ColecoVision 1.2 - replacement PCB, added features
ColecoVision Modification YPbPr Component New
259 replies to this topic
#226 Jinks OFFLINE
Jinks
  • 4,355 posts
Posted Wed Aug 10, 2016 7:45 PM
[quote name="Bmack36" post="3569053" timestamp="1470834531"]
Here is one installed. The connections inside the RF box are for Gnd, 12V, and the composite video output from the HEF4066 (that switches between the external video fo the EM1 and the CV video output).[/quote
Here is what I did.. the jumper is for the screwed trace from going on and off several times with the daughter board.. I get no video or anything.
#227 Bmack36 OFFLINE
Bmack36
    Moonsweeper
  • 426 posts
Posted Wed Aug 10, 2016 9:31 PM
So you have:
Green -> Gnd  Pin 1
Red-> 12V  Pin 4 (White Jumper shouldn't be needed as the 12V you are tapping on Pin 4 is the input to the RF box so it shouldn't matter if a trace is broken)
White -> Video  Pin 6  (you might want to move the connection directly to the pin 6)
Black -> Audio C88 leg closest to RF box
Edited by Bmack36, Wed Aug 10, 2016 9:32 PM.
#228 Jinks OFFLINE
Jinks
  • 4,355 posts
Posted Wed Aug 10, 2016 9:36 PM
So you have:
Green -> Gnd  Pin 1
Yes that is what I have.. Any other spots to try and get video? I repkaced my lm1889 chip. All my ram chips, I have black and white video on the vdp. I have sockets and chip to do the controller ic chips as well.. shoulda socketed the rams as well..
#229 Bmack36 OFFLINE
Bmack36
    Moonsweeper
  • 426 posts
Posted Wed Aug 10, 2016 9:40 PM
What type of tv/monitor are you using? Are you sure it is a pal console? The ones I have seen online look like they don't use the same RF box, but use a board by the power switch.
#230 Bmack36 OFFLINE
Bmack36
    Moonsweeper
  • 426 posts
Posted Wed Aug 10, 2016 10:48 PM
Ignore the PAL comment. Wrong thread and wouldn't let me edit or delete.
#231 madlou2 OFFLINE
madlou2
    Combat Commando
  • 1 posts
Posted Sat Aug 13, 2016 9:39 AM
I would be very interested in replacing my motherboard. Depending on the price. My coleco lost the game select screen but still plays at the game 3 selection for one player.
#232 Bmack36 OFFLINE
Bmack36
    Moonsweeper
  • 426 posts
Posted Sat Aug 13, 2016 10:14 AM
Usually bypassing the game selection screen is a sign of controller ic failure. There are some DIY kits for replacing these.
Edited by Bmack36, Sat Aug 13, 2016 10:14 AM.
#233 5-11under OFFLINE
5-11under
  • 3,345 posts
Posted Thu Nov 24, 2016 1:09 PM
Another vapourware update:
Layout of the next prototype is basically complete. Hopefully I'll have the PCB in hand within a few weeks.
Future versions may not have all these options (may be user configurable/orderable), but features include:
  • F18A compatibity
  • YPbPr/component output (new version, simple, but hopefully better than previous version)
  • Works with Sega controllers (extra ports on right side of console for now)
  • Can plug in keypad - installed on top of console (same kind as in Collectorvision's arcade controller) - yes, I know this is weird, but I like it (especially if using Sega controllers)
  • Uses 5V barrel power input
  • Expansion port hopefully fixed up and operational (project was conceived before the SGM ;))
  • Option for creating -5V and +12V for expansion port usage (I think the Atari module uses both
  • Power for roller controller
  • Hopefully the standard power and reset plastic button tops will work with the new switches
#234 panzeroceania OFFLINE
panzeroceania
    Space Invader
  • 27 posts
Posted Sat Nov 26, 2016 12:33 PM
Awesome! Keep us updated, I don't visit the forums often but always check this thread when I do.
#235 5-11under OFFLINE
5-11under
  • 3,345 posts
Posted Thu Jan 5, 2017 8:27 AM
Minor vaporware update: the prototype board is in production, and should arrive in a couple of weeks. Hopefully I'll get some time to work on it when it arrives.
#236 Ransom OFFLINE
Ransom
  • 4,993 posts
  • Pre-Crash Gaming and Computing Enthusiast
Posted Thu Jan 5, 2017 8:37 AM
Great! I hope your tests go well. :)
#237 imstarryeyed OFFLINE
imstarryeyed
    Moonsweeper
  • 425 posts
Posted Thu Jan 5, 2017 1:35 PM
Good luck on your tests, it sounds like the community can really use some homogenized stable hardware so the developers can minimize these weird problems that seem to creep up.
I am looking forward to your new designs.
