CrazyBoss Posted June 3, 2013 Share Posted June 3, 2013 Hi When develop at Colecovision, I used the PCB from Harvey Dekleine. http://www.colecovis...ekleine-pcb.jpg I then soldered a test-socket ont he it. so I can easy change the flash chip or test a real Eprom. Like this one: http://www.aliexpres.../907664307.html Problem is i have to remove top cover of the Colecovision to fit the PCB, cause the test-socket is to thick compared to a normal socket. Any one know about a slot extender, should basicly be a PCB with a slot on the top, just to extend an inch or so I guess. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted June 3, 2013 Share Posted June 3, 2013 I don't think there is a slot extender. A thing you could do would be to search on Internet for the PCB drawing of a cartridge and modify it with a PCB design program (there are some free programs) Then you simply would send the file for manufacturing, also there are several PCB manufacturers in Europe (check Elektor magazine) Quote Link to comment Share on other sites More sharing options...
+5-11under Posted June 3, 2013 Share Posted June 3, 2013 (edited) ... or take the case off of the ColecoVision? edit: that's too bad it doesn't work, though. I was planning on making one myself, with a ZIF socket. Edited June 3, 2013 by 5-11under Quote Link to comment Share on other sites More sharing options...
NIAD Posted June 3, 2013 Share Posted June 3, 2013 Check with Steve Tucker at www.atarimax.com . He has made a number of cartridge adapters for his MaxFlash cartridge including a ColecoVision Adapter which I have included a picture from his website of. I'm not sure if this CV Adapter would work as an Extender, but it wouldn't hurt to send Steve an email to find out or if he could provide an Extender for you. Quote Link to comment Share on other sites More sharing options...
