THE!CART... New 128MB FLASH Cartridge
944 replies to this topic
#726 Philsan OFFLINE
Philsan
  • 3,735 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Sat Feb 24, 2018 10:23 AM
If the original cards use flash only, it should be possible. But since the flash chip is different and every chip has a different layout/block size dedicated code is needed. Patching on the fly is possible with The!Cart Studio, but some would need to create the patch for the flash routine.
Pac-Man 2012 and Space Harrier both use AtariMax Flash carts.
#727 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,677 posts
Posted Sat Feb 24, 2018 11:04 AM
I put Space Harrier in a 8Mbit AtariMax cart. It saves high scores (higher than 1 million).
Then I guess my scores are saved. I was hoping it would save a starting level, when you have the option to choose at the main menu, if you've already played and made it enough levels to the save point (as long as power is on). I seem to recall being surprised at not being able to restart on level 12 or around there, after making it that far before...and turning off the game.
EDIT: I also just remembered that I had borrowed my 8Mb SH flashcart to play AtariBlast!, so obviously my high scores were wiped then too.
Edited by Gunstar, Sat Feb 24, 2018 11:19 AM.
#728 JAC! OFFLINE
JAC!
  • 1,760 posts
  • Always looking for GFX and MSX for my demos
Posted Sat Feb 24, 2018 4:11 PM
It works on a Mac but the fact that files have to be dropped one-by-one makes it a very tedious job. Also nog having (sub)folders means you are forced to select by search meaning you need to know part of the name.
I don't understand why it would be one-by-one if you select all in the finder. And knowing part of the name is easy, because they are either .rom, .car or .atr.
I just check on my Mac mini and it works just fine the way I described it.
#729 TonVH OFFLINE
TonVH
    Star Raider
  • 51 posts
Posted Sat Feb 24, 2018 9:04 PM
I don't understand why it would be one-by-one if you select all in the finder. And knowing part of the name is easy, because they are either .rom.car or .atr. I'll check on my Mac the next day. Maybe I misunderstand your problem...
I can't recheck at the moment but I am sure I could only drag a single program into the Cart Window. Multiples did not work.
#730 biobern OFFLINE
biobern
    Star Raider
  • 68 posts
Posted Sun Feb 25, 2018 6:07 AM
I always do it with a Mac. No problems to select hundreds of files at a time and drag it to theCartStudio.
#731 TonVH OFFLINE
TonVH
    Star Raider
  • 51 posts
Posted Sun Feb 25, 2018 6:34 AM
Ah well, probably I did something wrong then. Will have a 2nd look at it.
#732 plx OFFLINE
plx
    Space Invader
  • 19 posts
Posted Mon Feb 26, 2018 2:35 AM
Hello, a question about that *.car file format: all i have found is .rom or .bin -
they surely work but are there also collections of car-files available
or is it something I have to covert with the specific tool?
But as the roms and bins are working, why should I?
I'm a bit irritated, please help... :)
#733 HiassofT OFFLINE
HiassofT
  • 1,094 posts
Posted Mon Feb 26, 2018 6:44 AM
CAR files have a 16-byte header before the ROM data that contains the cartridge type (plus other info like a checksum).
This type is quite important as ROM dumps of the same size could be coming from rather different cartridge types - eg a 16k ROM could be from a standard 16k cart (using 16k memory at $8000-$BFFF) or a 16k bankswitching OSS cart (using 8k memory at $A000-$BFFF).
If you select the wrong type the cartridge dump doesn't work.
If you add a raw ROM dump in The!Cart Studio it'll try to find out what kind of cart this is by comparing the checksum against a list of known carts. This can fail though if you try to add a dump that's not "well known", in this case you have to manually select the type. With a CAR file The!Cart Studio will use the type from the header instead.
Most emulators have an option to convert between ROM and CAR files, and if you have an unknown ROM file that's also the easiest way to find out what type it could be. The emulator will also ask you about the type and you can quickly find out which type will work or not. This isn't 100% accurate though, there might be multiple types that work but have subtle differences - eg a standard 16k cart and a Blizzard 16k both use $8000-$BFFF but the latter can be switched off.
so long,
Hias
#734 plx OFFLINE
plx
    Space Invader
  • 19 posts
Posted Mon Feb 26, 2018 5:55 PM
The question is not about the difference but rather where to find them.
On sites like Atarimania or in archives, I always find .rom or .bin.
Edited by plx, Mon Feb 26, 2018 5:56 PM.
#735 SS OFFLINE
SS
  • 6,183 posts
Posted Mon Feb 26, 2018 8:51 PM
Try these.  I've got 200+ games in CAR format in the ZIP file.
