Maria Gets Some New Clothes Too
atari 7800 prosystem palette ntsc pal maria
2 replies to this topic
#1 Trebor OFFLINE
Trebor
  • 4,682 posts
Posted Wed Oct 16, 2013 9:11 PM
New palettes for ProSystem - Maria247, Maria252, Maria257, Maria262, Maria267, Maria272, & Maria277!
Download them here: Attached File  Maria2XX_Palettes_20131016.zip   48.76KB   139 downloads
Not to be outdone by her older sister, Maria has received some new clothes as well.
Like the Stella palettes, we have Phase Shifts 24.7 through 27.7 degrees in 0.5 degree increments.  Unlike the Stella palettes under the Stella emulator, Maria has no easy way to make adjustments to the base values when being utilized under the ProSystem emulator, as many video options are not present. So, in addition to the base values, three varieties of intensity accompany the set.
Also, the Maria palettes have different files for each region.  NTSC and PAL regions are included.
After further investigation and research, it appears what seems to be 'automatic' pot adjusting while the system is running is simply just the phase shifting.  It is better understood and captured at a lower/cooler start (24.7 degrees) and watching via gradual increases of 0.5 degree.  Previous palettes only offered phase shifts 25.7, 26.7, and 27.7.
This set is much more complete and thorough in covering the 7800's hues and their respective phases on a CRT better than any prior releases.
Screen captures to follow are in this order:
Maria247 --> Maria252 --> Maria257 (aka 180 degrees colorburst) --> Maria262 --> Maria267 --> Maria272 --> Maria277
Color Charts (NTSC)
NTSC_COLOR_SELECTOR_247.PNG NTSC_COLOR_SELECTOR_252.PNG NTSC_COLOR_SELECTOR_257.PNG NTSC_COLOR_SELECTOR_262.PNG NTSC_COLOR_SELECTOR_267.PNG NTSC_COLOR_SELECTOR_272.PNG NTSC_COLOR_SELECTOR_277.PNG
Color Charts (PAL)
PAL_COLOR_SELECTOR_247.PNG PAL_COLOR_SELECTOR_252.PNG PAL_COLOR_SELECTOR_257.PNG PAL_COLOR_SELECTOR_262.PNG PAL_COLOR_SELECTOR_267.PNG PAL_COLOR_SELECTOR_272.PNG PAL_COLOR_SELECTOR_277.PNG
Color Grids (NTSC)
NTSC_COLOR_GRID_247.PNG NTSC_COLOR_GRID_252.PNG NTSC_COLOR_GRID_257.PNG NTSC_COLOR_GRID_262.PNG NTSC_COLOR_GRID_267.PNG NTSC_COLOR_GRID_272.PNG NTSC_COLOR_GRID_277.PNG
Color Grids (PAL)
PAL_COLOR_GRID_247.PNG PAL_COLOR_GRID_252.PNG PAL_COLOR_GRID_257.PNG PAL_COLOR_GRID_262.PNG PAL_COLOR_GRID_267.PNG PAL_COLOR_GRID_272.PNG PAL_COLOR_GRID_277.PNG
Following screen captures provide an example difference of intensity in this order:
Maria262 --> Maria262x1 --> Maria262x2  --> Maria262x3
Donkey Kong XM
Bentley Bear's Crystal Quest
Here's the Phase shifting in action shown in the following order:
Maria247 --> Maria252 --> Maria257 --> Maria262 --> Maria267 --> Maria272 --> Maria277
Joust
Maria247Joust.PNG Maria252Joust.PNG Maria257Joust.PNG Maria262Joust.PNG Maria267Joust.PNG Maria272Joust.PNG Maria277Joust.PNG
Scrapyard Dog
Maria247SD.PNG Maria252SD.PNG Maria257SD.PNG Maria262SD.PNG Maria267SD.PNG Maria272SD.PNG Maria277SD.PNG
Enjoy.
#2 Trebor OFFLINE
Trebor
  • 4,682 posts
Posted Thu Oct 17, 2013 11:17 AM
Added a saturation bump only (x0) and a few contrast increased options to the line (x4, x5, x6) better rounding out the display choices for the Maria palette set.
Download the entire set here: Attached File  Maria2XX_Palettes_20131017.zip   96.96KB   134 downloads
Previous palettes in the Maria set are the same, just new ones were added.
Here is a line of base palette with x0 thru x6 via in-game captures. Captures are from the phase shift 26.2 degrees, but the concept follows for all phase shifts.