#238 5-11under OFFLINE
5-11under
  • 3,345 posts
Posted Tue Feb 14, 2017 8:01 PM
Another vaporware update:
The board arrived, and I assembled it. The biggest change I made for this version was to get the expansion port working. It now works with the SGM! I also updated the circuitry for the SRAM for the Video Display Processor, and that's working, too. I fixed up the Sega controller inputs a bit, and that works, although it's not compatible with all the games (because when you press a direction button, a number on the keypad is also enabled - so sometimes the game pauses or does other weird stuff - the standard controller seems fine).
There's a number of other things that still need to be tested... I forgot to order a chip, so for the YPbPr/component output, I've only tested the Y. I also still need to test the roller controller, steering controller, super action controller, the Atari module (I think it might need -5V and/or +12V which I haven't tried yet), and F18A. I also need to install it into a ColecoVision shell, to see how that all works (especially the power and reset buttons).
Then I'll have a new ColecoVison for ME ;) ... at some point I'll need to know what YOU need/want in such a board...
  1. YPbPr/component or F18A?
  2. Atari module compatibility or not?
  3. Roller controller power (would require soldering the 4-pin standard power connector to the board - as an output, not an input) or not? (BTW, board uses 5V barrel connector as power input).
  4. Coleco controller (2 standard inputs) or Coleco+Sega controller (2 standard inputs plus 2 Sega inputs)?
  5. Plug-n-play power and reset switches (similar to standard) or custom power and reset switches (someone would have to solder and fit these like a few people have done)?
  6. Standard ColecoVision case or something smaller and likely generic?
  7. Surface mount or mostly-soldered-in through-hole parts or fully-IC-socketed through-hole components? (input 74'541 ICs will be socketed through-hole in any case).
Most of these choices would be options, but some I may just get rid of, if nobody wants them. Assume for now that most options would cost a bit of money, but not too much.
#239 Pixelboy OFFLINE
Pixelboy
  • 7,938 posts
Posted Tue Feb 14, 2017 9:02 PM
  • YPbPr/component or F18A?
  • Atari module compatibility or not?
  • Roller controller power (would require soldering the 4-pin standard power connector to the board - as an output, not an input) or not? (BTW, board uses 5V barrel connector as power input).
  • Coleco controller (2 standard inputs) or Coleco+Sega controller (2 standard inputs plus 2 Sega inputs)?
  • Plug-n-play power and reset switches (similar to standard) or custom power and reset switches (someone would have to solder and fit these like a few people have done)?
  • Standard ColecoVision case or something smaller and likely generic?
  • Surface mount or mostly-soldered-in through-hole parts or fully-IC-socketed through-hole components? (input 74'541 ICs will be socketed through-hole in any case).
I think the above post deserves its own thread, but anyhow:
1 - F18A.
2 - Atari module not required in my case.
3 - Functional Roller Controllers are too rare, and games for this controller are too few to make it truly desirable.
4 - Don't really care about Sega pads, but feel free to add ports for them if you want. Personally, I would prefer NES controller ports, but that's just me. :)
5 - I don't want to fiddle with soldering custom power/reset switches. Please select an option and stick to it.
6 - I wouldn't mind a generic case, especially if it reduces the footprint of the console.
7 - Whatever floats your boat. Again, I'm never going to fiddle with soldering or electronic maintenance, I just want a system that "just works".
Thanks for the update on this project. :)
#240 AtariBuff OFFLINE
AtariBuff
  • 1,193 posts
Posted Wed Feb 15, 2017 1:51 AM
Great stuff!
2 F18A (is this included, as I don't have one?)
3 Not required
4 Roller Controller power: if possible, yes
5 Additional ports would be nice
6 Please no soldering...
7 Both fine
8 see Pixelboy
#241 HDTV1080P ONLINE
HDTV1080P
    Dragonstomper
  • 577 posts
Posted Wed Feb 15, 2017 5:40 AM
I would like to have HDMI 480P 4:3 screen ratio since every modern display uses HDMI now (component video inputs is hard to find on many new monitors), Expansion module #3 ADAM compatibility, Atari 2600 module compatibility. Also the advantage of using the exact same standard Colecovision case size, is that one could use the gray ADAM tray that comes with Expansion module #3. Surface mount components would be ideal. Roller Controller power and Sega controller options would be nice.
The ColecoVision case could be called “ColecoVision II”. If its 100% compatible with all cartridges and expansion modules, then I would end up buying several of these units. The ideal thing is to get the hardware working correctly, with a firmware update posted online one could download fixes to a SD card and plug it into the ATARIMAX Ultimate SD cartridge.
Thanks 5-11 for all the hardwork. It sounds like this might be the very first fully functional ColecoVision game system every made, except for the original 1982-1985 Colecovision game system.
Edited by HDTV1080P, Wed Feb 15, 2017 5:40 AM.
#242 grips03 OFFLINE
grips03
  • 3,638 posts
Posted Wed Feb 15, 2017 6:28 AM
1) Could both be possible?
2) No need for Atari module
3) No need for Roller Controller
4) No need for Sega controller
5) As long as there is pads to solder too.
6) Small case is cool, but Im thinking you would have more buyers for standard case
7) Socketed through hole would be cool.
