Altirra 2.40 Final out..
412 replies to this topic
#401 morelenmir OFFLINE
morelenmir
  • 1,458 posts
Posted Fri Jul 11, 2014 5:03 AM
A very belated but nonetheless sincere thanks to Phaeron for implementing some extremely useful improvements to the debugger.
I have not done any ASM for quite a while now, so only noticed today that the source window has begun to - INCREDIBLY conveniently - dock with the other windows!!!  That alone makes programming and debugging a 100% more comfortable.  Also, I think - although I have not experimented widely - the step into/out/over keyboard shortcuts are no longer hard coded either.  Another MASSIVE win.
MANY, MANY thanks Phaeron.  When I get back in to Atari programming this will make a huge difference to me at least and I am sure many others.
...AND on further inspection I also discover a feature I have wanted for literally years has ALSO been implemented while I was busy with other things - you can now clear the printer window directly!!!!  This mean you do not have to close and re-open it to 'insert a blank sheet' as it were.
Again - MANY thanks Avery.  Many thanks for listening and also for remembering.  This mioght give me the push I need to get back in to Atari ASM.
Edited by morelenmir, Fri Jul 11, 2014 5:16 AM.
#402 phaeron OFFLINE
phaeron
  • 2,506 posts
Posted Sun Jul 20, 2014 8:54 PM
Alright, I have everything about set to release 2.50, except for a small problem... namely that the compiler I've been using to build it is running very flakily on this new system. I've been able to generate a build by forcing off precompiled headers, which is a bit wonky. Please give this test build a check and see if you spot anything awry. It's basically the same as 2.50-test39 except for a small fix for slow startup. If all's good after a short check then I can release 2.50 final.
http://www.virtualdu...2.50-test40.zip
http://www.virtualdu...-test40-src.zip
To fix this problem, the next version (2.60) will be built with Visual Studio 2010, so I'll be dropping support for Windows 2000 and XP pre-SP2. I doubt anyone actually runs it on these, but if you do, fair warning....
#403 Mclaneinc OFFLINE
Mclaneinc
  • 5,675 posts
Posted Wed Jul 23, 2014 3:58 AM
Had a long hard play with most things and no crashes or odd behaviour here, admittedly I don't use bits like SIDE stuff at all nor the monitor that much but in terms of playing stability it seems ok so far...
Maybe those that use those functions could say if its all been ok for them just so you know...(Although silence is normally the best proof of no problems :)  )
Edited by Mclaneinc, Wed Jul 23, 2014 4:05 AM.
#404 morelenmir OFFLINE
morelenmir
  • 1,458 posts
Posted Fri Jul 25, 2014 9:01 AM
It is odd you should get so many problems from a new system Phaeron!  I imagine you must have upgraded the OS along with the hardware.  Were you using one of the GNU compilers/linkers?
Edited by morelenmir, Fri Jul 25, 2014 9:02 AM.
#405 phaeron OFFLINE
phaeron
  • 2,506 posts
Posted Sat Jul 26, 2014 5:19 AM
Nope, I use Visual C++. GCC on Windows is too icky for my quirky tastes.
The problem, as I understand it, is that the VS2005 compiler relies on being able to reload binary data at the same address each time. Fine idea when you're writing 6502 code, bad idea on a modern OS with ASLR. From what I understand it actually started to be a problem with Vista, but because of Altirra's relatively small size I'd never had a problem on Windows 7. It seemed to be working on Windows 8.1 too until one day some updates installed and then I basically couldn't compile. Until now, that the compiler was a bit old hadn't been an impediment -- I wasn't really running into cases of "this could be so much better if I were using a newer compiler." Not being able to use precompiled headers, though, is a dealbreaker.
#406 morelenmir OFFLINE
morelenmir
  • 1,458 posts
Posted Sat Jul 26, 2014 6:26 AM
THAT is really strange!  Basically MS are bypassing their own OS routines - in a fashion they criticize others for because it... BREAKS CODE when the underlying architecture changes!!!
You are brave shifting to 8.1 though!!!  I am going to give 8.x miss altogether and hope 'Threshold' will deliver the goods.  From what I see they have largely junked the Metro farrago so that is something at least.
#407 Mclaneinc OFFLINE
Mclaneinc
  • 5,675 posts
Posted Sat Jul 26, 2014 6:30 AM
I'm normally an early adopter of MS OS's, I sort of test them for mates around before saying to them to upgrade or not, 8.0 & 8.1 is the first time I've said no to it..
A friend got a new PC which came with it and its so hidden internally and that's with the latest update to make it more friendly, also heard so many people complain about items crashing because of its changes..
