Castle of Doom
91 replies to this topic
#26 atari2600land ONLINE
atari2600land
    My favorite channel is Channel F.
  • 11,793 posts
  • It's groovy.
Posted Fri Aug 29, 2014 7:37 PM
I doubled the length of the song and added a new death sound/code.
#27 bogax OFFLINE
bogax
    Dragonstomper
  • 793 posts
Posted Fri Aug 29, 2014 8:17 PM
Is there an easy way to make playfields the way you did in your code (0 and 1 instead of X and .) and make it look and be right?
I addressed that up above
make a program that is just the playfield (or it could be more than one playfield)
compile it
find the associated bB.asm file and open it in a text editor
copy the table of playfield data and paste it in to a new text file (that should get rid of most of the cruft)
use search and replace to get rid of the rest of the cruft (should be just .byte declarations)
now copy what's left once you've got it how you want/need it and paste it into
the end of the playfield(s) data statement.
not complicated, basically just
compile
cut and paste
search and replace
cut and paste
I think RT had a tool that would do what you want
but I'm not sure.
#28 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Fri Aug 29, 2014 9:29 PM
OK. That saved me about 300 bytes. Thanks for helping me work on this. I doubt I can fit 63 levels in here anyway, but I'll do as many as I can.
#29 bogax OFFLINE
bogax
    Dragonstomper
  • 793 posts
Posted Sat Aug 30, 2014 6:10 PM
 Here I've added a converter.
 It workes for me in Chrome and Opera
 but didn't work in Firefox or IE
 (perhaps it would with newer versions than I have).
 Might be easier if you have a bunch to convert.
 playfield to binary converter
#30 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Sun Aug 31, 2014 12:19 AM
Added room #22.
#31 godzillajoe OFFLINE
godzillajoe
  • 2,568 posts
Posted Sun Aug 31, 2014 1:01 PM
How about some sprite animation?
#32 bogax OFFLINE
bogax
    Dragonstomper
  • 793 posts
Posted Mon Sep 1, 2014 12:41 PM
 Is there some reason for the first
 playfield in bank 2 to have 12 lines
 instead of 11 like the rest?
 edit: looks like you got rid of the extra
 line in castle21.bas.bin
 nevermind
 The very first playfield statement,
 in bank 1, has 33 pixels per line.
 in castle19.bas and earlier
Edited by bogax, Mon Sep 1, 2014 1:24 PM.
#33 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Tue Sep 2, 2014 2:40 AM
I tried, but it looked as though Bob was standing in the middle of air when in fact he was standing on the edge of a ledge.
#34 bogax OFFLINE
bogax
    Dragonstomper
  • 793 posts
Posted Tue Sep 2, 2014 2:55 PM
 It occured to me that by slightly
 rearranging the code (and at the cost of 5
 bytes and 4 cycles) you could let level go
 up to 85
  rem temp2.temp1 = level * 44 + PF_dat
  asm
  lda #$00
  sta temp2
  lda level
  asl
  adc level
  asl
  rol temp2
  asl
  rol temp2
  sec
  sbc level
  bcs *+4
  dec temp2
  asl
  rol temp2
  asl
  rol temp2
  adc #<PF_dat
  sta temp1
  lda temp2
  adc #>PF_dat
  sta temp2
end
 And just for the hell of it here it is
 in bB with a small bit of asm (takes about
 twice as much space and time)
 dim lvl_hi = temp4
 dim lvl_lo = level
 dim lvl = temp4.level
 dim ptr_hi = temp2
 dim ptr_lo = temp1
 dim ptr = temp2.temp1
 dim tmp_hi = temp4
 dim tmp_lo = temp3
 dim tmp = temp4.temp3
 const baselo = <PF_dat
 const basehi = >PF_dat
 macro ptr_x_2
 asm
 asl temp1
 rol temp2
end
end
 rem lvl is the 16 bit version of level, uses temp4 for the hi byte
 rem tmp uses temp4 as the hi byte, same as lvl, and temp3 as the lo byte
 rem tmp is a 16 bit temp variable, we can assign PF_data to tmp to use in the math
 rem ptr uses temp2 for the hi byte and temp1 for the lo byte
 rem ptr is the 16 bit pointer in to the playfield data statement
 tmp_hi = 0 : ptr_hi = 0
  rem ptr = level * 3 (level * 2 + level = level * 3)
 ptr_lo = level * 2 + level
  rem ptr = level * 12 (ptr = level * 3 * 4)
 callmacro ptr_x_2
 callmacro ptr_x_2
  rem ptr = level * 11 (ptr = level * 12 - level)
 ptr = ptr - lvl
  rem ptr = level * 44 (ptr = level * 11 * 4
 callmacro ptr_x_2
 callmacro ptr_x_2
  rem ptr = level * 44 + PF_dat
 tmp_lo = baselo : tmp_hi = basehi
 ptr = ptr + tmp
 edit: I added a little bit more asm
 and stream lined the code a little.
