THE!CART... New 128MB FLASH Cartridge
772 replies to this topic
#626 orpheuswaking OFFLINE
orpheuswaking
  • 5,667 posts
  • Lone Raider Time!
Posted Mon Feb 6, 2017 4:54 PM
I'd be interested in the new version when it's available
#627 Stephen OFFLINE
Stephen
  • 6,868 posts
  • A8 Gear Head
Posted Mon Feb 6, 2017 5:59 PM
Follow up to the cart shell I created using the latest model.  I have my printer set up MUCH better now that is has the Repetier 0.92 software on it.  It's literally like owning a brand new printer.  I'm sure if I printed out the case using the new setup it would fit together even nicer.  Since this is strictly for my own personal use, I'm calling it good enough.  I may soon experiment with the "acetone fog" method for polishing the pieces, and I'll fill in the remaining indentations on the front such that any label I apply will stay flat.
The holes for the LEDs were opened up using a jewelers file (round, tapered down to 0.3mm at the small end)
Minimal cleanup has been done on this end of the cart.  I have more sanding to do and I'll try to eliminate the "layer lines".
A very small amount of cleanup was needed in order to fit the reset switch.  In my case, the hole needed opened up towards the back of the shell.  Given the low print quality of this piece, I would not yet recommend changing the model.
Here you see the absolute awesome fitment of the PCB into this case.  I actually sanded down the PCB, not the shell.  I used GENTLE pressure and a flat block of 320 grit sandpaper.  There was barely any fiberglass dust generated from the process, so the material removal was very minimal.  This is a "friction fit", the PCB does not move in any direction.
Ready to click together.
#628 trailblazer OFFLINE
trailblazer
    Combat Commando
  • 3 posts
Posted Mon Feb 6, 2017 6:10 PM
I would like to buy one cart also, thank you!
#629 FULS OFFLINE
FULS
    Moonsweeper
  • 309 posts
Posted Tue Feb 7, 2017 7:25 PM
Jac!,
Would it ever be possible in the future, for The!Cart to load "ATX" files?
Just curious.
#630 JAC! OFFLINE
JAC!
  • 1,612 posts
  • Always looking for GFX and MSX for my demos
Posted Wed Feb 8, 2017 4:21 PM
Jac!,
Just curious.
That would imply simulating the Floppy Drive and CPU inside the Atari and do as if there was even SIO in between...
Sounds like a ... well, I think it'll be more effective if you just PM the ATX and I remove the protection for fun ;-)
#631 576XE OFFLINE
576XE
    Dragonstomper
  • 756 posts
Posted Sat Feb 11, 2017 11:01 AM
IMHO Atari Has it's own TERMINAL inside.
I mean stdin, stdout, stderr...
It's E: device.
It was simulated thousand times!
Thus - it's Atari way to use simulators of any devices!
#632 JAC! OFFLINE
JAC!
  • 1,612 posts
Posted Sun Feb 12, 2017 8:24 AM
Correct and that's why The!Cart can emulate "D:" and SIO. But ATX is the format to emulate what happens on the SIO wire directly. The (few) programs that require this intentionally bypass the OS to make sure they cannot be copied.
#633 576XE OFFLINE
576XE
    Dragonstomper
  • 756 posts
Posted Thu Feb 16, 2017 1:00 PM
Thanks! Jac!
I still have the intention to buy TheCart! but I have not any messages from Wolfram.
Too sad.
#634 Philsan OFFLINE
Philsan
  • 3,569 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Thu Feb 16, 2017 3:57 PM
Is it possible to load programs that need many disks (for example, Alternate Reality and The Dark Crystal need more than 4 disks)?
#635 JAC! OFFLINE
JAC!
  • 1,612 posts
Posted Tue Feb 21, 2017 12:25 PM
You can leverage the support from MegaCart Studio Images for that. Not sure it the emulation works with these specific program of course.
Excerpt from the documentation:
http://www.wudsn.com...CartStudio.html
#636 tep392 ONLINE
tep392
  • 2,973 posts
Posted Tue Feb 21, 2017 12:58 PM
Just a note on using Maxflash Studio to load ATR's.  The above chart says disk swapping is not supported, but you can swap between 4 disk images by pressing ctrl+shift+1,2,3 or 4.  The atr image selected is accessible as D1:.  You need to put the 4 atr files sequentially in the maxflash cart menu.  The atr you select when the cart boots will be #1 and the following 3 atr's in the list will be 2,3 and 4.  I've used this to copy atr's to real disks since I don't have an SIO2?? device.
#637 JAC! OFFLINE
JAC!
  • 1,612 posts
Posted Wed Feb 22, 2017 7:49 PM
Nice, didn't know that. Fixed the description, thanks!
#638 bernie OFFLINE
bernie
    Star Raider
  • 54 posts
Posted Fri Mar 10, 2017 9:27 PM
Amy idea when the next version will be out?
#639 irich2 OFFLINE
irich2
    Combat Commando
  • 7 posts
Posted Wed May 24, 2017 3:17 AM
Please put me down for one (1) THE!CART in a Case on your next production run.
Thank you!
irich2
#640 Hellraiser OFFLINE
Hellraiser
    Space Invader
  • 28 posts
Posted Thu Jun 15, 2017 6:05 AM
Are these still available?
Edited by Hellraiser, Thu Jun 15, 2017 6:05 AM.
#641 JAC! OFFLINE
JAC!
