kamakazi Posted September 1, 2013 Share Posted September 1, 2013 I'm going to try to learn the 5200 by playing around with DanB's samples on his website. I've got MESS already setup and have DASM as well. But I haven't used DASM in so long that I forgot how to do it. Would someone please tell me how to assemble ASM files with DASM, by that I mean the command line. Thanks! On a side note: Windows 7 apparently doesn't let any command line application to go full screen. Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 1, 2013 Share Posted September 1, 2013 You'd probably be better off using MADS or AtAsm - AtAsm is somewhat dated but has had some recent work done. Fullscreen isn't required for any cmd-line assembler that I'm aware of. The common way we use them these days is via a decent editor which allows calling command-line programs and capturing the output. Each assembler generally has a readme file or other documentation which explains the calling procedure. In case you can't find such docs, you can often run the assembler from a cmd-line with either no parms or /? as the parm and get a brief explanation of usage as per other Windows commands. Quote Link to comment Share on other sites More sharing options...
+JAC! Posted September 2, 2013 Share Posted September 2, 2013 (edited) Here are the defaults I use for DASM in WUDSN IDE: dasm <sourceFilePath> -o<outputFilePath< -f3 -v5 -l<outputFilePathWithoutExtension>.lst Error handling and messages in DASM are really bad, so I also recommend MADS/AtAsm Edited September 2, 2013 by JAC! Quote Link to comment Share on other sites More sharing options...
