CTRLPF Per Player?
4 replies to this topic
#1 Cybearg OFFLINE
Cybearg
    Dragonstomper
  • 950 posts
Posted Mon Jul 15, 2013 3:36 PM
So I'm in a situation where I'd like one player to move behind the playfield while another player moves in front of the playfield. Is there any modification that can be made (not worried if it costs extra memory) to the kernel to allow for this?
#2 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,811 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Mon Jul 15, 2013 3:39 PM
Did you check out the related links here:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#ctrlpf
Might be something similar to what you want there.
#3 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,548 posts
  • Medieval Mayhem
Posted Mon Jul 15, 2013 3:50 PM
CTRLPF = Control PlayField. If the above/below setting was per player it would be controlled via something like one of the unused bits (D7, D6 or D3) found in NUSIZ0 and NUSIZ1.
There is a way around it, but it will use a lot of RAM and CPU. You'd have to define the "behind playfield" player's graphic data to be stored in RAM, then you'd have to manually zero out any bits that would be blocked by a playfield pixel.
Edited by SpiceWare, Mon Jul 15, 2013 3:51 PM.
#4 Cybearg OFFLINE
Cybearg
    Dragonstomper
  • 950 posts
Posted Mon Jul 15, 2013 4:16 PM
Thanks, this is the response I was looking for, unfortunate as it may be. Thanks for letting me know.
#5 freshbrood OFFLINE
freshbrood
    Star Raider
  • 81 posts
Posted Wed Jul 18, 2018 1:43 AM
One quick and dirty way to achieve this illusion would be to constantly leave both players in front of the playfield, but to change all the colors of the player "behind" the playfield to the same colors as the playfield. This would essentially make it "disappear" while behind it.