Screen shots are in the following order:
Maria262 --> Maria262x0 --> Maria262x1 --> Maria262x2 --> Maria262x3 --> Maria262x4 --> Maria262x5 --> Maria262x6
Donkey Kong XM
Maria262DKXM2.PNG Maria262x0DKXM2.PNG Maria262x1DKXM2.PNG Maria262x2DKXM2.PNG Maria262x3DKXM2.PNG Maria262x4DKXM2.PNG Maria262x5DKXM2.PNG Maria262x6DKXM2.PNG
Maria262BBCQ2.PNG Maria262x0BBCQ2.PNG Maria262x1BBCQ2.PNG Maria262x2BBCQ2.PNG Maria262x3BBCQ2.PNG Maria262x4BBCQ2.PNG Maria262x5BBCQ2.PNG Maria262x6BBCQ2.PNG
Xenophobe
Maria262XENO.PNG Maria262x0XENO.PNG Maria262x1XENO.PNG Maria262x2XENO.PNG Maria262x3XENO.PNG Maria262x4XENO.PNG Maria262x5XENO.PNG Maria262x6XENO.PNG
#3 Trebor OFFLINE
Trebor
  • 4,682 posts
Posted Fri Oct 18, 2013 11:37 AM
To provide an even more diverse set of palettes for Maria, x7, x8, and x9 have been created. That brings the total series for each phase shift having x0 thru x9 as available display options in addition to the base palette.
Download the complete NTSC & PAL set here: Attached File  Maria2XX_Palettes_20131018.zip   132.14KB   159 downloads
*November 3, 2013 Update: There was a slight typo for the NTSC and PAL 26.7 degrees phase shift palettes that has been corrected.  Visually it is not noticeable by the naked eye, but technically it was incorrect.
The corrected palette set is here: Attached File  Maria2XX_Palettes_20131103.zip   132.14KB   330 downloads
[Includes all prior palettes posted earlier just have them overwritten with this set]
*NOTE:  A summary of Maria (Atari 7800) and her sister Stella (Atari 2600) colors and console behavior can be found HERE.
What to expect from the display options...
x0 = Saturation Increase
x1
x2 = Gamma Increase and Saturation Deltas
x3
x4
x5 = Gamma and Saturation Increase with Contrast Deltas
x6
x7
x8 = Saturation Increase with Contrast Deltas
x9
It runs the display gambit reasonably well.
The following captures are in this order:
Maria262 --> Maria262x0 --> Maria262x1 --> Maria262x2 --> Maria262x3 --> Maria262x4 --> Maria262x5 --> Maria262x6 --> Maria262x7 --> Maria262x8 --> Maria262x9
Maria262BBCQ3.PNG Maria262x0BBCQ3.PNG Maria262x1BBCQ3.PNG Maria262x2BBCQ3.PNG Maria262x3BBCQ3.PNG Maria262x4BBCQ3.PNG Maria262x5BBCQ3.PNG Maria262x6BBCQ3.PNG Maria262x7BBCQ3.PNG Maria262x8BBCQ3.PNG Maria262x9BBCQ3.PNG
Donkey Kong XM
Maria262DKXM3.PNG Maria262x0DKXM3.PNG Maria262x1DKXM3.PNG Maria262x2DKXM3.PNG Maria262x3DKXM3.PNG Maria262x4DKXM3.PNG Maria262x5DKXM3.PNG Maria262x6DKXM3.PNG Maria262x7DKXM3.PNG Maria262x8DKXM3.PNG Maria262x9DKXM3.PNG
Froggie
Maria262FROG.PNG Maria262x0FROG.PNG Maria262x1FROG.PNG Maria262x2FROG.PNG Maria262x3FROG.PNG Maria262x4FROG.PNG Maria262x5FROG.PNG Maria262x6FROG.PNG Maria262x7FROG.PNG Maria262x8FROG.PNG Maria262x9FROG.PNG
Commando
Maria262COMM.PNG Maria262x0COMM.PNG Maria262x1COMM.PNG Maria262x2COMM.PNG Maria262x3COMM.PNG Maria262x4COMM.PNG Maria262x5COMM.PNG Maria262x6COMM.PNG Maria262x7COMM.PNG Maria262x8COMM.PNG Maria262x9COMM.PNG
Pole Position II
Maria262PPII.PNG Maria262x0PPII.PNG Maria262x1PPII.PNG Maria262x2PPII.PNG Maria262x3PPII.PNG Maria262x4PPII.PNG Maria262x5PPII.PNG Maria262x6PPII.PNG Maria262x7PPII.PNG Maria262x8PPII.PNG Maria262x9PPII.PNG
Utilizing the 'x7' display variety, here is the phase shift in this order:
Maria247x7 --> Maria252x7 --> Maria257x7 --> Maria262x7 --> Maria267x7 --> Maria272x7 --> Maria277x7
Choplifter!
Maria247x7CHOP.PNG Maria252x7CHOP.PNG Maria257x7CHOP.PNG Maria262x7CHOP.PNG Maria267x7CHOP.PNG Maria272x7CHOP.PNG Maria277x7CHOP.PNG
Also tagged with one or more of these keywords: atari 7800, prosystem, palette, ntsc, pal, maria
