Ice-T XE 2.76 released
ice-t terminal
175 replies to this topic
#151 w1k OFFLINE
w1k
  • 1,669 posts
Posted Sat Oct 15, 2016 12:05 AM
dead project.. nobody uses internet on atari.. because - games only.. omg
#152 Stephen OFFLINE
Stephen
  • 7,261 posts
  • A8 Gear Head
Posted Sat Oct 15, 2016 9:07 AM
Hi Guys, I have a problem using ICE-T under SDX with APE, when starting ICET.COM, R: is not loaded automatically using APE, while normally when I boot ICE-T from MYDOS ATR there's no such problem. Any hint?
Can you perhaps post a directory of the disk you are using?  Some versions of IceT have the device handler pre-pended to the executable.  Others, have just the "raw" Ice-T program and require the driver to be loaded first.  When using APE, you will want to use the standard 850 driver.  Since my SDX setup is rather customized (I always run in 80 column mode, with TD on, etc.) I have a BAT file which cleans up the environment first, loads the driver, then loads Ice-T.  It does work great with SDX and APE, it's all I use.
#153 itaych OFFLINE
itaych
    Chopper Commander
  • 210 posts
Posted Sat Oct 15, 2016 9:16 AM
Sure. Read the "getting started" section of the doc. :)
#154 Jacques OFFLINE
Jacques
    Moonsweeper
  • 298 posts
Posted Sat Oct 15, 2016 11:37 AM
Thank you Itay, stupid me ;) Obviosly I forgotten the part about R: handler being loaded automatically under MyDOS which is not the case with SDX. And funnily enough, I already had nice .BAT file created few years ago on my SDX partition :D
#155 ProWizard OFFLINE
ProWizard
  • 4,674 posts
  • Into Stampede
Posted Sat Oct 15, 2016 3:54 PM
this is a VT1xx terminal client, which can be used over RS232. This is a program just like Bobterm, but now with ANSI (color) and 80 column width.
1) I use this program a lot
2) It is amazing, one of my most favorite tools ever
3) It is not an TCP/IP stack compatible tool
So what are you complaining about?
Edited by ProWizard, Sat Oct 15, 2016 4:05 PM.
#156 w1k OFFLINE
w1k
  • 1,669 posts
Posted Sun Oct 16, 2016 12:10 AM
i know, its amazing, i love that program.. but most atarian dont interested.. because  - gamers
#157 ProWizard OFFLINE
ProWizard
  • 4,674 posts
  • Into Stampede
Posted Sun Oct 16, 2016 3:29 AM
But you call it a dead project and you started about internet on the atari...
Wrong thread perhaps?
And what is wrong with games? If there were no video games, Atari wouldn't have existed in the first place.
#158 w1k OFFLINE
w1k
  • 1,669 posts
Posted Sun Oct 16, 2016 4:07 AM
i dont see any progres.. ice-t is fantastic program, i love it
with games is nothing wrong, but 99% atarians are interested only for games, nothing else.. if more people (then you and I) use this program, author making new releases and add features
#159 Kyle22 OFFLINE
Kyle22
  • 3,716 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sun Oct 16, 2016 8:20 PM
I personally spend more time with programming languages, applications and tools than I do gaming.
#160 timofonic OFFLINE
timofonic
    Star Raider
  • 92 posts
Posted Tue Nov 29, 2016 9:30 AM
Did you develop it using some Version Control System ike CVS, SVN or Git? Are you willing to publish the source code?
#161 Mechanicjay OFFLINE
Mechanicjay
    Star Raider
  • 94 posts
Posted Tue Nov 29, 2016 1:04 PM
Okay, I have an interesting one.
I am unable to interact with certain services with ICET that I can with FlickerTerm.
A really easy example is to connect to port 80 of any webserver and enter:
GET /
Another is to telnet to rainmaker.wunderground.com to check the weather.
With ICET you'll never get anywhere, it'll just sit there for ever.
I am able to use this stuff with FlickerTerm by setting "CR out" to "CR + LF".
I notice that ICET has a setting for EoL, but changing the settings don't seem to change the behaviour, at least in examples like the above.
Is there something I can do to further help test/diagnose this?
#162 itaych OFFLINE
itaych
    Chopper Commander
  • 210 posts
Posted Tue Nov 29, 2016 2:15 PM
Ice-T was mostly developed in my bedroom as a teenager with an Atari 130XE. I knew nothing of these three letter acronyms of which you speak and even if I did there was no practical way for me to use them :) .. During a few years that I continued development (2012-2014 or so) I simply kept a snapshot of every release.
I published the source code to version 2.72 (released in 1997) here. It's not very pretty and much of it has been changed or even rewritten since then, but I haven't published the newer sources - and I think no one even asked for them. Perhaps I will with the next major release (any decade now).
