funkheld Posted September 15, 2013 Share Posted September 15, 2013 hello, good day.Graphics (23) does not work with Effectus?greeting MODULE PROC Main() Graphics(23) color=2 Plot(0,0) DrawTo(159,95) color=1 Plot(159,0) DrawTo(0,95) RETURN Quote Link to comment Share on other sites More sharing options...
ricortes Posted September 16, 2013 Share Posted September 16, 2013 Once again, I don't have Effectus so just a guess. It looks like the program is trying to print to screen and is handling it badly. Something like the 'RETURN' is going to DOS and DOS is trying to print something. Try changing it to PROC Main() Graphics(23) color=2 Plot(0,0) DrawTo(159,95) color=1 Plot(159,0) DrawTo(0,95) While Peek(764)=255 DO OD RETURN Quote Link to comment Share on other sites More sharing options...
funkheld Posted September 16, 2013 Author Share Posted September 16, 2013 Thank you.With an endless loop it does not go well.greeting MODULE PROC Main() Graphics(23) color=2 Plot(0,0) DrawTo(159,95) color=1 Plot(159,0) DrawTo(0,95) DO OD RETURN Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted September 18, 2013 Share Posted September 18, 2013 Try also replacing this: While Peek(764)=255 DO OD with this: While Peek(555)=0 DO OD This works better because sometimes the KB buffer doesn't get cleared when the program is run or you can do a POKE(764,255) before the While statement. Quote Link to comment Share on other sites More sharing options...
Gury Posted August 11, 2015 Share Posted August 11, 2015 Peeking at 555 is fine alternative for testing the key. I used it several times with no problem. I just wonder if there are any issues using this location, are there any conflicts with different DOSes or special software? Quote about this location from System Guide: "Software repeat timer, controlled by IRQ device routine, establishes initial delay before key will repeat--1/2 sec. Stage 2 Vblank establishes repeat rate 10/sec. decrements timer, implements auto repeat logic." Quote Link to comment Share on other sites More sharing options...
Gury Posted August 12, 2015 Share Posted August 12, 2015 Even more descriptive explanation: "Each time you read this location, you get a different number. That's because it's counting down from when a key is de- pressed to time the delay before repeating the key." but I will stick with location 764 and reseting it to 255, because it seems more reliable. Quote Link to comment Share on other sites More sharing options...
funkheld Posted August 12, 2015 Author Share Posted August 12, 2015 (edited) continues to attend the effectus. thank you. greeting Edited August 12, 2015 by funkheld Quote Link to comment Share on other sites More sharing options...
Gury Posted August 12, 2015 Share Posted August 12, 2015 Yeah, of course it is. It was recently updated, but I am working on new version with much more features and bug fixes. So much has to be done, better support for pointers, multi-line compiling, other syntax, function and parameter fixes, etc. Quote Link to comment Share on other sites More sharing options...
funkheld Posted August 12, 2015 Author Share Posted August 12, 2015 (edited) hello, why demo " result=0" with effectus ??? greeting CARD FUNC MultiplyB=*(BYTE a,x)[ $85 $E0 $86 $E1 $A9 $00 $85 $A0 $A2 $08 $46 $E0 $90 $03 $18 $65 $E1 $6A $66 $A0 $CA $D0 $F3 $85 $A1 $60] BYTE FUNC PokeTest=*(BYTE d)[ $8D $02C6 $60 ] PROC Test() BYTE i BYTE j CARD z ; Poke background with color PokeTest(210) ; Multiply two numbers i=20 j=30 z=MultiplyB(i,30) PrintF("Result = %U%E",z) RETURN Edited August 12, 2015 by funkheld Quote Link to comment Share on other sites More sharing options...
funkheld Posted August 12, 2015 Author Share Posted August 12, 2015 gury thanks. Quote Link to comment Share on other sites More sharing options...
Gury Posted October 12, 2015 Share Posted October 12, 2015 New version (0.2.1) Now this code compiles properly. Value is returned in $a0 and $a1 as it is in Action! Quote Link to comment Share on other sites More sharing options...
funkheld Posted October 14, 2015 Author Share Posted October 14, 2015 hello gury thanks. greeting Quote Link to comment Share on other sites More sharing options...
