master 6801
43 replies to this topic
#26 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,835 posts
  • Coding something good
Posted Sun Oct 6, 2013 8:26 AM
ok now using 2 62256 ram game load play nice but thant crash or sound bug
3D2EA1A4-37D6-4AF1-9A94-E5170CC754AF-910
probably because the breadbord but if someone have an idea ???
i ordered a 64k chip to replace the 32k should do hope so
5-11 can i have your opignion please
Of course your Colecovision will crash!!!
In the memory space there is space only for 24K of RAM, so you need only one 62256 (32K RAM)
To reduce noise put a bypass capacitor 0.1 mf between VCC and GND of RAM, so short as possible.
To test the memory use this little program I wrote for Super Game Module: http://atariage.com/...m/#entry2748035
Edited by nanochess, Sun Oct 6, 2013 8:28 AM.
#27 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Sun Oct 6, 2013 10:18 AM
Yes, yes, capacitors on all the chips... maybe more than one. Shorter wires might be helpful, too.
#28 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Sun Oct 6, 2013 10:56 AM
ok tomorow ill get the capacitor... but when im using only 1 62256 the game
load but is slow and lot of glitch.. when i put 2 62256 and using 2 i/0 for one of the z80 game running perfec until i die then problem start.
just tu be sure should i use only the 62256 or i should use something else and again im not electronic dude i do what you guys telling me and what i find on google so if i need something else tell me and i know i need a sgm but i cant get one
thanks again to you guys and all of you who try to help me in that project
Edited by chart45, Sun Oct 6, 2013 11:29 AM.
#29 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Sun Oct 6, 2013 1:03 PM
ok here's the result of the ram test
D3C74C10-6AF4-43DD-9FA8-CBFCDD9B90AB-162
failure in the lower 8k
this is the y3 i think should i AND it alone and leave y2 and y1 together
#30 nanochess OFFLINE
nanochess
  • 5,835 posts
Posted Sun Oct 6, 2013 3:39 PM
The test is designed for the Super Game Module, you've right the 24K part, congrats!
The 8K part will never work because it's used by the BIOS, so don't worry, ignore it.
And yes, use only one memory 62256, the number is right. As 5-11under said, you should try to use shorter cables and use a perforated board and solder a socket for the memory.
#31 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Sun Oct 6, 2013 3:52 PM
It looks like nano beat me to it. Yes, you should be able to try Zaxxon and Dragon's Lair now, and they should be fine. The SGM is able to switch between BIOS and RAM for the lower 8K, but you don't need that.
#32 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Sun Oct 6, 2013 4:33 PM
for sure I'll use a board and solder everything this was just to know if it was possible to do it now I will work on a pcb for the chip is there something else I should know before doing it like the capacitors
and juste another thing when I remove y2 or y3 don't remember your software detect the sgm module so is it possible to play game design for the sgm without the sound chip
#33 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Sun Oct 6, 2013 6:10 PM
ok tight some connection on the breadboard and now work perfectly thank to all of you
http://i288.photobuc...zpsff3d1ae4.mp4
now ill try to do something clean
Edited by chart45, Sun Oct 6, 2013 6:27 PM.
#34 nanochess OFFLINE
nanochess
  • 5,835 posts
Posted Sun Oct 6, 2013 7:10 PM
Pretty impressive! Congrats! :)
I'm still expecting my SGM to play my cartridges of Zaxxon Supergame, Thexder and Dragon's Lair.
#35 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Sun Oct 6, 2013 7:21 PM
i hope to be contacted by eduardo to get one but with all i read i think i will wait for a long time hope that i will be able to find a way to play all the game until i get my sgm....
#36 JamesD OFFLINE
JamesD
  • 8,441 posts
Posted Sun Oct 6, 2013 10:35 PM
FWIW, I looked at the 6801 master interface and you can't use a 6803 with ROM.
#37 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Mon Oct 7, 2013 4:17 AM
the sgm have is own cpu an bios ???
if yes is it possible to replace one of the adam to the opcode 32k bios
#38 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Mon Oct 7, 2013 5:03 AM
The SGM does not have its own BIOS. The SGM is able to switch between the CV bios and the SGM RAM (lower 8K).
#39 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Mon Oct 7, 2013 7:31 AM
so by using the master 6801 of the adam i will be able to doing it with your help : )
Edited by chart45, Mon Oct 7, 2013 8:00 AM.
#40 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Mon Oct 7, 2013 10:30 AM
the signal to switch the bios come from where the cartrige port ??? and do i really need a separate cpu to doing it ??
Edited by chart45, Mon Oct 7, 2013 10:33 AM.
#41 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Mon Oct 7, 2013 11:14 AM
SGM technical info: http://atariage.com/...echnical-forum/
I don't have an Adam computer, and I don't know much about it. I didn't know it had a 6801 until this thread.
#42 NIAD OFFLINE
NIAD
  • 6,218 posts
Posted Mon Oct 7, 2013 4:20 PM
Where there is a will, there is a way. Congrats! :thumbsup:
#43 jfcarbel OFFLINE
jfcarbel
    Space Invader
  • 24 posts
Posted Sun Sep 23, 2018 7:49 PM
Trying to understand the context of this thread.  Is this a plan for chip replacement on motherboard to integrate SGM functionality for homebrew games?
#44 chart45 OFFLINE
chart45
    Dragonstomper
  • 820 posts
Posted Mon Sep 24, 2018 1:36 PM
at that time Ed was mia and i wanted to play sgm game ... i didnt know fuck all about z80 and address decoding so they help me to add 24k ram to my coleco...
