Altirra 2.30 released
232 replies to this topic
#226 atx4us OFFLINE
atx4us
    Moonsweeper
  • 434 posts
Posted Fri Oct 25, 2013 10:56 PM
I found this old topic when I was looking around for quick state save/load keyboard shortcuts on Altirra.  Has this ever been implemented?
(Copied here since I don't frequent the "AtariAge Forums→ Gaming General→ Emulation" much)
http://atariage.com/...s/#entry2853858
#227 rdea6 OFFLINE
rdea6
  • 2,725 posts
Posted Fri Oct 25, 2013 11:26 PM
TOOLS
            Keyboard Shortcuts..
#228 atx4us OFFLINE
atx4us
    Moonsweeper
  • 434 posts
Posted Sat Oct 26, 2013 9:15 AM
TOOLS
Works great!  Thanks for the help.
Does anyone know where the Quick Save State file is stored?
#229 Mclaneinc OFFLINE
Mclaneinc
  • 5,882 posts
Posted Sat Oct 26, 2013 9:25 AM
in memory I believe ...ie I don't think theres a temp file on the HD, sure I asked avery about this before..
#230 rdea6 OFFLINE
rdea6
  • 2,725 posts
Posted Sat Oct 26, 2013 12:00 PM
Memory only state...
But there is a Save and Load State also that saves or loads to/from  a specified user given location.
I am using the most current Beta 2.40.test22
Edited by rdea6, Sat Oct 26, 2013 12:01 PM.
#231 atx4us OFFLINE
atx4us
    Moonsweeper
  • 434 posts
Posted Sat Oct 26, 2013 3:07 PM
Thanks for the info -> "Memory only state...".
I also use the latest beta version for my main use.  If I spot an unexpected issue in the latest beta version then I will revert back to the last stable and/or the previous beta version(s) to investigate the issue.
#232 itaych OFFLINE
itaych
    Chopper Commander
  • 209 posts
Posted Wed Oct 30, 2013 6:10 AM
Hi Phaeron,
Thanks for fixing the P: handler.
I have a couple of requests regarding the R: emulation. These are basically issues I'm running into while working on Ice-T.
If "Emulate Telnet protocol" is disabled, I expect the R: device to be able to send and receive any data transparently. However this is not the case: while the emulated Atari can receive any byte, it cannot send out a 0xFF.
As for the Telnet emulation, I wish it could be improved a bit. First, it doesn't identify as a terminal type (there ought to be a drop-down like in APE with the options "Do not identify", "VT-52", "VT-100", "VT-102", "ANSI"). As a result of this, when Telnetting to a Linux shell various programs refuse to run (such as Emacs) unless you set the terminal type manually (e.g. export TERM=vt102). See below for a reference on how this negotiation looks like.
Another problem with the Telnet emulation is that it doesn't handle escape sequences properly; for example if the host sends the sequence FF FF the Atari is supposed to receive just an FF, and if the second byte is anything else then it should be interpreted as a command (which can probably safely be ignored, but the Atari isn't supposed to receive anything). Also apparently if the Atari sends a FF it should be translated to FF FF. As a result of this problem, occasional garbage characters are received and file transfers such as Xmodem (which require 8-bit transparency) fail. I've tried other Telnet clients such as Tera Term and had no problems so this is definitely solvable at the Telnet level.
Here is a dump (with some commentary) of Altirra's and APE's initial Telnet negotiation with a Ubuntu host, where Altirra refuses to identify and APE identifies as VT100.
Telnet Negotiation on Altirra:
Ubuntu:  ff fd 18  ff fd 20  ff fd 23  ff fd 27
	Start use: term type, term speed, X location, env.option
Altirra: ff fc 18  ff fc 20  ff fc 23  ff fc 27
	Won't use any of the above
Ubuntu:  ff fb 03  ff fd 01  ff fd 1f  ff fb 05  ff fd 21
	Will use Supress GA, Start use Echo, 1f. Will use 05, Start use 21.
Altirra: ff fd 03  ff fc 01  ff fc 1f  ff fe 05  ff fc 21
	Start use Supress GA, Won't use Echo, 1f. Stop use 05. Won't use 21.
Ubuntu:  ff fb 01
	Will use Echo.
Altirra: ff fd 01
	Start use Echo.
Telnet Negotiation on APE:
APE:     ff fb 18  ff fc 20  ff fc 23  ff fc 27
	Will use term type. Won't use any of the others.
Ubuntu:  ff fa 18 01 ff f0
	Subnegotiate Term type, 1, end subnegotiation
APE:     ff fa 18 00 56 54 31 30 30 ff f0
	Subnegotiate Term type, 0, "VT100", end subnegotiation
APE:     ff fd 03  ff fc 1f  ff fe 05  ff fc 21
	Start use Supress GA, Won't use 1f, Stop use 05, Won't use 21
Ubuntu:  ff fb 01
	Will use Echo.
APE:     ff fd 01
	Start use Echo.
Thank you!
Edited by itaych, Wed Oct 30, 2013 6:24 AM.
#233 matosimi OFFLINE
matosimi
    Moonsweeper
  • 339 posts
  • Location:Slovakia - Bratislava http://matosimi.atari.org
Posted Wed Oct 30, 2013 10:06 AM
Hi Phaeron, one sugestion...
what about changing icons of associated files in altirra?
I use only XEX and ATR, but those icons are not nice (no offense) :)
I'm sure somebody here will be able to design something better, there are several pixelmasters here on AA.
I would suggest something like this:
...its similar to a800win.
