New hardware: SIO_FIFO
POKEY SIO Transmission floppy disk aspeqt turbo
37 replies to this topic
#1 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Wed Oct 9, 2013 8:51 AM
There is a new hardware for A8:  SIO_FIFO. This device allows data transmission with up to 127kbps speed. Here is the movie with copying disk using this hardware,  "US SECTOR COPIER 4" by E.Reuss and AspeQT emulator. SDX, IDE+ loader etc. also working at this baud rate. Form of device is small PCB between POKEY and mainboard. No cables, no solder (if there is a socket for POKEY on the MB). The device is yet in testing phase but will be available soon.
Edited by Simius, Wed Oct 9, 2013 8:52 AM.
#2 Firedawg OFFLINE
Firedawg
    Dragonstomper
  • 525 posts
Posted Wed Oct 9, 2013 10:25 AM
Very nice Simius!  Can always use more speed.  Count me in for 1 or 2 when they become available.
Mike
#3 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 615 posts
Posted Wed Oct 9, 2013 5:33 PM
Also Interested.
#4 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Wed Oct 9, 2013 11:00 PM
Interesting idea - I guess this device does read/write of it's own accord to SERIN / SEROUT via a local bus?
In theory this could be expanded to all manner of other applications, e.g. automated digital sound playack via local buffer.
#5 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Thu Oct 10, 2013 12:40 AM
SERIN only. Doesn't affect on SEROUT. FIFO is inactive also when baudrate is smaller than 38kbps, then only copies directly the input to the output.
#6 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Thu Oct 10, 2013 1:12 AM
So it works as read-only insofar as Pokey accesses?
How about contention? Does it operate at some multiple of the master clock and do it's reads when it knows that Pokey isn't being accessed?
Edited by Rybags, Thu Oct 10, 2013 1:12 AM.
#7 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Thu Oct 10, 2013 2:23 AM
FIFO is connected between SIO connector (pin no.3) and POKEY SIO input. Master clock is 18.432MHz. Divisor is choosen (using schedule) depending on the content of AUDF3, so baudrate is the same as POKEY has. Or, when AUDF4 > 0 or AUDF3 > 16 or clock source is other than AUDF3+AUDF4, the state of input is copied to the output (with about 700ns delay).
#8 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Thu Oct 10, 2013 2:51 AM
OK, way different to what I imagined. So is this just essentially something that allows us to avoid input overrun by buffering more than 1 received and 1 partially received byte at a time?
#9 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Thu Oct 10, 2013 3:07 AM
Exactly.
#10 TXG/MNX OFFLINE
TXG/MNX
  • 3,633 posts
Posted Sun Nov 3, 2013 9:32 AM
so basicly this fifo can be used for any sio device you connect ?
#11 Kyle22 OFFLINE
Kyle22
  • 3,823 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sun Nov 3, 2013 3:17 PM
It appears to be very fast in the movie.  May we see a picture of the device?
#12 Defender II OFFLINE
Defender II
  • 1,170 posts
Posted Sun Nov 3, 2013 11:39 PM
Sounds like I need more cash again soon.
#13 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Mon Nov 4, 2013 9:25 AM
Yes.
#14 Mathy OFFLINE
Mathy
  • 2,860 posts
Posted Mon Nov 4, 2013 10:33 AM
Hello Simius
Is this placed underneath POKEY? What if you have a dual POKEY upgrade? Will that fit?
Sincerely
Mathy
#15 TXG/MNX OFFLINE
TXG/MNX
  • 3,633 posts
Posted Mon Nov 4, 2013 12:59 PM
Hello Simius
Sincerely
Mathy
Cool then you can install maybe 2 FIFO's :grin:
#16 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Mon Nov 4, 2013 2:46 PM
Hello Simius
Sincerely
Mathy
Of course. FIFO have to be placed under this one, which handles SIO. The only problem could be the height of set.
#17 Mathy OFFLINE
Mathy
  • 2,860 posts
Posted Mon Nov 4, 2013 6:36 PM
Hello Simius
How many millimeters would the FiFo add?
Sincerely
Mathy
#18 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Tue Nov 5, 2013 12:10 AM
Hello Simius
Sincerely
Mathy
max. 10,3mm (4.5 mm IC socket +1.5mm PCB +4.3mm header)
#19 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Fri Dec 20, 2013 6:01 PM
Better late than never. :)
Device is working in two modes: FIFO (baudrate greater than border value) and transparent mode (equal or less than border value) and is configurable through $D20C register (write only).
0xxxxxxx - initialization (FIFO cache cleaning)
10aaaaaa - set temporary border value (as AUDF3 content, $00...$3F)
11aaaaaa - set default border value
About 12 pcs. available at the begining of next year. Price: 25USD+5USD shipping.
#20 Kyle22 OFFLINE
Kyle22
  • 3,823 posts
Posted Fri Dec 20, 2013 6:41 PM
I would like one.
Thanks
-K
#21 atari8warez OFFLINE
atari8warez
  • 2,724 posts
Posted Fri Dec 20, 2013 11:53 PM
simius, what type of apps will benefit from this device, your demo movie by the way is not accessible (says can't find the server at starzaki.eu.org)
Edited by atari8warez, Fri Dec 20, 2013 11:55 PM.
#22 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Sat Dec 21, 2013 12:46 AM
It's hard to determine. Each can, which uses SIO. I'm using it for example with slightly modified OS, under the ordinary MyDOS.
#23 atari8warez OFFLINE
atari8warez
  • 2,724 posts
Posted Sat Dec 21, 2013 1:35 AM
So is it sort of like the hardware version of Hias's high speed patch?
#24 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Sat Dec 21, 2013 1:51 AM
It's just a FIFO/buffer to help prevent serial overrun which can be an especial problem at the higher speeds. It doesn't actually play any part in determining what SIO speed is in use though.
OK, selling it short - "it's just" is understating - this is giving us something that Pokey could well have done with in the first place.
#25 bf2k+ OFFLINE
bf2k+
  • 1,772 posts
Posted Sat Dec 21, 2013 6:27 AM
I'll take one...
Also tagged with one or more of these keywords: POKEY, SIO, Transmission, floppy disk, aspeqt, turbo