#736 plx OFFLINE
plx
    Space Invader
  • 19 posts
Posted Tue Feb 27, 2018 1:08 PM
Thanks for that one! :)
#737 JAC! OFFLINE
JAC!
  • 1,760 posts
Posted Fri Mar 2, 2018 1:25 PM
Update: tf_hh finally received the V2 and is flashing it right now to start analyzing the Atari 400 compatibility issue.
We want to make sure that if there is a fix possible & required, we won't have "fixed and unfixed" The!Carts out there.
Thanks for you patience.
#738 Stephen OFFLINE
Stephen
  • 7,261 posts
  • A8 Gear Head
Posted Fri Mar 2, 2018 7:09 PM
Thanks for the updates and all the work on this!
#739 JAC! OFFLINE
JAC!
  • 1,760 posts
Posted Sun Mar 4, 2018 7:14 AM
UPDATE: Finally tf_hh identified the (hopyfully last) issue!!! The phi2_short signal generated by the RC combination is too short due to the value of the resistor. With the current 5.6k the signal is too short for the Atari 400, with 6.8k it works in Atari 400/XL/XE. Test for Atari 800 is on the todo list. Wolfram has sent out only 8 PCBs with the 5.6k resistor by now within Germany. All remaining PCBs will get the correct resistor now. It's SMD, but on the other hand only a resistor, so changing it should be doable. I'll do that also as test myself.
#740 commander OFFLINE
commander
    Star Raider
  • 70 posts
Posted Sun Mar 4, 2018 7:36 AM
great to hear.
I can't wait to hold this great cart in my own hands :-)
Hoperfully somebody can post some nice cart collections here to make a start easy for me :-)
#741 Philsan OFFLINE
Philsan
  • 3,735 posts
Posted Sun Mar 4, 2018 9:05 AM
great to hear.
Post #735
#742 commander OFFLINE
commander
    Star Raider
  • 70 posts
Posted Sun Mar 4, 2018 9:34 AM
I mean the complete cartstudio sets called workbook
#743 SS OFFLINE
SS
  • 6,183 posts
Posted Sun Mar 4, 2018 12:47 PM
Honestly, I think that half the fun of these things is doing the work of filling your own cart yourself.
#744 Panther OFFLINE
Panther
    Moonsweeper
  • 291 posts
Posted Sun Mar 4, 2018 2:55 PM
And some people believe that the fun of something like The!Cart is actually designing, building, and programming it, so are you planning on doing that as well?  =B>
#745 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 732 posts
Posted Tue Mar 6, 2018 1:58 AM
Another update... also the programming (flashing) of The!Cart V2 works now fine on an Atari 400 or Atari 800! I´ve tested it with a full 128 MByte ATR file (took over 7 hours each!), no problems.
The Atari 800 need the PHI2 cartridge patch, of course (see here: PHI2 Patch for Atari 800)
Owners of the The!Cart V1 version can also use their carts with an old Atari computer, when the CPLD code is updated to the lasted version from Hias and the actual CARTMENU is used. The cartridge won´t fit with a closed cartridge door, but it works :)
#746 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,677 posts
Posted Tue Mar 6, 2018 12:13 PM
Fantastic! I am eagerly awaiting...I am going to add it to my sig, since I own it and just don't have it in my hands yet! :-D
Edited by Gunstar, Tue Mar 6, 2018 12:15 PM.
#747 MARIO130XE OFFLINE
MARIO130XE
    Chopper Commander
  • 185 posts
Posted Wed Mar 7, 2018 1:41 AM
Got my cart yesterday. looks beautiful and is working great, Thanks to Peter, Jürgen and Wolfram.
Awesome job!!!!
#748 lucifershalo ONLINE
lucifershalo
  • 3,005 posts
Posted Wed Mar 7, 2018 1:55 PM
Hello, I am interested in this cart
but have some questions?
is it easy to use?
which format can it recognize?
thanks
#749 Gunstar OFFLINE
Gunstar
    Gunstar
  • 9,677 posts
Posted Thu Mar 8, 2018 9:52 AM
Awesome job!!!!
But where is the gold leaf inlay? :?  ;)
Guess what I'll be adding to mine...
Edited by Gunstar, Thu Mar 8, 2018 9:53 AM.
#750 JAC! OFFLINE
JAC!
  • 1,760 posts
Posted Thu Mar 8, 2018 6:45 PM
is it easy to use?
thanks
Please check out the video and the description here http://www.wudsn.com/index.php/productions-atari800/tools/thecart
Best Regards, Peter.
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