  • 1,612 posts
Posted Sun Jun 18, 2017 3:46 PM
They will be available definitively. I talked to mega_hz today. Because of the huge interest, he'll setup a separate page to manage ordering without getting lost in "who ordered what and paid which ...". And that page will of course take time.
And he added a small change to the PCB today which will allow you to modify The!Cart in a way that it runs with an unmodified Atari 800 too. Even though I'd recommend this fix ...
http://www.wudsn.com/index.php/productions-atari800/tools/thecart/atari-800-fix
... there are certain people who rather want to keep their 800 buggy untouched. There is then the option to keep your Atari 800 untouched and get the missing PHI2 signal from a dummy cartridge in the right slot instead. Here's my test installation.
#642 Heaven/TQA OFFLINE
Heaven/TQA
  • 10,678 posts
Posted Wed Jun 21, 2017 2:34 AM
do I see a MEGA 65 label on the pic??? ;=)
#643 OmaOhneBH OFFLINE
OmaOhneBH
    Combat Commando
  • 3 posts
Posted Wed Jun 21, 2017 7:29 AM
#644 Level42 OFFLINE
Level42
  • 1,897 posts
Posted Fri Aug 4, 2017 2:57 PM
Hey Peter,
Still love the good "old" The!Cart but what is this talk about a new version ? Where do I find details about this ? (without going through the 26 pages here :))
Of course I'm interested in one :)
Also noticed the new printed housings for the "old" The!cart...do you still have one for sale ?
Thanks for all the awesome work !! The!cart is really.....THE cart...
#645 remowilliams OFFLINE
remowilliams
  • 10,369 posts
Posted Sat Aug 5, 2017 12:36 PM
I forgot that there were case files made available, but now that I've reached a semblance of competency with my new 3D printer...   :D
#646 JAC! OFFLINE
JAC!
  • 1,612 posts
Posted Sat Aug 5, 2017 4:52 PM
Still love the good "old" The!Cart but what is this talk about a new version ? Where do I find details about this ? (without going through the 26 pages here :)) Of course I'm interested in one :)
The new version of The!Cart is functionally equivalent to the first version. The PCB and shell will be smaller, so it fits into an 800 in a way you can close the cover. And it'll be prepared to also work in unmodified 800's with by adding a write to the other cartridge port (little soldering required). Both versions work anyway fine in 800's with fixed PHI2 signal on the left slot.
Regarding shells, please PM biobern.
#647 Stephen OFFLINE
Stephen
  • 6,868 posts
  • A8 Gear Head
Posted Sat Aug 5, 2017 5:44 PM
What kind of printer do you have?  I'm ready to shoot my POS.  About 99% ready to sell it, I am even going so far as to get packaging materials for it.
#648 remowilliams OFFLINE
remowilliams
  • 10,369 posts
Posted Sat Aug 5, 2017 7:09 PM
I went with a Flashforge Creator Pro and it seems to be a brilliantly capable printer.
It's been an exhilarating and infuriating ride going from zero practical knowledge to where I am now, and I can say that 99% of the problems (and all the bigger ones) I've had were my error.  The other 1% I think is this particular spool of grey ABS.
I can tell you this - JAC! was 100% on the money when he said this :)
[...] it looks like 3D printing is a real handcraft that you learn [...]
#649 Stephen OFFLINE
Stephen
  • 6,868 posts
  • A8 Gear Head
Posted Sat Sep 2, 2017 5:46 PM
Man - I love the software on this cart.  The menu is beautiful, the search feature is the best.  I like the transparent yellow case I 3D printed.  But this is the final time I am going to try programming the cart.  128MB through SIO is absolutely unusable.  I tried a big collection of ROMs and 100% of them crashed upon load.
Can we PLEASE find a way to use something like the AtariMax USB programmer for this cart?  I'd help with anything I could, hardware or software.  If not, this cart will unfortunately be going in the bin of stored things, never to be powered up again.
P.S.
Don't ask - it's not for sale.
#650 CharlieChaplin OFFLINE
CharlieChaplin
  • 2,744 posts
Posted Sat Sep 2, 2017 6:12 PM
P.S.
Thats why I sold my The!Cart and many other flashcarts - I simply do not want to wait 15 minutes for flashing a 4MB flashcart or much much longer for flashing a 128MB flashcart with the A8. With the Ultimate Cart. or UNO Cart. however you can simply use your PC and copy+paste or drag+drop to fill the SD card or micro SD card (filling 4MB then takes a few seconds)...
It is okay to flash a 1MBit (128kbyte) flashcart with the A8, it already takes quite long to fill an 8MBit (1MB) flashcart with the A8, everything bigger than that, sorry I do not have the patience to flash it with the A8 (and loading the data from a SIO2xxx device)...
A device similar (or equivalent) to an Atarimax USB programmer would be fine or like I already mentioned going the SD/micro-SD card and thus PC route. But it would be great to have an A8 cart with enough onboard (fast) RAM that can load ROM/CAR, XEX and ATR up to 16MB...
I do have 64k Ataris, so a cart with 64MB RAM onboard and a 64GB SD/micro-SD card would be the ideal choice... ;-) And a BIOS, errm, firmware that can load ATR, CAR and XEX...
@Stephen: Are you the owner of Don't Ask software/hardware ?!?   ;-) But Don't Ask did sell software/hardware... ;-)
Edited by CharlieChaplin, Sat Sep 2, 2017 6:22 PM.
