New hardware: SIO_FIFO
POKEY SIO Transmission floppy disk aspeqt turbo
37 replies to this topic
#26 Firedawg OFFLINE
Firedawg
    Dragonstomper
  • 525 posts
Posted Sat Dec 21, 2013 9:33 AM
Very nice Simius!  Can always use more speed.  Count me in for 1 or 2 when they become available.
Mike
#27 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 615 posts
Posted Sat Dec 21, 2013 9:36 AM
I would also like 2.
Robert
#28 atari8warez OFFLINE
atari8warez
  • 2,724 posts
Posted Wed Dec 25, 2013 11:02 PM
It's just a FIFO/buffer to help prevent serial overrun which can be an especial problem at the higher speeds. It doesn't actually play any part in determining what SIO speed is in use though.
OK, selling it short - "it's just" is understating - this is giving us something that Pokey could well have done with in the first place.
Ok thanks, so it makes high speed SIO more reliable by buffering incoming bytes and that we can use Pokey divisor 0 without hiccups. I hope I finally got it :)
Edited by atari8warez, Wed Dec 25, 2013 11:05 PM.
#29 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Fri Dec 27, 2013 3:35 PM
All devices are ready for shipment. I can accept the payments now. Info on the PM.
#30 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 615 posts
Posted Sat Apr 12, 2014 4:45 PM
Hello, I installed the FIFO mod in my 130XE but have not tried using it yet, I have not altered the default value in the $register listed above.  I was testing out some new floppy drives i had just picked up, but none of them were working.
After several failed attempts at getting a floppy to boot, I figured I would get out a known good drive and make sure the disk I was using were still OK.  The known good drive is a Happy 1050, and it would only boot in Hi-speed OS.   At first, I wrongly assumed it a was and issue with the stock OS I had flashed in my u1mb. I have tested all my drives with FIFO installed and have mixed results.  Stock 1050's would not boot at all in standard or hi-speed OS.  Indus, Rana and XF-551 would boot, but load data was sometimes corrupted.
I was preparing to drop in a stock OS and MMU, when I spotted the FIFO mod and decided to try pulling it first.  After pulling the FIFO board everything is back to normal and booting normally.
Are the FIFO mods defaulted for Hi-speed mode?   Do I need to disable the FIFO Mod while using floppy drive?  Any one else have similar issues with fifo and floppy's?
Best Regards
Robert
Edited by venom4728a, Sat Apr 12, 2014 4:48 PM.
#31 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Mon Apr 14, 2014 2:20 PM
Strange. There should be absolutely no problem with  any floppy drive at normal speed, because the input state is simply (with very small delay) copied to the output, regardless of the clock rate.
It may be some hardware problem. I don't know what. Capacitors are removed as described?
You can always send back.
Edited by Simius, Mon Apr 14, 2014 2:21 PM.
#32 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 615 posts
Posted Mon Apr 14, 2014 5:04 PM
I must have missed the part that said we needed to remove some capacitors?  Which ones?
Best Regards
Robert
#33 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Mon Apr 14, 2014 11:29 PM
Marked red on the picture.
#34 Bumzyman OFFLINE
Bumzyman
    Chopper Commander
  • 174 posts
Posted Thu Apr 17, 2014 3:57 PM
Simius, are these still available, whats the cost, and how do we order?
#35 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Fri Apr 18, 2014 1:10 AM
There is still a few. 25USD+6USD shipping. Payment by Paypal. The same address as before, when paying for the IDE+.
Edited by Simius, Fri Apr 18, 2014 1:12 AM.
#36 Kyle22 OFFLINE
Kyle22
  • 3,828 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sun Feb 26, 2017 3:56 PM
Bump.
Are there any of these left?
#37 Simius OFFLINE
Simius
    Dragonstomper
  • 542 posts
Posted Mon Feb 27, 2017 12:27 AM
Last two.
#38 tuf OFFLINE
tuf
    Chopper Commander
  • 245 posts
Posted Tue Feb 28, 2017 11:35 PM
I'll take one if any left - I forgot all about this.
Also tagged with one or more of these keywords: POKEY, SIO, Transmission, floppy disk, aspeqt, turbo