#408 morelenmir OFFLINE
morelenmir
  • 1,458 posts
Posted Sat Jul 26, 2014 7:01 AM
I mean...  In all honesty I like MS software - they CAN produce nice GUI applications.  However they are also colossally arrogant and it was that sheer arrogance which set me against 8 from the get go.  They just unilaterally decided that EVERYONE wanted the same touch-screen UI across every platform.  That was it.  Like it or not - and too bad if 'not' - you ARE going to run your PC as if it were a mobile telephone...  and I don't even HAVE a mobile telephone!!!  Maybe Metro is ace on a tablet like 'Surface' - I could see it working in that setting pretty well.  Maybe even it is tolerable for a console where interaction is fairly linear and predictable in the scheme of things, although I MASSIVELY preferred the original 360 dashboard with the 'Panes'.  But for a PC..  Nope.  And no matter how 'cool' and 'modern' you tell me it is, no matter how many smiling pretty commercial models you post to your homepage I am NOT going to agree with you MS!
But 'Threshold' looks like it has learnt the lesson and kept the few good bits from metro and nicely integrated them into a real 7-style GUI.
Which is the real crux of the matter.  In my opinion if you want a GUI then you should use 7.  I you want a command-line you should use Unix/Linux.  No matter how much people and third parties try to fill the other shoe like 'Take Command' or 'Gnome'/'KDE' - it doesn't work.
#409 Mclaneinc OFFLINE
Mclaneinc
  • 5,675 posts
Posted Sat Jul 26, 2014 7:23 AM
I'm very happy with 7 X64, its not as pretty as 8.1 but then again I turn all the AERO stuff off 7 anyway so pretty pretty does nothing for me. What I also didn't like on his 8.1 was the constant pressure to be part of Windows Live, I don't use the online stuff on my Xbox and I certainly don't want to be pushed at it when I use the computer, like you I don't have a mobile and like you I don't want my computer to behave like one, I want a nice GUI, COMPATIBILITY and SOLID OS.
I also don't want bloatware but hey, its compulsory with MS...
#410 morelenmir OFFLINE
morelenmir
  • 1,458 posts
Posted Sat Jul 26, 2014 7:58 AM
Even now, nearly fifteen years later I still think 'Windows 2000' was the best OS they have ever released.
#411 Mclaneinc OFFLINE
Mclaneinc
  • 5,675 posts
Posted Sat Jul 26, 2014 8:37 AM
In terms of best OS ever used, for me its the Amiga OS, loved it...Really nice and easy to use and loads under the hood, as for MS ones, I'd say 7 has been my overall favourite, I forget what was on my first PC just after I shifted up for the Amiga but the DOS setting up was such an annoyance after the Amiga, did I have enough base mem, was QUEMM working right, were the Soundblaster interrupts correct..
At least 7 auto configures most stuff.
#412 morelenmir OFFLINE
morelenmir
  • 1,458 posts
Posted Sat Jul 26, 2014 9:11 AM
The first - and still to my mind best - OS I ever used was the hardcoded RISCOS 3 that came on ROM with the ARM A400/4000/5000's.  That was my first exposure to a GUI environment and i was blown away.  Everything, absolutely everything that came after was compared to that and came up wanting.  ESPECIALLY the jump I made from using ARM machines at highschool and then buying my own 486DX2-66 PC for home.  Arrggghhh...  SO SLOW!!!!  Going from RISCOS to Windows 3.1/DOS was worse than a culture shock - it genuinely, along with hardware problems led me to take the PC back and demand my money be returned.  Which for the most part I got.  I think the chap could apreciate my point - especially as I had pretty much make him promise it would be the fastest machine available at that time in late March 1994.
I LOVED RISCOS.  And then I tried the excellent 'VirtualAcorn' emulator recently and...  I don't know.  I did not realize how good the windows Aero GUI had become and how favourably modern machines contrasted with old.  Nonetheless I still have an impossibly rosy memory of the old ARM machines and even have four or five complete systems broken down in to component parts kicking around somewhere.   just have never had room to put them together and network away.  Maybe one day - when I have found a source for new solder-in CMOS batteries for their motherboards!!!
Oddly I have never used an Amiga - not even in emulation.
Edited by morelenmir, Sat Jul 26, 2014 9:12 AM.
#413 The Usotsuki OFFLINE
The Usotsuki
  • 1,959 posts
  • Also called "Licca"
Posted Sat Jul 26, 2014 12:32 PM
Doesn't RiscOS run on the RasPi now?
Also, my first GUI was GS/OS, or more precisely ProDOS-16 1.3.