Ice-T was designed as a VT-100 (now 102/52/ANSI) emulator, not a general Telnet client. The standard behavior for these devices is to send a CR when the user hits Return. It's nice that FlickerTerm allows to change this, at the time I saw no need for this. (Remember Ice-T was written first, I didn't have FT to compare to, and nothing that I tested against needed it.) I wish it were trivial to add this feature, but nothing is simple when your project is written in assembly.
The EOL setting you mention governs how Ice-T interprets incoming codes, not outgoing. I've managed to interact with websites and the weather site you mention by using Ctrl-J where you'd press Return. Note that if you want to see what you're typing enable Local Echo.
#163 Mechanicjay OFFLINE
Mechanicjay
    Star Raider
  • 94 posts
Posted Tue Nov 29, 2016 3:29 PM
Understood, and I suspected that may have been an incoming setting vs outgoing.
That said, Ctrl-J will work well enough for me!  Thanks for the pointer.
--Jason
#164 Mechanicjay OFFLINE
Mechanicjay
    Star Raider
  • 94 posts
Posted Tue Nov 29, 2016 5:12 PM
I should also add, that my above "issue" should in no way be misconstrued as a criticism of this truly amazing utility.   The 2.8.0 Alpha with colors and and stuff is really mind-blowing.
#165 _The Doctor__ OFFLINE
_The Doctor__
  • 5,813 posts
Posted Tue Dec 6, 2016 10:29 PM
@itaych,
Kind sir, I remind you it's the holiday season of giving.... and you might perchance have time....
awe heck we're just dying to see your next revision!
Edited by _The Doctor__, Tue Dec 6, 2016 10:29 PM.
#166 _The Doctor__ OFFLINE
_The Doctor__
  • 5,813 posts
Posted Fri Apr 14, 2017 7:13 AM
bump
#167 w1k OFFLINE
w1k
  • 1,669 posts
Posted Sat Apr 15, 2017 7:19 AM
2.9?;)
#168 w1k OFFLINE
w1k
  • 1,669 posts
Posted Mon Apr 24, 2017 8:55 AM
i trying connect to icet- via lantronix..
on ICE-T i SEE "C" symbol - im online..
when i type
AT
ATDI SERVER:PORT, then
%ERROR parameter not known
NOT CARRER
any help?
#169 DrVenkman ONLINE
DrVenkman
  • 3,596 posts
  • Back off, man! I'm a scientist.
Posted Mon Apr 24, 2017 4:35 PM
when i type
AT
NOT CARRER
any help?
ATDI isn't a valid command. Use ATDT instead.
#170 w1k OFFLINE
w1k
  • 1,669 posts
Posted Mon Apr 24, 2017 10:45 PM
thanks, works
#171 Kyle22 OFFLINE
Kyle22
  • 3,716 posts
Posted Wed Apr 26, 2017 6:00 PM
Also, on the UDS-10, it doesn't like the colon before the port. A slash works.  ATDT 12.34.56.78/8888, for example.
#172 _The Doctor__ OFFLINE
_The Doctor__
  • 5,813 posts
Posted Fri May 5, 2017 4:41 PM
That's one of my lantronix peeves , the use of    /       ,      :    etc for port from model to model... some boxes like atdtip some like atdt ip....  grrr... I was contemplating doing a lantronix only what you need thread for each model, and specifically what you need to set it up using the Atari by istelf and for two purposes... to dial out or to run a bbs... I noticed someone posted the boxes only establish a raw connection in some other thread... this is not true... on an mss100 it depends on the port you use as to what protocol is enacted.... this was done to keep compatibility and to allow protocols to stay out of the way for binary transfers etc.... you most certainly can observe the differences or select the protocol a number or different ways depending on the box....   ie   atdt xxx.xxx.xxx.xxxt     atdt xxx.xxx.xxx.xxxu  etc etc.... you can select the tunnel protocol you wish to use by port and assign it in config... this all gets very messy and I suggest you get what you can from the lantronix site while you can... stuff is disappearing.... like the domain name patch.... posts and just recently pages on the site itself... you may need to try to get what you want a couple of different links or ways to be successful.... also check the ftp site.... Scrounge up what you can even if it makes your head swim... If need be later someone who mucks about might need it to help you or someone you know... they will gladly accept the documentation and will figure out what to do with it.
Edited by _The Doctor__, Fri May 5, 2017 4:57 PM.
#173 _The Doctor__ OFFLINE
_The Doctor__
  • 5,813 posts
Posted Fri Sep 7, 2018 3:56 PM
But I want my new cup of ICE-T now.....   you teased me with a post and a pm at some point.... what's going on.....   More T please :)
#174 doctorclu OFFLINE
doctorclu
    ***Moon Patrol 5200*** *Moon Master2015* *Blue Max:Class 4*
  • 7,656 posts
  • *Star Raiders 2* **Captain -CL 2**
Posted Sat Sep 8, 2018 6:40 AM
More Ice-T.... more Ice-T!!!  :D
#175 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 440 posts
Posted Sat Sep 8, 2018 1:30 PM
How to upload with ICE-T in a different
manner than ascii?
Stefan
Also tagged with one or more of these keywords: ice-t, terminal
