFFLINE
grzybson
    Space Invader
  • 13 posts
Posted Sun Mar 19, 2017 2:38 PM
Believe me, there will be more :) And when we find the solution for the audio, I am thinking of converting full length feature film :)
I don't complain about the audio quality on the emulator, I understand the white noise is inevitable. But check the short WAVE recordings I posted earlier (I recommend using ear phones). On real hardware the noise is much more louder than vocals, unlike the Altirra.
#137 a8isa1 ONLINE
a8isa1
  • 1,460 posts
Posted Sun Mar 19, 2017 5:28 PM
Someone requested Dragon's Lair video.   I had actually converted the file many months earlier than the request having found it on archive.org but never had storage online.   Not sure how long I'll keep it online now but here it is.
Oh, it's NTSC format and it's about 700MB
it's a raw image suitable for Altirra SIDE 2 emulation or real CF card.
-SteveS
Edited by a8isa1, Sun Mar 19, 2017 5:30 PM.
#138 rdea6 ONLINE
rdea6
  • 2,668 posts
Posted Sun Mar 19, 2017 10:10 PM
Dragon's Lair video is amazing through emulation...  I loaded a 1gig CF card with the file (2nd CF card WORKS) with real hardware and Side 1 and side2 carts..  Some slight static and or popping noise about every 5-6 seconds but not bad enough to hinder the volume so I can hear the sounds.. while viewing the movie.
#139 a8isa1 ONLINE
a8isa1
  • 1,460 posts
Posted Mon Mar 20, 2017 8:14 AM
I had one more video on this laptop.   Can't get any others until I repair the corruption on this laptop and/or get the linux box back up and running.
Shuttle - 103 MB
-SteveS
#140 Wrathchild ONLINE
Wrathchild
  • 1,949 posts
Posted Mon Mar 20, 2017 8:21 AM
Last May when I looked at this I'd found the Dragon's Lair video with a difference sequence.
Also at that time I'd experiment with that different form of colour matching.
Here are links to the NTSC and PAL versions I've recreated today.
I've targeted the AuthenticNTSC and OlivierPAL palettes (if replaying in Altirra) and so hopefully they'll look on on real h/w too.
Edited by Wrathchild, Mon Mar 20, 2017 8:21 AM.
#141 Gunstar ONLINE
Gunstar
    Gunstar
  • 9,078 posts
Posted Mon Mar 20, 2017 11:48 AM
Will these players and videos work on a MyIDE 2? I have mine set up via SpartaDOS and I've been told it pretty much works like a SiDE2 this way, but I also have the normal MyDOS & MyBIOS too.
#142 a8isa1 ONLINE
a8isa1
  • 1,460 posts
Posted Mon Mar 20, 2017 12:47 PM
Yes, they can.   A year or two ago I edited or patched MOVPLAY60N (probably badly) for MyIDE II but I don't remember if I posted the file.  I'll try to find it
The newer player MOVPLAY can be edited as well.
Just a reminder.  A CF card has to be dedicated for each video.  It won't be usable for normal MyIDE II usage.
-SteveS
Edited by a8isa1, Mon Mar 20, 2017 12:48 PM.
#143 grzybson OFFLINE
grzybson
    Space Invader
  • 13 posts
Posted Mon Mar 20, 2017 4:18 PM
What CF cards (manufacturer, model, capacity, approximately year of production) do you use for video playback?
#144 a8isa1 ONLINE
a8isa1
  • 1,460 posts
Posted Mon Mar 20, 2017 5:21 PM
1GB Dane Electric and 2GB SanDisk standard both at least a dozen years old, before speed multiplier markings were added.
-SteveS
#145 Wrathchild ONLINE
Wrathchild
  • 1,949 posts
Posted Tue Mar 21, 2017 5:33 AM
I've had the chance to try this on my 800's Incognito and have to say that it looks better on a TV than through Altirra (which is still good) so would recommend that to anyone!
Some pics attached too. That isn't glare on the tank shot but as they get activated.
For playback I used the attached MovPlay, rebuilt with the altered IDE_BASE (I run it from an disk mounted as D1 on SIO2SD).
The card I have is a Jessops branded 256MB but reads as Hitachi V3.3.0.0 under Fdisk on the A8.
Enjoy, Mark
#146 Wrathchild ONLINE
Wrathchild
  • 1,949 posts
Posted Tue Mar 21, 2017 9:47 AM
Regarding SD cards, I've tried the same binary (Strange Dawn intro) on the 256MB and that was OK too but when tried on a smaller 64MB "I.T. Works" card (shown as "CHH" in Fdisk) the sound is swamped with buzzing and so therefore it appears the choice of card is factor, but what is going on? The playback code must be receiving the right data values as the graphics are output correctly, so could there actually be interference generated by the CF card itself and being picked up by the audio output or circuitry?
#147 Wrathchild ONLINE
Wrathchild
  • 1,949 posts
Posted Tue Mar 21, 2017 3:54 PM
And finally, I've made a video to demonstrate the vividness of what is actually shown on the TV.
(I'd forgotten to turn the volume up a bit louder however the tune sounds good too!)
Edited by Wrathchild, Tue Mar 21, 2017 4:11 PM.
#148 grzybson OFFLINE
grzybson
    Space Invader
  • 13 posts
Posted Wed Mar 22, 2017 12:26 PM
Wow, the video is awesome. Colours so bright, vivid and audio so much better than what I can achieve.
On weekend I'm going to visit Zaxon (since we live in the same city). We are going to test all of his CF cards to find the perfect one.
Also visit my Onedrive (link is in one of previous post), I uploaded some new videos.
#149 Gunstar ONLINE
Gunstar
    Gunstar
  • 9,078 posts
Posted Wed Mar 22, 2017 1:19 PM
I g
-SteveS
I guess I need to go get another CF card for videos then. Thanks! and looking forward to the MyIDE patch versions!
#150 Gunstar ONLINE
Gunstar
    Gunstar
  • 9,078 posts
Posted Wed Mar 22, 2017 1:22 PM
Thanks! As to looking better on the real hardware, I'm not surprised. Rastaconverter images looks much better on real hardware too, IMHO. Though I only have LCD monitor atm, so I can't say how good they look on an old interlaced CRT screen.
Enjoy, Mark
