Potential new hardware
FPGA DE1 Hardware
798 replies to this topic
#776 vanfanel OFFLINE
vanfanel
    Star Raider
  • 85 posts
Posted Mon Dec 26, 2016 8:45 AM
@santosp: thanks for trying! I found it works good too... but I had to re-download the XEX. I don't know what went wrong with my previous download.
Any luck with Space Harrier cart image?
On the ZX-UNO using this core it does not work.
http://atariage.com/...rrier-released/
#777 NML32 OFFLINE
NML32
    Dragonstomper
  • 655 posts
Posted Mon Dec 26, 2016 8:50 AM
Have you guys got PacMan Arcade working? I have tried different configurations (memory expansions, etc) with no luck:
http://atariage.com/...cepting-orders/
The .xex loads fine for me if I bypass basic by pressing F8 + F10.
#778 santosp OFFLINE
santosp
    Dragonstomper
  • 790 posts
Posted Mon Dec 26, 2016 8:52 AM
Yes this work also for me but I use Altera DE1 compatible hardware.
#779 NML32 OFFLINE
NML32
    Dragonstomper
  • 655 posts
Posted Mon Dec 26, 2016 8:57 AM
The cart runs fine for me.
I'm using the default settings.
Running on MCC-216
Edited by NML32, Mon Dec 26, 2016 8:57 AM.
#780 vanfanel OFFLINE
vanfanel
    Star Raider
  • 85 posts
Posted Tue Dec 27, 2016 10:25 AM
Thanks guys. I guess it's broken on de ZXUNO only...
#781 foft OFFLINE
foft
    Dragonstomper
  • 784 posts
Posted Tue Dec 27, 2016 2:10 PM
I saw your post on the ZX Uno forum. I think the ZX Uno has just 512KB RAM like the Papilio Duo. So there isn't enough memory to load large cartridges. Since that space is shared between OS, basic system RAM and cartridge. Think its 128K max.
#782 vanfanel OFFLINE
vanfanel
    Star Raider
  • 85 posts
Posted Tue Dec 27, 2016 2:12 PM
@foft: ah, thanks! Everything is clear now.
#783 vanfanel OFFLINE
vanfanel
    Star Raider
  • 85 posts
Posted Wed Feb 15, 2017 4:36 AM
@foft: the famous NUMEN demo has two versions. The single disk version works, however the 2-disk version does not. Both versions are available here: http://numen.scene.pl/download.html
Maybe the single disk version is what we're supposed to be using, but I am reporting just in case...
#784 foft OFFLINE
foft
    Dragonstomper
  • 784 posts
Posted Sun Feb 26, 2017 3:48 PM
What about it doesn't work? I've always tested with the 2 disk version, but perhaps there is another one:)
#785 vanfanel OFFLINE
vanfanel
    Star Raider
  • 85 posts
Posted Mon Feb 27, 2017 9:44 AM
@foft: I think there was a 2-disk version not working here:
http://www.pouet.net....php?which=9044
But now there's only the single-disk version! Maybe the demo was broken after all. It used to hang after loading. But I can't find the non-working version anymore. Nothing to worry about then :D
#786 NML32 OFFLINE
NML32
    Dragonstomper
  • 655 posts
Posted Fri Mar 3, 2017 11:24 PM
I'm having problems running the 800 and 5200 cores on my MiST. The 800 core just boots to a black screen and if I press F12 to load a game the list is buggy and the game doesn't load. TBH, I usually run both the 800 and 5200 from my MCC-216 and I can't remember the last time I tried running them from my MiST.  Maybe my SD card is going bad.
Running Firmware: firmware_170207.upg
800 core: 20160305/mist
Edited by NML32, Fri Mar 3, 2017 11:25 PM.
#787 foft OFFLINE
foft
    Dragonstomper
  • 784 posts
Posted Sat Mar 4, 2017 12:22 AM
The sd card layout on the mcc is different to the mist. The manual shows where they should go. Worth checking. Other than that, erm...