#243 VectorGamer OFFLINE
VectorGamer
    Go Sleep In the Cold
  • 14,564 posts
  • \m/
Posted Wed Feb 15, 2017 7:00 AM
yeah we know...
#244 Ikrananka OFFLINE
Ikrananka
  • 2,558 posts
Posted Wed Feb 15, 2017 8:03 AM
1.  F18A
2.  I am one of the rare one's that would like Atari module compatibility but ONLY for power.  The video out from the Atari module is, in my opinion, crap and so I add a video mod to the module and have a separate video out on the module itself.
3.  I want roller controller power even if it means some soldering.  BTW - all of my roller controllers are fully functional !!!
4.  Coleco standard only.
5.  I'd stick with the plug and play power and reset switches.  After all, it's supposed to be a drop in replacement.  If someone wants customisation then they can do that themselves.
6.  Standard CV case.  I just want boards that I can drop in my many CV cases update them to modern technology in one simple step.
7.  No view on this.  Whatever works best for you.
#245 SiLic0ne t0aD OFFLINE
SiLic0ne t0aD
  • 2,239 posts
  • Rock 'N Roller, Space Patroller
Posted Wed Feb 15, 2017 2:01 PM
My preferences:
    - BOTH if possible. I'd prefer the F18a, converted to HDMI. A lot of my displays have Component inputs but none of them have straight up VGA.
    - YES, it's about the only way I play 2600 games.
    - YES, it would be nice to have this option, even though I rarely use it. It would be a shame to not have all the original hardware options available.
    - Both CV and Genesis inputs, please. You can never have enough controller options.
    - Either or, doesn't matter. The option of using NKKs or something equivalent would be great though. Also, please don't forget the Pause button mod (w/blinking light optional). ;)
    - Either or, although I definitely want a drop-in replacement for my existing CV cases. It would also be nice to be able to drop one into a small project case for a Mini CV option.
    - Doesn't matter to me, surface mount is probably the way to go, although I prefer working with through-hole. Socketed ICs are a must.
Thanks! Really excited about this project and can't wait to replace my old mobos, especially since my original unmodified unit started acting up and is currently unplayable.. I really don't feel like messing with it right now. Only my heavily modded CV works at the moment.
#246 BillLoguidice OFFLINE
BillLoguidice
    Dragonstomper
  • 754 posts
  • Armchair Arcade
Posted Wed Feb 15, 2017 2:13 PM
1. I'd prefer both, but, if I had to pick just one, it would be the F18A, even if it means I'm converting it to HDMI (which is what I'd do with component anyway via the Framemeister).
2. This doesn't necessarily interest me. I already have dedicated modded Atari 2600 systems and I suspect my Atari module would continue to sit on the shelf.
3. Roller controller power would be great.
4. The more inputs the better, but I'm just fine with the two standard ones.
5. Plug and play.
6. Although I have donor ColecoVision cases, I'd be just fine with a generic case, and in fact would probably prefer it.
7. Doesn't matter to me.
#247 Spinage OFFLINE
Spinage
    Combat Commando
  • 1 posts
Posted Wed Feb 15, 2017 6:42 PM
Oh, I want in on this!
#248 imstarryeyed OFFLINE
imstarryeyed
    Moonsweeper
  • 425 posts
Posted Thu Feb 16, 2017 12:06 AM
1. RGB/Component and F18A would be great if possible..
2. I think being able to use the Atari module would be nice to have
3, I would want to have Roller controller functionality as I use it and hope to have devs make more games that can support it
4. Coleco controller, Sega controllers, (SMS or Genesis with configurable buttons) would be awesome
5. I would like custom power and reset switches
6. Standard Coleco case or new smaller case if possible
7. Socketed chips would be great for repairs
In any case thank you for the great effort!
#249 TPR OFFLINE
TPR
  • 1,856 posts
Posted Thu Feb 16, 2017 5:35 PM
F18A please!
While it would be "nice" it's not a dealbreaker for me.
Same answer as #2
Standard Coleco controller is fine by me.
I'd prefer this to be as "drop in" as possible since I'm not a tech/electronic person.  Any additional work I'd have to do would probably mean I would destroy the PCB!
Standard CV case is fine with me.  If I can open up an old CV and drop this one board in with as little modifications as possible, that's a huge win, IMO, and something that I think would sell to a lot more people that just on these boards.
Hang on, I'm going to have to Google many words in this sentence to fully understand how to answer it!  :)
#250 sega_SHARK OFFLINE
sega_SHARK
    Dragonstomper
  • 756 posts
Posted Fri Feb 17, 2017 4:34 PM
1.  F18A
2. Doesn't matter to me.
3. Yes to the Roller Controller.
4.  2 Coleco inputs
5. Plug and play
6. I'm receptive to the idea of a smaller generic case, but I like the idea of upcycling standard CV cases too.
7.  Sockets
Also tagged with one or more of these keywords: ColecoVision, Modification, YPbPr, Component, New
