Caterpiggle Posted August 6, 2013 Share Posted August 6, 2013 Does your ADAM mentioned how many watts using on ADAM disk drive with your PS ? Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 6, 2013 Share Posted August 6, 2013 For the original Coleco supplied Disk Drive Power Supply: INPUT: 120V 60Hz 50W OUTPUT: 9V AC 31 VA For the replacement Disk Drive Power Supply that is still being sold by eColeco and is pictured in the last post of the thread that i linked to: INPUT: 120V 60Hz 60W OUTPUT: 9.2 VAC 3.0 AMP 40 V.A. Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted August 7, 2013 Share Posted August 7, 2013 I found an exactly info. above ! on my Atari 1050 Power Supply, it is all matched and even the plug end is matched into back of ADAM disk drive ! The Atari part : C017945 9 V AC 31 VA 50 W It is prefect ! I will test on ADAM drive soon and I pray that it will NOT blow up or fry up motherboard on drive and PS ! Will let you know when it is passed ... Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted August 7, 2013 Share Posted August 7, 2013 Next is , will find flat 6 lines as "ADAMNet" cable somewhere else... Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 7, 2013 Share Posted August 7, 2013 Next is , will find flat 6 lines as "ADAMNet" cable somewhere else... Glad to hear that you have the proper Atari PS to use with the Coleco drive and thanks for providing the Part # in case I ever need a replacement. I'm sure it will work as others have reported using it with good results. As far as the ADAMnet cable, you should be able to find the proper 6 Conductor Reverse cable at any electronics store in your area. If not, ShowMeCables ships fast and there is no minimium order amount. Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted August 8, 2013 Share Posted August 8, 2013 That Atari part : C017945 can be using either Atari 1050 disk drive, 1200XL computer, that's it. Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted August 13, 2013 Share Posted August 13, 2013 I recently short tested on ADAM disk drive with Atari PS 1050 and it works ! I switched on/off and it does do fine. Next is I do have only blank diskette , no ADAM software on any diskette, only a fewest tapes software. So how can I transfer disk images from INTERNET into diskette ? A little off-point, I do seen once on eBay , the seller tried to sell it for $499.99 with copy ADAM software on diskette. I have no intention to sell mine ADAM drive. I just wonder why it is high price on eBay ? Rare ADAM drive ? How rare is that ? Quote Link to comment Share on other sites More sharing options...
NIAD Posted August 13, 2013 Share Posted August 13, 2013 Follow these two links to old threads where I posted a lot of deatiled information about transferring Disk Images back to ADAM disks. Lots of good stuff on the AtariAge Forums and I recommend spending some time looking through all the old threads... I did and was very glad that I spent the time doing so. http://atariage.com/forums/topic/177853-looking-for-specs-on-coleco-adam-floppy-drive-model-%237817-power-supply/ http://atariage.com/forums/topic/179825-was-montezumas-revenge-available-on-disk-for-the-adam/page__hl__+dcopy?do=findComment&comment=2251139 The ADAM Disk Drive is a pretty rare and hot commodity, especially if it is tested and working. Surprising a large number of these disk drives became avalable last year on eBay, but this year has seen consideraly less. A loose disk drive can fetch in the neighborhood of $125 and one that is CIB can run about $225. Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted December 28, 2013 Share Posted December 28, 2013 (edited) Hello NIAD, I need to know if my RJ12 6-conductors cable are reverse or opposite 1-6 to 6-1 or just straight cable 1-6 to 1-6 ?? It is for my ADAM 5.25 disk drive. Thank you for understanding. Edited December 28, 2013 by Caterpiggle Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 28, 2013 Share Posted December 28, 2013 It is the Reverse (or also referred to as Twisted) style cable. Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted December 30, 2013 Share Posted December 30, 2013 (edited) Hello NIAD again, I have 1 question. Is possible for you to have any spare or extra RJ-12 twisted cables (2 of them) somewhere at your home ? If you do, is possible for you to send them to me in my home state ? Because my RJ-12 is really straight rather than twisted, it is generic made. I buy them at used electronic store. Edited December 30, 2013 by Caterpiggle Quote Link to comment Share on other sites More sharing options...
jblenkle Posted December 30, 2013 Share Posted December 30, 2013 (edited) You can buy them here...they are the "reverse" ones... http://www.showmecables.com/Search.aspx?q=RJ12+6+Conductor+6P6C+Flat+Silver+Satin+Crossed+Telephone+Line+Cord Hello NIAD again,I have 1 question. Is possible for you to have any spare or extra RJ-12 twisted cables (2 of them) somewhere at your home ? If you do, is possible for you to send them to me in my home state ? Because my RJ-12 is really straight rather than twisted, it is generic made. I buy them at used electronic store. Edited December 30, 2013 by jblenkle Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 31, 2013 Share Posted December 31, 2013 Sorry Caterpillar, but I don't have any extra ADAMnet cables that I can spare, so your best option is either to order from ShowMeCables (which Joe B. provided the link for above) or to order from ADAMcom (just send him a PM on here). Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted July 18, 2017 Author Share Posted July 18, 2017 Necrobumping my old thread here... I haven't really used that 3.5 inch disk drive in the four years since I tested it and got it working. I'm curious if anyone is at all interested in these things? Quote Link to comment Share on other sites More sharing options...
coleconut Posted July 18, 2017 Share Posted July 18, 2017 PM incoming Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted July 28, 2017 Author Share Posted July 28, 2017 So after testing, the drive doesn't work anymore, despite the fact the fact that it was stored carefully away with no reason to have been damaged during those years. Sigh. Probably just going to put it on Ebay in the near future, describing it as non-working, of course. Very much hope someone will get this rarity who has the motivation and skills to get it working again. Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted August 7, 2017 Author Share Posted August 7, 2017 It's on Ebay now: http://www.ebay.com/itm/162619222106?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Quote Link to comment Share on other sites More sharing options...