#788 NML32 OFFLINE
NML32
    Dragonstomper
  • 655 posts
Posted Sat Mar 4, 2017 9:40 AM
I think my MiST's SD reader is having problems. Lately, my MiST has been having issues reading all my SD cards new and old I have to power cycle and remove and reinsert the cards many times before they are read.
#789 Jorge Carvalho OFFLINE
Jorge Carvalho
    Space Invader
  • 12 posts
Posted Sun Jul 2, 2017 4:22 AM
Hello! I have installed the atari800 core on Mist . is it possible to run files .rom? like this http://www.atarimani...rier_28586.html? Or commando also in rom format? Many thanks!
Jorge
Edited by Jorge Carvalho, Sun Jul 2, 2017 4:22 AM.
#790 foft OFFLINE
foft
    Dragonstomper
  • 784 posts
Posted Sun Jul 2, 2017 4:36 AM
It supports car, you need to convert from bin to car. There is a thread about a utility for that here, or you can use atari800win to do it.
#791 santosp OFFLINE
santosp
    Dragonstomper
  • 790 posts
Posted Sun Jul 2, 2017 10:03 AM
Mark mean this one...
Attached File  RomToCar.html   7.37KB   88 downloads
#792 Jorge Carvalho OFFLINE
Jorge Carvalho
    Space Invader
  • 12 posts
Posted Thu Jul 6, 2017 2:55 AM
thank you to all for the tips... worked flawless!!! playing space harrier now!!!!
#793 Jorge Carvalho OFFLINE
Jorge Carvalho
    Space Invader
  • 12 posts
Posted Thu Jul 6, 2017 3:57 AM
Just another question, how I swap disks without reset the core? I would like to load numen demo but it has 2 disks. The first loads and ask to insert de secind one. I do F12 select disk 2 and core reboots
#794 Philsan OFFLINE
Philsan
  • 3,807 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Thu Jul 13, 2017 2:55 AM
The Ultimate-64, a new FPGA project with a form factor suitable for original (C64) case: http://www.1541ultim...id=9&Itemid=127
Nice idea.
#795 santosp OFFLINE
santosp
    Dragonstomper
  • 790 posts
Posted Thu Jul 13, 2017 3:28 AM
Thanks for the info!!
For use with original case, I think that a full pcb remake with all the custom ic's, like the Individual Computers in the past, would have better luck!
#796 quincy451 OFFLINE
quincy451
    Combat Commando
  • 5 posts
Posted Mon Oct 30, 2017 1:34 AM
I got my mist computer this weekend and fired off a bunch of cores and they all worked including Atari 800xl. But I went to type 10 print “hello world” and quote didn’t show up. Figured out why and mist has a key mapping feature in the mist.ini that might fix it up. Anyone got a mist.ini that maps Atari to modern keyboard?
#797 gozar ONLINE
gozar
    Dragonstomper
  • 964 posts
Posted Sun Nov 5, 2017 7:17 PM
Isn't the quote shift-2?
#798 vanfanel OFFLINE
vanfanel
    Star Raider
  • 85 posts
Posted Wed Nov 8, 2017 8:47 PM
Hi!
I just tried to format an ATR disk with this core using Atari DOS II 2.5 (V4) but I get:
ERROR 138
(which means "device timeout")
I happens both on the DE1, the MCC-216 and the ZX-UNO boards.
So, is there anything missing with the disk drive implementation?
#799 jugac64 OFFLINE
jugac64
    Star Raider
  • 60 posts
Posted Sun Oct 28, 2018 12:07 PM
Hi Mark! how are you.
I just realized you changed the name of your website to http://www.64kib.com/, good name!
I requested the Chameleon team to update the link in their wiki.
Best regards! Juan
Also tagged with one or more of these keywords: FPGA, DE1, Hardware