 Saves a few bytes, cycles, makes it
 easier to use.
 dim lvl_hi = temp4
 dim lvl_lo = level
 dim ptr_hi = temp2
 dim ptr_lo = temp1
 rem takes 1 parameter an 8.8 variable
 rem shifts the 16 bit variable to the left (multiplies by 2)
 macro x_2
 asm
 asl {1}-1
 rol {1}
end
end
 rem takes 2 paramters an 8.8 variable and a constant
 rem adds the constant to the 16 bit variable
 rem if the constant is defined using the const declaration
 rem bB adds a # to it when it's passed as a paramter
 rem DASM doesn't seem to mind
 rem passing the data statement name works correctly
 macro add_con
 asm
 clc
 lda {1}-1
 adc #<{2}
 sta {1}-1
 lda {1}
 adc #>{2}
 sta {1}
end
end
 ptr_hi = 0 : lvl_hi = 0
 callmacro x_2 ptr
 callmacro x_2 ptr
 ptr = ptr - lvl
 callmacro x_2 ptr
 callmacro x_2 ptr
 callmacro add_con ptr PF_dat
Edited by bogax, Wed Sep 3, 2014 1:23 AM.
#35 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Wed Mar 25, 2015 2:25 PM
Added level 23. To start at room #1, press up+fire. Pressing fire without up warps you to room 23. The up+fire thing is just for convenience so I don't have to play through all the levels to test a new level at the end. I can't do Bob animation due to my code. Does anyone have any other feedback?
#36 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Wed Mar 25, 2015 4:41 PM
I added a new room. I also played it on real hardware. I discovered my controller isn't very good. And my hands hurt after 30 minutes or so of playing it. I discovered a shortcut on room 21. I think I'll keep it the way it is, and if you discover it too that's OK.
#37 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Thu Mar 26, 2015 5:14 PM
Added two new rooms since last time. I need to know if room #25 is too hard. If it is, I'll change it, but I'm letting you know it is possible to beat. You just have to experiment with timing a little bit...
#38 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Wed Apr 1, 2015 10:03 PM
Room #27 added. It is hard, but not impossible. I need feedback on how hard the game is, folks!
#39 Papa OFFLINE
Papa
    Dragonstomper
  • 751 posts
Posted Mon Apr 27, 2015 10:32 AM
Okay..I keep getting hit by the smelly-meatus-eye-nazi-bird badguys.  I can't get to the door and I want to.  I will try the other levels, as I started on #27.  I couldn't stop laughing at how quick I was dying and If there was a counter for how many times I died it would probably be around one hundred and twenty.  I'll try it on the cabinet and see what happens, maybe post a video or something.  I would maybe cut back on the badguys, or make them have a slower/different pattern.  It's HARD!
#40 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Thu Apr 5, 2018 3:31 AM
I came back to this game. Since I didn't have a .bas file for room #27, I redesigned it.
#41 zilog_z80a OFFLINE
zilog_z80a
    Chopper Commander
  • 103 posts
Posted Thu Apr 5, 2018 12:46 PM
nice, very challenging!!  :-o
#42 NML32 ONLINE
NML32
    Dragonstomper
  • 659 posts
Posted Thu Apr 5, 2018 3:14 PM
Nice game and I agree it's challenging.
#43 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Thu Apr 5, 2018 8:53 PM
Press up+fire at the title screen to begin at level 1. I put in some animation for the bat and Bob.
#44 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Fri Apr 6, 2018 7:33 AM
Changed a lot of stuff:
+ Changed title screen & added music on it
+ changed Bob's sprites
+ Bob now faces left and right.
#45 vidak OFFLINE
vidak
    Moonsweeper
  • 458 posts
Posted Sat Apr 7, 2018 4:47 AM
I'll see if I have some time to make a bat sprite.
#46 neotokeo2001 OFFLINE
neotokeo2001
  • 3,872 posts
Posted Sat Apr 7, 2018 8:22 AM
Very cool so far. I made it to 23 and couldn't get over the gap.
At level 21 when the enemy changes, you should make them be a different color. I see that you have place holder graphics in for a new enemy type so that may be your plan already.
The extra pixel for the Bob sprite makes the jumps get snagged easier.
Castle of Doom Bin with changes:
Attached File  Castle of Doom b.bin   8KB   44 downloads
- removed extra pixel on Bob's front arm.
- made a bat sprite.
- changed room to cell
#47 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 200 posts
Posted Sun Apr 8, 2018 7:14 AM
Nice lightning effect, I like these kind of games
Would either atari2600land or neotokeo2001 like to upload the scoregraphics so I can see how to add letters?
#48 Karl G ONLINE
Karl G
    Dragonstomper
  • 852 posts
Posted Sun Apr 8, 2018 2:19 PM
It's cute and fun - although I'm not any good at it.  I made it past level 1, though!  :)
#49 atari2600land ONLINE
atari2600land
  • 11,793 posts
  • It's groovy.
Posted Sat Apr 14, 2018 10:19 AM
Added room #30. Fixed a collision bug where Bob gets partially dead when he touches only the extreme right part of a bat. I also changed the font. Here is the font I use now, along with the newest binary file.
#50 KevinMos3 OFFLINE
KevinMos3
  • 1,610 posts
  • Founder of the Timothy Dalton as Bond fan club
Posted Sun Apr 15, 2018 8:05 PM
I like it.  Challenging, but not frustrating... as long as the unlimited tries remain.  :)
Spent a few minutes to get to room 14, but had to put it down and get some things done.  ;)
I imagine it will be even better when playing with a joystick instead of a keyboard.
